Lucan
Lucan's 1989 325i Sedan
Nice bro, I have a bottom end if you are planning on rebuilding it anyway. Has pretty decent compression too. Just could do with new seals and bearings etc, which you will be doing anyway.
Car-wash B)
Need to learn how to use my camera betterer...
still looks mint never the less my friend
lookin good bro. ll be keen to snap of few pics sometime .not a pro though !
Kean on 4door E30 shoot :P
In the next week or so?
Got to start tearing it apart after next weekend ^_^
yea keen !!
mash is keen as well , we should arrange it :)
yea keen !!
keen, got to get my sh*t together tho.
Oh snap Matt too, need to wind down the coilovers so I don't look like a 4x4.
dont so i dont look out of place LOL! :lol:
Do this. Please
It'll be sweet.
Need to find a decent spot, with good lighting, and back drop.
Can i join ? i need some good photos. Ha Blender
Edited by APT
Started doing this.
Advice on a good product to remove the glue?
Any strong solvent to soften it up then water blast it off.
^ As per Polley's advice in a thread I had, I used spray degreaser and a water blaster.
Buy CRC or similar degreaser, the $3 a can supercheap stuff doesn't work really - go figure.
Spray then let soak in, then nuke it with the waterblaster, use a paint scraper/putty knife to help peel the glue off, then repeat, then once the glue is thin enough the rest can be wiped off with meths.
Takes a while but the result is good, just be careful about shooting the waterblaster on edges/loose paint because it will blow off easy as.
Edited by Brams
I used engine start on mine. It waterblasted right off, needed no cleaning afterwards.
Desolvit and a scraper. Works mint. Or a heatgun.
Wax and grease remover (prepsol or supercheap stuff), and a rag. Won't take much time, or too much effort. And no powertools required. (That sorta job is what this sh*t is made for!!!)
Only have CRC here atm so soaked it and will leave that over night.
Will pick up the heat gun and everything else mentioned and go to town on the bisch tomorrow.
Bored thread update!
Well since I last posted here I've done a couple of cosmetic things.
Stripped the crap foam from my bonnet, painted the underside cosmo to match the car, new insulation and decorated a panel B)
Removed and painted my intake manifold satin black.
Wired in some foot well lights
And today I did my S/S braided lines up front and drilled front rotors :D
Still to do the other 4 lines. Sighh.
Also found out my rear passenger window will go down but doesn't want to go back up <_<
haha is that pedobear?
