charles28 141 Report post Posted December 24, 2009 Mmm now this is what I want.. http://www.trademe.co.nz/Trade-Me-Motors/C...n-261806876.htm Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted December 24, 2009 I just saw that, was going to make a thread about it too. Quote Share this post Link to post Share on other sites
charles28 141 Report post Posted December 24, 2009 I just saw that, was going to make a thread about it too. Great minds think alike and so do ours lol Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted December 24, 2009 I think by reading between the lines its running on the standard ECU... Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted December 24, 2009 PFL tail lights + Tech 2 looks sweet! Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 24, 2009 It's not certed either, price does reflect that I think. Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted December 24, 2009 I like it, just don't like the exterior. So want to do something like that with an M20 though. Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted December 24, 2009 I am completely unimpressed by it. I would have expected something with a lot more power. Be still, my beating heart, a whopping 140 - 150kw at the wheels.... Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 24, 2009 I think it really needs a new ECU, then it's potential could be untapped. alllthough a non-turbo M20B25 gets around 100kW ATW so 50kW gain isn't too bad then I suppose. think of the torque Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted December 24, 2009 Abit optimistic with that 150rwkw figure. Esp with that turbo, Un-tuned and running on a standard ECU.. Some guys have managed to get it going right though, using standard ECU's and rrfpr. 8psi is about as high as you would wanna go though. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted December 25, 2009 I'm sure that car used to belong to a member way back who actually did the turbo. if so it was actually running LEM. I cant think why someone would remove it, so its probably still there along withe bigger injectors and fuel reg. Car has probably been through a few hands since the guy who built it so people wont be exactly sure on what they have Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted December 25, 2009 Needs some work but has potencial, not my cup of tea though Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted December 25, 2009 3.5mm custom gasket.. Wouldn't that make it completely dead gutless until the turbo kicks in? Quote Share this post Link to post Share on other sites
Driftit 2187 Report post Posted December 25, 2009 3.5mm custom gasket.. Wouldn't that make it completely dead gutless until the turbo kicks in? Yep. Must have a very low comp ratio with head gasket that thick. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted December 25, 2009 (edited) Not really. I ran a 0.120" thick headgasket which is 3mm thick. Dropped CR in my 2.7 from 9.5:1 to 8.8:1. Didn't even notice a difference in power when not in boost.. 3.5mm is the 0.140" headgasket. Can't remember what the stock 2.5i CR is but it's more than 9.5:1 i think, So it would only drop to 8.5:1ish or something. Edited December 25, 2009 by e30ftw Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 25, 2009 AFM on the pressure side and stock intake boot - can't imagine how well that works. Intake boot should blow up like a balloon with very little boost, and AFM not designed to read airflow when it's under pressure (ie denser than atmosphere). I'd be interested to see how they got it running, and what sort of ecu it has. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted December 25, 2009 Same here on what ECU is being used... Just noticed that AFM position too.. Should be put before the turbo so the flap still reacts to air being sucked though and not blown straight through it. I've heard of the stock boot handling up to 10psi but i wouldn't trust it. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 26, 2009 (edited) AFM on the pressure side and stock intake boot - can't imagine how well that works. Intake boot should blow up like a balloon with very little boost, and AFM not designed to read airflow when it's under pressure (ie denser than atmosphere). Thats what I said about it when the owner was showing it off in here a while ago (if its the same car). Not a good set up to work properly at all Edited December 26, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
