BM WORLD 1293 Report post Posted October 5, 2013 (edited) selling my bmw v8 engine from my nz new 1995 540i touring if anyone is after a good loiw millage nz new engine http://www.trademe.co.nz/Browse/Listing.aspx?id=647307624&ed=true $1400 to you guys 021433600 papakura also have the matching 5 speed auto trans $1000 http://www.trademe.co.nz/Browse/Listing.aspx?id=647309748&ed=true make a great package for a e30 e28 e24 etc Edited October 5, 2013 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 6, 2013 This would look nice in a 3 series. Quote Share this post Link to post Share on other sites
jeffbebe 1560 Report post Posted October 6, 2013 what's going to replace it, Brent? Quote Share this post Link to post Share on other sites
lord_jagganath 421 Report post Posted October 6, 2013 M62B44. gosh I would love this engine to go into the touring .... but mountings.... :sigh: 1 Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted October 6, 2013 He has exp to do this engine replace.manual touring is coming Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted October 6, 2013 yup just a M62B44 and 6spd to go in its place. and yes the m60 will mount up in your 525i touring , will need a few other parts to make it all go , but nothing is impossible Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 6, 2013 yup just a M62B44 and 6spd to go in its place. and yes the m60 will mount up in your 525i touring , will need a few other parts to make it all go , but nothing is impossible Thats the spirit. M62 E34 Touring will be a real package Brent! Would this require a cert? Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted October 6, 2013 Thats the spirit. M62 E34 Touring will be a real package Brent! Would this require a cert? i dont think so , looks stock , and only a small increase in cc's Quote Share this post Link to post Share on other sites
jeffbebe 1560 Report post Posted October 6, 2013 yup just a M62B44 and 6spd to go in its place. and yes the m60 will mount up in your 525i touring , will need a few other parts to make it all go , but nothing is impossible Very nice! Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted October 9, 2013 (edited) some more pics Edited October 9, 2013 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
robert.fowler 0 Report post Posted October 9, 2013 will still need cert as not the original engine or trans Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted October 28, 2013 bump , out of the car now ready to go if anyone wants nice low km nz new V8 . Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 29, 2013 (edited) will still need cert as not the original engine or trans LVV Certification is always required for any engine or drive-train-related modifications unless specified below: (if modification does not appear below, always refer to LVV Certifier) Fitting of or modification to: LVV Certification is not required provided that: (refer to LVV Certifier if beyond threshold below) Substitution of engines When compared with the OE engine, the replacement engine: is of the same or less cubic capacity; and has equal or less weight; and has the same or less power output; and uses the same fuel (petrol, diesel, LPG, CNG); and uses the same unmodified attachment points and system (ie bolts-in); and uses the same family of block and cylinder head from the same vehicle manufacturer; and is of the same configuration. Reckon you'd need to have a trainspotter of a WoF inspector to pick up the difference between the B40 & B42! But yes, technically it should be certified However if the vehicle has been converted from auto to manual using ONLY OEM parts and with no modification to the car it does not require certification. I had a good long chat with the certifier the father-in-law uses before commencing on the 325i conversion. Better safe than failed! Edited October 29, 2013 by Ahmedsinc Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted November 25, 2013 BUMP!! engine and trans is ready to go Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted November 27, 2013 ok,I knew it now. LVV Certification is always required for any engine or drive-train-related modifications unless specified below: (if modification does not appear below, always refer to LVV Certifier) Fitting of or modification to: LVV Certification is not required provided that: (refer to LVV Certifier if beyond threshold below) Substitution of engines When compared with the OE engine, the replacement engine: is of the same or less cubic capacity; and has equal or less weight; and has the same or less power output; and uses the same fuel (petrol, diesel, LPG, CNG); and uses the same unmodified attachment points and system (ie bolts-in); and uses the same family of block and cylinder head from the same vehicle manufacturer; and is of the same configuration. Reckon you'd need to have a trainspotter of a WoF inspector to pick up the difference between the B40 & B42! But yes, technically it should be certified However if the vehicle has been converted from auto to manual using ONLY OEM parts and with no modification to the car it does not require certification. I had a good long chat with the certifier the father-in-law uses before commencing on the 325i conversion. Better safe than failed! Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted November 27, 2013 is it m60 has better intake manifold?? Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted November 27, 2013 (edited) is it m60 has better intake manifold?? same as early m62 non vanos engine. but yes will flow more at high rpm than the vanos m62 Edited November 27, 2013 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted December 18, 2013 bump anyone want a nice new low km m60b40 v8 engine and trans?? Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted December 18, 2013 Damnit Brent if only i had the cash right now i'd be throwing that in the touring. Got stung with some hefty fines/charges after some spirited bike riding... If you still have the engine and trans in March look me up. Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted December 18, 2013 Looking for e30 325 manual facelift, coupe or sedan. Quote Share this post Link to post Share on other sites
