rjac001 0 Report post Posted November 30, 2011 Sorry your way offsuppose the only way to find out will be to do a diagnostic then run a few checks... funny cause I had a similar problem with my E30 same symptoms and it was just a loose lead, but guess I'm way off so it cant be that! Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted November 30, 2011 (edited) suppose the only way to find out will be to do a diagnostic then run a few checks... funny cause I had a similar problem with my E30 same symptoms and it was just a loose lead, but guess I'm way off so it cant be that! that may be the case, but the M5x engines are streaks ahead of anything found in an E30. M5x and later its just not worth messing around with trying to work out what went wrong when you can do a scan and it will tell you. Yes you can do that on an E30, but its not always true, and can tend to be conditional. That said, i wouldnt extend to saying you way off... thats just rude, particularly with no justification as to why. It could very well be that, or something along those lines. Im just saying a scan is the best way to find out Edited November 30, 2011 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted December 6, 2011 Hey guys can anyone tell me what spark plugs i should put in the 318i cheers! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 6, 2011 Hey guys can anyone tell me what spark plugs i should put in the 318i cheers! Bosch & NGK are the best brands Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted December 6, 2011 Cheers Glenn! Quote Share this post Link to post Share on other sites
jonomayo 0 Report post Posted December 6, 2011 hey guys, I've got an E36, 320i prefacelift, with abs issues. The abs light comes on intermittently, sometimes when i drive away, sometimes when i first brake, or sometimes not even at all. It has happened over the last few days, but most of the time if you turn the engine off and wait a bit it wont come back on until I next drive it. Any hints as to what it could be? Cheers Jonathan Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 7, 2011 hey guys, I've got an E36, 320i prefacelift, with abs issues. The abs light comes on intermittently, sometimes when i drive away, sometimes when i first brake, or sometimes not even at all. It has happened over the last few days, but most of the time if you turn the engine off and wait a bit it wont come back on until I next drive it. Any hints as to what it could be? Cheers Jonathan Possibly the control unit... a scan should give you the info needed Quote Share this post Link to post Share on other sites
thirdkide30 0 Report post Posted December 7, 2011 quick q. How do you install the break light switch? Mine is currently not on where its supposed to be. Had a manual conversion by Synthe Takanini and i think they couldnt get it on themselves too. Any fixes for this? E30 320i '88 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 7, 2011 (edited) Why cant they sort it out. If they put the pedal box in, it should be quite simple to sort out. It just screws into the bracket and you can adjust its position and lock it with the lock nut. Edited December 7, 2011 by *Glenn* Quote Share this post Link to post Share on other sites
thirdkide30 0 Report post Posted December 13, 2011 Im guessing they didnt put it back on cos it seems like the bracket is too small for the switch housing. I tried putting it on myself and it wont fit at all. Does the switch come apart? Right now its taped up into the hose and has to be adjusted everytime i drive so it touches the break pedal. There doesnt seem to be any locknut or screws on the bracket? any pics to help? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted December 13, 2011 Facelift is a small square plug which pushes into a square housing on the bracket, prick of a thing to get off and on. Pre f/l is the round one with a nut and adjustment, f/l has no adjustment apart from a small hammer. part 6 here is pre f/l http://www.realoem.com/bmw/showparts.do?mo...hg=35&fg=05 Can't find the square one on realoem but have certainly seen them on E30's. Quote Share this post Link to post Share on other sites
