Jamez
e30 325i 1988
Update
No pics till tomorrow night
Today I;
  • Swapped Bumper/Boot over
  • Removed Dash's from both cars
  • Put a front windscreen in
  • put back seats in
  • took pods off the 325i to send to Frantic
  • put a fuel pump in
  • started to remove pedals for the swap to manual
  • put on taillights
Total Time 5hrs
TO DO Tomorrow;
  • Swap Pedals Over
  • put dash in
  • Finish off putting windscreen in (the rubber inlay bit)
  • put on front guards
  • put headlights and front bumper on
  • swap driver seats over
  • get rid of automatic gear changer
  • Prep for engine swap
TO DO Monday
  • Get Engine and gearbox out of 325i
  • Put brake booster in 320i
TO DO Tuesday
  • Put Engine and Gearbox in 320i
  • Swap Rims and rear sway bar over
TO DO Wednesday
  • Anything that gets forgoton
  • swap Diff's
  • go get quote on re-spray
TO DO Thursday
  • Get a WOF and REGO. If not being painted, otherwise Friday
TO DO Saturday
Go on Anzac cruise.
James
Edited by Jamez
keep hitting dead ends :(
how do i get the break and clutch pedal out without taking off the accelirator, from what i can see its welded on
how do i get he front tech2 kit off? the plastic clips at the bottom are proving very stubborn
this is turning into alot of work :(
will probly not have it ready in time for the Anzac cruise at the rate im going :(
Not what that attitude lol... get back in the garage! :P
There is a long bolt that runs through the brake clutch pedal, just unclip the accelerator pedal (behind the pedal) there should be no welding, they come out in about 5 minutes. Just undo all the bolts and slid out the long one and they come free.
Update
didn't have much time today to work on the car as i had to go out to breakfast with the girlfriend then helped her move house
not much done to the 320i
got all the tech2 off the 325i
will have all panels on the 320i by 9am tomorrow.
the engine is pretty much ready to lift out, so might be in and going by tomorrow night, at this point in time I can see myself being ready by the Anzac cruise, help permitting :unsure: .
took some pics but it was pretty dark, so no good ones, will make sure i take some goodin's tomorrow.
so stoked im swapping all the bits over, the 325i is a rust bomb, the whole car is rust and has bog EVERYWHERE. it would of never complied. on the otherhand the 320i is immaculate :)
and for reference, the 320 is the car with no steering wheel on the left and the steering wheel in the 325i someone can have if they help :) ( its pretty worn tho)
pretty much if you help me you can take bits off the 4door :)
and can someone please please swap the pedals for me :) ill give you a door as a memento :P , i just cant do it. I HATE THEM
Edited by Jamez
OMFG! how do you get anything done? You must be forever losing things and falling over stuff.
Pedals are simple. Remove the hinge pin, swap the pedals over. Done.
Haha yeah you messy bastard :P
haha all that junk goes out onto the driveway each day so i have working space :)
zzzzzzz i must be thick or something, everyone says its easy but i keep missing the boat :(
will give it another go first thing tomorrow morning.
Edited by Jamez
Update:
finally swaped the pedals over
got the dash back in
and pt some panals on
Tomorrow is the day when everything is going to happen, as it wont be a one man team anymore more like 2 so thing should happen alot faster
all that's left to do is
  • put some front seats in
  • put the engine/gearbox in
  • put the Tech2 kit on/fixed
  • get it paint'd
Sweet - the trick with a 2-man team is no beers till the work is done. Or else you end up with lots of empties and no work done.
UPDATE
engine in but not wanting to start........
made a thread for helping me............ Linky
Update
CAR GOING WOOT WOOTT OWTOWTOOWTw
stuff still too doo
  • Put front seats in
  • Put Mtech2 kit on
  • Change front and rear sway bars
  • Change front and rear springs, its riding so hight currently
  • Change diff
  • Put Exhaust on
  • Finish of Wiring, cover it all in tape so it looks nice :)
  • Bleed the Clutch
  • Give it a good clean
Update
decided to let the breather for the fuel tank just sit and do nothing
Car is go
befor i get a WOF and active the REGO I will have to
  • mount the front Tech2 valence properly
  • fix and mount the rear bumper
  • put brake light switch on the pedal
and after that i'll do the small things before the Anzac cruise like..
  • swap over sway bars and suspension
  • swap over diff
  • ect....
not going to have time for the car to get painted :( so it will look pretty rough on the cruise........
Cool - feral e30 > tidy e30 anyway.
All e30s are feral.
Some just have shiney paint.
And resize your pictures man!
Really? They're still huge!
Anyway, hows it drive?
havent taken it out for a drive
got no petrol lol, and still have to mount front bumper, then i'll get a WOF :)
k so i got a WOF and REGO today :)
so it will be going on the cruise
will get some pics on the cruise :)
