nath 176 Report post Posted April 3, 2024 My '98 B3 with B3/M3 420g transmission has a really bitey clutch engagement which you have to be good with, every-single-time you pull away lest the car stall or chirp. I see that M3 Evo's had a delay/lock 'valve' which seems to be just a flow restrictor. From most of what I read, this would provide a more smooth engagement for my Sunday morning café trips. Whole setup is new (probably 1000km) including dual mass flywheel. My question is, could a valve help, or is it just because I have aftermarket clutch and flywheel installed? Both are some version of OEM spec, as lazy/heavy as I could find. Thanks Nath Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted April 4, 2024 Sounds like a clutch\flywheel issue to me. Never had any issues like you describe with OE spec parts. Im running OE E36 M3 clutch\flywheel on my E46, its heavier and lower engagement point than stock but its just as smooth and easier to modulate with no CDV or self adjusting pressure plate. What is the setup you are running? Quote Share this post Link to post Share on other sites
M3AN 4144 Report post Posted April 4, 2024 I removed the CDV from my M3, much like every other owner has, and would never go back. A CDV means you can never be precisely sure when the clutch will fully engage which is disconcerting and ultimately more difficult to drive, especially on or near the limit. Removing it does however mean that the clutch is less forgiving but once you have the necessary muscle memory that shouldn't be an issue. Having said this, even without the CDV you still have some 'room', it's hardly a 3-puck race clutch. Quote Share this post Link to post Share on other sites
nath 176 Report post Posted April 4, 2024 16 hours ago, M3AN said: Removing it does however mean that the clutch is less forgiving but once you have the necessary muscle memory that shouldn't be an issue. Having said this, even without the CDV you still have some 'room', it's hardly a 3-puck race clutch. This reflects my experience. I just really don't drive my car like I stole it, or push out the revs. Perhaps the next owner may want to but I prefer the intrinsic aspects of the car, and replacing/fixing things which need it. She basically runs from her storage to my house and back once a week or fortnight with a coffee in between. I did take her to Coromandel a couple months back which was a painful drive in the end- should have taken the 'cruiser. Quote Share this post Link to post Share on other sites
wrs 120 Report post Posted April 5, 2024 (edited) I've got the S6S420G on a E36 with a 6.5kg single-mass flywheel and never had any restricter (and until now didn't even know it was an option). While I initially found it a bit more challenging and less forgiving than a typical manual (had been driving auto for years) it wasn't at all that bad. What I really like about the box/clutch combo is how easy it is to change when you do drive it like you stole it. At higher RPM (5000-7000) you can just smash it through the gears and it's reasonably forgiving to minor clutch timing errors. What I don't like about it is, if you're not driving it like you stole you it, you have to give gear changes just that little bit extra respect which means slower change times. I really want a DCT... Edited April 5, 2024 by wrs Quote Share this post Link to post Share on other sites
nath 176 Report post Posted January 2 I went ahead and ordered a CDV / lock valve and fitted it. No perceptible change, perhaps it’s just a heavy clutch. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted January 9 Which clutch and flywheel are you using? Quote Share this post Link to post Share on other sites
nath 176 Report post Posted January 9 Ok after driving it for a couple of days, it does seem more comfortable. It’s also worth saying that I don’t drive it like I stole it and keep within a low rev range. The clutch and flywheel are ‘oem equivalent’ DMF from Exedy. Same spec as for M3. Quote Share this post Link to post Share on other sites
