*Glenn* 856 Report post Posted October 29, 2009 cheers mate, and yep the clutch slip is fixed, just bleed it up again an no worries. Pretty happy with the whole thing to be honest. Hurry up cert plate! itching to go for a real drive You are legaly allowed to drive with the documentation... just make sure you have it in the car Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 29, 2009 Badass Congrates Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted October 29, 2009 You are legaly allowed to drive with the documentation... just make sure you have it in the car Really? so if i have my W.O.F sheet and my cert sheet i should be fine? my rego is overdue though...(cant renew until i get wof) Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted October 29, 2009 Awesome. Good stuff. Please post another vid Quote Share this post Link to post Share on other sites
karimMSalama 0 Report post Posted November 9, 2009 very good i see smoe other E30 V8 at BMW E30 CARS Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 9, 2009 Really? so if i have my W.O.F sheet and my cert sheet i should be fine? my rego is overdue though...(cant renew until i get wof) You can drive with your cert documentation... but you must have a WOF & Rego Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted January 22, 2010 Well long time since i have made an update. To be honest got a bit sick of the whole thing and had to give it a break. The motor had a run bearing which ment the motor had to come out and swapped it for a lower k one out of an e39, which ment i had to swap all the intake, water pumps, wiring looms, etc over onto the e39 block to get it to work. So while it was out it gave me some good time to do some tidying up of the plumbing, heat wrap the headers, paint the sump and give the new motor a really good clean and pollish inside and out. Upon putting the motor back in i made up some nolathane engine mounts which were 5mm shorter than the e30 ones i was using which gives me more clearance between the top of the engine cover and the bonnet. I also had all the injectors cleaned and new plugs and coils checked which all turned out fine. Got the motor back in and somehow an 02 sensor wire was ripped which shorted it out which then melted the wire right up to the ECU, so made a new wire for it and then it was always missfiring and farting around. Anyways took it to my mate at bmw and he plugged it in and spent a long time checking all the systems were working and trying to diagnose the problem, turns out it has burnt the earth track in the ECU for the o2 sensors, FFS. New ECU is arriving on monday to be fitted and back to BMW to reflash it to manuel and ill be away! Things are finally looking up, its an absolute weapon to drive, the new motor has much more go than the old one did. When i get the new ecu i will make a few videos, but in the mean time i have some average photos of just the exterior for you guys. Henry is going to help me take some awesome ones! haha thanks mate Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted January 22, 2010 Awesome!! Yes, I still want it! Im admiring your dedication, ten points for staying on top of it Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 22, 2010 total shame you run a bearing man, but hay new motor is always good. good on ya for keeping it alive Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted January 24, 2010 I sure can help, still waiting on a nice day here in shitschurch.. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted January 24, 2010 Sweet to hear it still lives Sammy. So you've swapped in a 4.4L? And aside from changing loom, waterpumps, etc there are no issues with the gearbox? Mates up ok still? Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted January 25, 2010 Awesome effort Sammy... can't WAIT to see this thing in action Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted January 25, 2010 From my reseach it appears it is possible to mate the e39 6speed to an m60 with minimal issues and its all meant to be bolt in. I'd say the same vice versa. Will be in touch Sam as have some questions. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted January 25, 2010 From my reseach it appears it is possible to mate the e39 6speed to an m60 with minimal issues and its all meant to be bolt in. I'd say the same vice versa. Will be in touch Sam as have some questions. Ian I read your comment as - an E39 manual gearbox, to mate up to M60B40 from E34? Correct? I'm asking from the angle of chucking a M60B44 (4.4L from E39) into mine Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted January 25, 2010 From my reseach it appears it is possible to mate the e39 6speed to an m60 with minimal issues and its all meant to be bolt in. I'd say the same vice versa. Will be in touch Sam as have some questions. Ian I read your comment as - an E39 manual gearbox, to mate up to M60B40 from E34? Correct? I'm asking from the angle of chucking a M60B44 (4.4L from E39) into mine yes all m60/ m62 n62 engines have same bellhousing etc . so yes 6spd e39 box onto a e34 , e39 m60 engine . or M62 4.4L into a e34 540i 6spd etc . i have a spare 4.4L was saving for a rainy day project like that Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted January 25, 2010 Ian I read your comment as - an E39 manual gearbox, to mate up to M60B40 from E34? Correct? I'm asking from the angle of chucking a M60B44 (4.4L from E39) into mine Awesome. From what i've read it's a matter of reflashing the ECU (like Sam's doing) to manual and you're away. Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted January 26, 2010 Nah I swapped in a 4l out of an e39 because I wasn't sure about the ecu's and wiring etc. But when I was doing my research either gearbox will fit onto either motor. Sure mate feel free to pm me. Quote Share this post Link to post Share on other sites
