Andre3000 55 Report post Posted June 3, 2009 Need an m52 crank for my 2.8L stroker project. Anyone got one? Also on another topic, wtf can i buy a dbilas itb system? I cant translate their website and it seems you cannot buy from their website directly. Grrrrrrr Quote Share this post Link to post Share on other sites
isis 16 Report post Posted June 3, 2009 dbilas ? lol! how much dosh are you willing to fork out for one of those? they're aren't cheap... Quote Share this post Link to post Share on other sites
Jeddy 0 Report post Posted June 3, 2009 (edited) This what your after: http://www.dbilas.com/img/db10010006.jpg? English: http://www.dbilas.com/dbilas_eng/index.htm Edited June 3, 2009 by jeddy Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted June 3, 2009 Have 2.8 cranks. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted June 3, 2009 dbilas ? lol! how much dosh are you willing to fork out for one of those? they're aren't cheap... No sh*t sherlock This what your after: http://www.dbilas.com/img/db10010006.jpg? Yup thats the one. Have 2.8 cranks. Thanks ray, will give you a call tomorrow Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted June 3, 2009 http://www.trademe.co.nz/Trade-Me-Motors/C...n-222259274.htm Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted June 4, 2009 Thanks for that Brent. Damn Autobid. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted June 4, 2009 Do you know whats involved with using the m52 crank? IMO bore out an m20b27 ETA block to 85mm so you can use +1mm oversized custom pistons, gets you to 2.8L for much cheaper.. That way you don't have to do heaps of crank work to make it fit (it's not a direct fit into the m20 block). Also with custom pistons you could have valve reliefs cut into them to make the engine non-intference if you ever break a timing belt... And choose your own compression ratio, as in get high ratio ones if it's gonna b Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted June 4, 2009 http://www.msportster.co.uk/detail.asp?cat=22&offset=48 Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted June 4, 2009 it's gonna cost you the same, get the whole engine? well maybe not the same.. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted June 4, 2009 Do you know whats involved with using the m52 crank? IMO bore out an m20b27 ETA block to 85mm so you can use +1mm oversized custom pistons, gets you to 2.8L for much cheaper.. That way you don't have to do heaps of crank work to make it fit (it's not a direct fit into the m20 block). Also with custom pistons you could have valve reliefs cut into them to make the engine non-intference if you ever break a timing belt... And choose your own compression ratio, as in get high ratio ones if it's gonna b I heard about this crank swap as an alternative to the 2.7l ETA bottom end on Sunday. Was told that the swap was relatively simple, with a couple of small turning jobs to do on the ends of the crank (which the web link seems to back up). Am I missing something else?Surely custom oversized pistons are going to be big $$$s unless you can find a stock size out of another motor? Not that I'm an expert... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 4, 2009 Its best to go with bigger valves as well and a good cylinder head porting job. ++++ $$$$$ Quote Share this post Link to post Share on other sites
