*Glenn* 856 Report post Posted May 23, 2011 Asking $500.. comes with M50B52 Vanos block as well as the M54 block Quote Share this post Link to post Share on other sites
HELLBM 1604 Report post Posted May 23, 2011 Great price Glen. Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 24, 2011 Is there any wear on anything that is worth mentioning? Long block or short? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted May 24, 2011 just buy it james. cheap as chips. i would have if i didnt just rebuild my 2.8. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 24, 2011 Is there any wear on anything that is worth mentioning? Long block or short? For $500 you get a second hand crankshaft, conrods & pistons with a 2nd hand engine block from a M54B30 with naturaly worn rings & bearings. The original motor apparently was overheated and the block was purchased knowing that. The 2nd hand M50B25 block also had a blown headgasket and I was using the block as a project mok up. If I was continuing with the project I would be polishing, measuring and replacing rings, bearings etc as my intention was to go from 84mm bore to 86.5 +50... thats another story though Quote Share this post Link to post Share on other sites
tire 10 Report post Posted May 24, 2011 (edited) <<<<< yes I totaly agree with that Max Edited May 24, 2011 by *Glenn* Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted May 31, 2011 Is there any wear on any of the bearing surfaces? Are the rods, pistons and crank in good condition? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 31, 2011 Is there any wear on any of the bearing surfaces? Are the rods, pistons and crank in good condition? You would need to use new rings and bearings... standard engineering practices Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 23, 2012 BUMP $400 Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted February 25, 2012 what would postage to palmy be? and what does it stroke it out to? my current project involves a m50b25 vanos Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 25, 2012 (edited) what would postage to palmy be? and what does it stroke it out to? my current project involves a m50b25 vanos You need to do your own maths and research. I'm only selling some engine parts and it's pick up only. I havent got time to frigg around wrapping , posting, or organising freight. BTW: The M54 block went out in alloy scrap. This lot will probably end up there too Edited February 25, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted February 25, 2012 You need to do your own maths and research. I'm only selling some engine parts and it's pick up only. I havent got time to frigg around wrapping , posting, or organising freight. BTW: The M54 block went out in alloy scrap. This lot will probably end up there too Check your inbox Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted February 25, 2012 Check your inbox M50b30 turbo? Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted February 25, 2012 M50b30 turbo? We'll see Quote Share this post Link to post Share on other sites
