Forrest 35 Report post Posted May 3, 2009 (edited) ^ Thats true mate, but can get a m42 or a m50 for about the same price, its just I would need another gearbox if I went the m50 route, because mine is the 4 cylinder g240 not the 6 Edit: ^ Ignore my retard post Edited May 3, 2009 by Forrest Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted May 3, 2009 wont this mean that the gearbox is twisted back 10degrees though, so a custom tranny mount should be used? As has already been said in this thread, the 240 from an M40 will fit fine behind an M50, better so than the 240 from the M20, as this will have the wrong angle. 320guy just modified the normal transmission mount. And his shifter is on a bit of an angle, but it's nothing serious. Still totally useable. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted May 3, 2009 Thats wrong. I got my getrag240 from a 320i and it's now sitting behind a m20 stroker. All m20' blocks are the same so of course the bellhousing is the same. Shifter linkage would go by year, early models use steel plate shifter design, later ones changed.. I didn't say a m20b20 240 would not fit behind another m20.. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 3, 2009 As I said, m20, m40, m42, m44, m50, m52, s50 etc all use the same bellhousing. This is not quite right. They share the same basic bolt pattern with the exception being the m20 is on a different angle. Just as Mike says. It doesn't stop the m20 boxes being used with modified crossmember. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 3, 2009 I didn't say a m20b20 240 would not fit behind another m20.. 3rd line you said "Then there is the g240/5 fitted to the 320i which, according to this book has another different bellhousing which prevents it from being interchanged." Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted May 3, 2009 3rd line you said "Then there is the g240/5 fitted to the 320i which, according to this book has another different bellhousing which prevents it from being interchanged." Reading it in context with the above bits, it prevents it being interchanged with the M10 and M40 engines, which is correct. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 4, 2009 Reading it in context with the above bits, it prevents it being interchanged with the M10 and M40 engines, which is correct. Oh, My bad Quote Share this post Link to post Share on other sites
tire 10 Report post Posted May 5, 2009 What foxy said This is a very valuable thread I've book marked it. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted May 5, 2009 I didn't read the whole post - it was long, so forgive me if I repeat something. It appears the M40/M50/M20 all share the same gearbox bolt holes. The gearboxes sit on different angles. M10/S14/M30 share another pattern. I have used a Getrag 260 from a m20b25 to the turbo m42 (318iS e30). We cut the front off the bellhousing, rotated the gearbox round to the right place. Works like a champion on a 300hp car. Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted May 6, 2009 Have you ever thought about an m30b35 conversion? its prity cheap power Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted May 6, 2009 M30B35 would be mint. Have you taken your 316i for a serious thrash yet though? It's mint. Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted May 6, 2009 Have you ever thought about an m30b35 conversion? its prity cheap power I hear to put a m30 in a e30 you gotta smash the firewall in to get it to fit. The weight of a m30 would f**k the handling on a e30 as well. My mate with an m50 in it even says you can notice the difference between it and the old m20 when it comes to handling. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted May 6, 2009 M30's only 26kg heavier than the m20. you don't have to touch the firewall at all if you don't want to. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted May 6, 2009 ^^^ just put it in the boot e30's are know to be a bit light in the back Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 6, 2009 Why drift off into m30 territory, Thats a whole different gearbox needed there.. And more to be had with a 24V motor than an old m30. Not that there is anything wrong with an m30, Very strong motors.. m50+ much more economical. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted May 6, 2009 Yeah m30 is a pretty ancient motor. I plan on skipping any other 'e30' motor and going to a 'early' e36 motor. Ideally want to do non vanos m50 with a turbo..essentially the same motor as boostjunky's...ay Luke Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted May 6, 2009 (edited) Yeah m30 is a pretty ancient motor. I plan on skipping any other 'e30' motor and going to a 'early' e36 motor. Ideally want to do non vanos m50 with a turbo..essentially the same motor as boostjunky's...ay Luke better to use early M50 2.5 non vanos as they are a cast iron block ,and less complicated with out the vanos.and fit a 2.8L crank if you want more CC (and maybe bore out to 3L while you are at it) Edited May 6, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 6, 2009 All m50s are cast iron are they not? And why the obsession with non vanos? Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted May 6, 2009 All m50s are cast iron are they not? And why the obsession with non vanos? yes m50 are all cast iron , m52 are ali i hear its better not to have vanos when doing turbo setups Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 6, 2009 Yeah, Vanos harder to tune. More to go wrong. And possibly strength of the heads too maybe? Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted May 6, 2009 From what i understand the vanos m50's have an alloy block. Also the non-vanos have double valve springs, which the vanos dont have, so if you wanna rev the nuts off it.. go non-vanos. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 6, 2009 Yeah m30 is a pretty ancient motor. I plan on skipping any other 'e30' motor and going to a 'early' e36 motor. Ideally want to do non vanos m50 with a turbo..essentially the same motor as boostjunky's...ay Luke Why go turbo ? more goes wrong with turbo set ups. I'd go M52B28 + SC if it was me with no tuning issues...just a remap and spend more money on suspension, brakes & certification 1 Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted May 7, 2009 All m50s are cast iron are they not? And why the obsession with non vanos? Valves are larger are they not? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 7, 2009 From what i understand the vanos m50's have an alloy block. No. And both m50/m50tu are good for approx 7000rpm as I understand it. Pretty high for a street engine. Valves are larger are they not? No idea. Quote Share this post Link to post Share on other sites
