international 0 Report post Posted September 15, 2007 On my Auto E36 there is the usual P R N D 3- holds to a maximum of 3rd gear 2- holds to a maximum of 2nd gear 1 -holds at 1st gear Can you drive it like a tiptronic by switching between 1, 2 and 3 gears? If I do...would I damage the transmission system? Quite unsure about his dont know if anyone can enlighten me on this... Quote Share this post Link to post Share on other sites
ThreeOneEight 0 Report post Posted September 15, 2007 Just buy a manual! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted September 15, 2007 You can. The actual shifting will be no different than if you let it change by itself. However, the thing is you will probably hold gears longer and thus shift harder than usual so on that basis it will see your auto lasting all of 5 minutes. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted September 15, 2007 switch the auto switch to M for manual . then it holds it in gears even if you take off in 3rd it wont change down . but just buy a manual or convert yours far better . tiptronic is only a marketing thing to try and sell auto's . Quote Share this post Link to post Share on other sites
international 0 Report post Posted September 16, 2007 You can. The actual shifting will be no different than if you let it change by itself. However, the thing is you will probably hold gears longer and thus shift harder than usual so on that basis it will see your auto lasting all of 5 minutes. Thats what Ive been doing...so far its been alright...on D is drives just as fine as before...I do find it quite useful at times...far more effective than the Sport Switch... Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted September 16, 2007 (edited) Auto's are good for learning to keep the car balanced through corners, with the foot brake. Edit: The auto box, spat the dummy at me, after a while. But considering what i was able to achieve, it was worth the cost of the manual conversion. Edited September 16, 2007 by bumpstop325 Quote Share this post Link to post Share on other sites
e30kingpin 0 Report post Posted September 17, 2007 Are they for engine breaking more than anything? instead of having your foot on the breaks down a long hill overheating your disks? (the few times I have ever driven an auto thats all iv ever used it for) Quote Share this post Link to post Share on other sites
Old_Skool_Bmw 0 Report post Posted September 17, 2007 i drove my old 325i auto like a manual for a day.. until the auto fluid started to overheat and i almost blew up on me . better to get a manual conversion i say auto's are too boring for me. Laurence. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted September 17, 2007 Are they for engine breaking more than anything? instead of having your foot on the breaks down a long hill overheating your disks? (the few times I have ever driven an auto thats all iv ever used it for) Brakes are for stopping - engine are for going forward. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted September 17, 2007 Unless you are towing. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 17, 2007 im shaking my head at some of the anwsers in this thread... Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 17, 2007 (edited) Brakes are for stopping - engine are for going forward.That is so god damn true on the trackAs per above, I drove my old auto like that for years that when I had it, it's just fluid on the inside Used to love flicking it into 1 at 100kph and listening to it go mental on the engine bracking - I drive the manual considerably nicer than I did the auto but I think that's more because the slushbox was boring but it was definitely built like a rock solid shithouse. Edited September 17, 2007 by Carl Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted September 17, 2007 Ouch Carl! At 100kph the torque converter is locked (ie solid link, not fluid) so (and I'm surprised it let it change) when the box changed you would've been chewing all holy hell out of the clutches inside the box, not to mention the strain on everything else. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 17, 2007 It would chop down to 2nd then into 1st around 80kph and was a whole lotta fun Quote Share this post Link to post Share on other sites
international 0 Report post Posted September 17, 2007 It would chop down to 2nd then into 1st around 80kph and was a whole lotta fun I usually cruise at 2nd gear which gives me about 3000RPM just over 50Km/h...so I still have some room to boost up to 5500RPM before I change to 3rd gear by which then I would be about 80Km/h I dont really change the gear that much...usually on sport shift and second gear...it holds 1st gear to max then changing to second...worked well as sport shift also shifted down on higher RPMs... Its good when I sense a yellow light coming....BANG on the yellow light is on, switch from D to 2nd gear, boost it...the engine sound is just...aww too sensational! Quote Share this post Link to post Share on other sites
international 0 Report post Posted September 17, 2007 i drove my old 325i auto like a manual for a day.. until the auto fluid started to overheat and i almost blew up on me . better to get a manual conversion i say auto's are too boring for me. Laurence. What kind of way were you actually driving it like? where you also down shifting constantly? How did you know it was overheating? Quote Share this post Link to post Share on other sites
Old_Skool_Bmw 0 Report post Posted September 17, 2007 haha yeah i was downshifting heaps driving it pretty hard!! Um i could tell it was overheating with it started to smoke from under the car haha.. but i guess the car had also done over 300,000kms.. Laurence. Quote Share this post Link to post Share on other sites
Old_Skool_Bmw 0 Report post Posted September 17, 2007 sounds to me like you need to get youself a manual!!!! + they are a heap more fun (i just find auto's too boring after buying the e30 M3). Laurence Quote Share this post Link to post Share on other sites
