Toast 118 Report post Posted Friday at 12:02 PM I need someone who's in the know to give me their honest opinion on an issue i've got at idle, it's persistant and BMWorkshop haven't been able to diagnose it. Preferably someone who's owned a S50 series motor could chime in, maybe come for a drive and give an opinion? Cheers Quote Share this post Link to post Share on other sites
M3AN 4069 Report post Posted Friday at 10:29 PM What's the issue and what diagnostics have been undertaken to date? Quote Share this post Link to post Share on other sites
Toast 118 Report post Posted Sunday at 08:22 AM On 5/3/2025 at 10:29 AM, M3AN said: What's the issue and what diagnostics have been undertaken to date? sounds like a slight misfire every 10 seconds of idle, hasn't done it in the past, only at idle. Runs well, all coil packs test good, new spark plugs, BMWorkshop said nothing was amiss but commented that it's not a model they deal with regularly (then it was stored for 3 years). Back on the road again last week and after some new fuel, oil change and an Italian tune it seems to be mint other than this. Not sure if it's an "issue" or if I'm imagining things. Might pay to get the injectors flowed and cleaned? Quote Share this post Link to post Share on other sites
M3AN 4069 Report post Posted Sunday at 09:19 AM An injector service is cheap enough and with some miles under the belt always advisable but something every 10 seconds or so probably doesn't line up with an ignition cycle, I'd expect more frequent "misses". Have you done a DIS VANOS diag? What about a smoke test? These things, certainly as they get older, are prone to vacuum leaks. Also, never diagnose startup or idle issues until the SAP has done its thing, it creates all sort of bumps, lumps, and noises during warm up. Happy to listen to it, or plug it in, if you can drag it to Epsom at a suitable time. 1 Quote Share this post Link to post Share on other sites
