Herbmiester 945 Report post Posted March 3, 2024 A couple of weeks ago I bought a 1999 Z3 of FB Marketplace for a ridiculously cheap price. FB Marketplace is in my mind, the Wild West of Car buying and in this case I was first to contact him, first to get to him and paid on the spot after a quick carjam. The spec is not too bad, 2l M52, Auto GM 4 speed , but it is an LCI with the fat bum, has an LSD and a reasonably nice interior with Heated 2 tone seats. Body wise its pretty tidy with a few scratches here and there. It has 179k on it and has clearly been looked after, for part of its life. I will admit I have always loved the Z3 look, and convincing Mrs Herbmiester, was actually easier than I thought. She did state of course that 6 cars may be overkill. Pfffft. She didn't mention the 7 motorbikes, so all good I guess. As mentioned the car did not run, well technically it did but would not rev past 2500 rpm-ish. So I figured it was the throttle body, and as such I took a punt and paid the princely sum of $2300 for it. After trailering it home, I looked in the box of spares and found a spare throttle body. After taking the old one off I could see that it had corrosion holding the blade shut, very firmly shut in fact. For those in the know this TB was used for a few years and uses a cable but also has a servo motor that is what actually opens the blade. The throttle body rubber manifold was split, but a quick visit to Pick a Part sorted that. With the new bits installed it fired right up. Just like on TV. Haha. Next are the issues that need to be addressed. While I dont want to skimp on important fixes, this will be a budget restoration with money spent where it . and I will state for the record I am not into M539 levels of fixing things. The ABS light is on, with the dreaded F0 code. Once I get the unit out from under the dash, Pramod says he can reprogram the unit. There is an intermittent transmission warning light, so a trans service is probably required. There is a rocker cover leak. No surprises there. Drivers door card is loose (Fixed) Radio is a crappy old Sony with no BT (Fixed). New front marker lights. Cut and Polish. The suspension is tired, shocks are not leaking but bump-stops are gone. Front lollipops feel worn. The suspension rubs on the inner guards especially at the front. New bump stops and a thicker spring perch should sort this. At the rear I will raise it 10-15mm with some thicker spring pads. I will pull the shocks before I commit to replacing them, but they look pretty old so if anyone has some Z3 shocks I am all ears. 1 Quote Share this post Link to post Share on other sites
Eagle 1732 Report post Posted March 3, 2024 Struts and shocks sure to be well worn if they are original. Bilstein B4's front and rear from Spareto are $700 shipped. Less than 1k you can replace the entire suspension - subframe bushings, trailing arm bushings, sway bar links & bushings, front control arm bushings and struts\shocks. Very easy to do and makes a big difference. Quote Share this post Link to post Share on other sites
Herbmiester 945 Report post Posted March 6, 2024 (edited) Ok time to checks a few things with the Bimmersport experts. 👨💻 My car is fitted with a set of style 18s, 7.5 x 17 and 8.5 x 17. They are fitted with 235 45 17 tyres all round. Now I know the square vs staggered argument, and I am not keen to dredge it up here, however because I have rubbing on the front guards I am curious to know if going back to 225s up front and the installation of new bump stops might fix the rubbing. While I will probably replace the struts as well, I am curious if this might fix the rubbing issue? If you look at the image you can see the edge is where the contact is taking place. Edited March 6, 2024 by Herbmiester Quote Share this post Link to post Share on other sites
Vass 991 Report post Posted March 6, 2024 How severe is the rubbing? If it's just slight then going to 225's should be enough. 235 at the front does seem a bit excessive for a stock setup. The shocks must be well gone if it's bottoming out that easily. A suspension refresh is well worth taking on if you're planning on keeping the car for any decent length of time. 1 Quote Share this post Link to post Share on other sites
Herbmiester 945 Report post Posted March 6, 2024 The bump stops are well and truly dead, The front end, when bounced up and down settles very quickly, so there appears to be quite a bit of damping still there. But yes I should just replace them for piece of mind. Quote Share this post Link to post Share on other sites
Bruski 35 Report post Posted March 7, 2024 For the rubbing on the front guard, you can always cut out some of the plastic guard where it rubs. That stops the rubbing! Quote Share this post Link to post Share on other sites
Gaz 1067 Report post Posted March 7, 2024 Factory sizing is 225/45 and 245/40 so yes will cure the rubbing 1 Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted March 11, 2024 On 3/7/2024 at 5:13 AM, Gaz said: Factory sizing is 225/45 and 245/40 so yes will cure the rubbing yes and new shocks and bump stops , most z3 i see have worn out guard liners even when running correct tyre sizes but yes 235 wide is a no no on the front 1 Quote Share this post Link to post Share on other sites