thirdkide30 0 Report post Posted December 13, 2011 (edited) Thanks Silver Fox. Yup mine is unfortunately the facelift square one. No bolt on it and is hella hard to put in the bracket. No easy fixes apart from tape by the sounds? Looks like this Brake light switch Edited December 13, 2011 by thirdkide30 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted December 13, 2011 Facelift is a small square plug which pushes into a square housing on the bracket, prick of a thing to get off and on. Pre f/l is the round one with a nut and adjustment, f/l has no adjustment apart from a small hammer. part 6 here is pre f/l http://www.realoem.com/bmw/showparts.do?mo...hg=35&fg=05 Can't find the square one on realoem but have certainly seen them on E30's. You can adjust the pedal height, which will adjust when the switch closes / opens. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted December 13, 2011 Thanks Silver Fox. Yup mine is unfortunately the facelift square one. No bolt on it and is hella hard to put in the bracket. No easy fixes apart from tape by the sounds? Looks like this Brake light switch ok, to fit this you need to pull the red bit out fully, then you can push it into its bracket. you the have to push the red bit back to where it is in the pic, this locks it in place. it's harder to get out as you have to pull the red bit out again. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 13, 2011 Can you take a pic of the bracket in the car without all the tape on it ? You might have p/fl bracket and f/l switch Quote Share this post Link to post Share on other sites
E36 M 9 Report post Posted December 14, 2011 In my 2004 e46 s/w when im driving up hills in 5th gear (tiptronic) it doesnt go anywhere at all, even the slightest hill, if im in fifth gear, i put my foot flat to the floor and the revs dont go anywhere, its as if the car is off, but once you click the accelerator into the button at the bottom, it instantly jumps down to third and redlines like crazy and then i have to put it into 4th, so now just dont bother driving in 5th gear. Any reason for this or is it not powerful enough to go up a hill in 5th? Haha Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 14, 2011 In my 2004 e46 s/w when im driving up hills in 5th gear (tiptronic) it doesnt go anywhere at all, even the slightest hill, if im in fifth gear, i put my foot flat to the floor and the revs dont go anywhere, its as if the car is off, but once you click the accelerator into the button at the bottom, it instantly jumps down to third and redlines like crazy and then i have to put it into 4th, so now just dont bother driving in 5th gear. Any reason for this or is it not powerful enough to go up a hill in 5th? Haha Call in tomorrow and I'll check it for you Marcus...please ring first though Quote Share this post Link to post Share on other sites
E36 M 9 Report post Posted December 14, 2011 Cheers Glenn, it's not bothering me too much so i will get it sorted some time in the new year which should suit us better. Will give you a call tomorrow to arrange a date sometime in jan Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted December 20, 2011 trying to diagnose my friend's 325i e36. it boggs down and loses power going uphill. its not misfiring going up hill just wont get the power and to rev up past 2.5k. but on the flat, and downhills no problem getting power and revs to go up. anyone have any idea on the cause? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 20, 2011 Be best to scan it and check live data while driving it and work from there Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted December 20, 2011 Hi guys, I have noticed since i have changed wheels that they are hitting the inside guard at high speed bumps and corners, i didn't have the problem on my old e36 (which they came off) I checked the shocks myself and they still seem to be ok but i noticed the rubber stop things at the top are very perished. Does this sound like new shock time or to replace those stops...which i think are number 18. Cheers muchly. Quote Share this post Link to post Share on other sites
jay^ 1 Report post Posted December 22, 2011 Hi team - seems like a stupid question but im having a hard time finding amber indicator bulbs for the front indicators (in the front bumbper) on my e30. They appear to need to be the dual contact type - repco only seems to sell clear and red bulbs not amber. Anyone able to point me in the right direction ? CHeers! Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 22, 2011 my two local repco stores both have them. maybe they are just out of stock? Supercheap local? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted December 22, 2011 try Segedins on Dominion Road if you're ever near central area lol, beats repco in service and price haha, even if its just a bulb Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted December 22, 2011 Hi guys, I have noticed since i have changed wheels that they are hitting the inside guard at high speed bumps and corners, i didn't have the problem on my old e36 (which they came off) I checked the shocks myself and they still seem to be ok but i noticed the rubber stop things at the top are very perished. Does this sound like new shock time or to replace those stops...which i think are number 18. Cheers muchly. If your car's not any lower than previously, those are bump stops, whoever your local auto dist. is should have replacements, although its a pain to put new ones in as as everything else needs to come out. Quote Share this post Link to post Share on other sites
