NA325i 0 Report post Posted January 8, 2010 does anyone know if the e30 heater system is just crap and will only ever give tepered heatage, or is mine just bung? if so what is the remedy? Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted January 8, 2010 engine might be running too cold? I have always found mine to give a good heat Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted January 8, 2010 Has the engine been removed recently? The pipes that go to the heater core may have been put together the wrong way around. Quote Share this post Link to post Share on other sites
isis 16 Report post Posted January 8, 2010 mine works way better than the one in the E36 - what the hell are you using the heater in summer anyways? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 8, 2010 Yep, with everything working correctly - the system is very efficient. You must have a problem. As above - engine temperature. Pipe connections shouldn't matter as water will still flow through heater core regardless. Also may have faulty heater valve. Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 9, 2010 engine might be running too cold? I have always found mine to give a good heatthis was the reason why the heater in my e36 was rubbishthermostat wasn't working properly, so engine wasn't heating up properly now it's mint as, the engine warms up nice and quick and I stay toasty warm in the winter Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 9, 2010 i havent had a lot of cars bu the heater in the e34 is the heater from hell.....it warms up very quickly cos of the aux water pump and if you want it can REALLY crank up the heat....sometimes it decided to on its own! Quote Share this post Link to post Share on other sites
westy 614 Report post Posted January 9, 2010 The heater I pulled out of Alice (E30) would almost burn ya feet! Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 9, 2010 Antil33t had this problem just last week and I told him change his firewall pipes around and it fixed it. (He had just swapped in the m20b25). Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted January 9, 2010 Do as he sais. It's a reallly easy mistake to make. Quote Share this post Link to post Share on other sites
NA325i 0 Report post Posted January 13, 2010 thanks 4 the help guys. the cluth cable went on the way home today so ill get it all checked at the same time. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 13, 2010 They are hydraulic. There are no clutch cables with e30's. Probably blew the slave cylinder seal? Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted January 13, 2010 Pipe connections shouldn't matter as water will still flow through heater core regardless.I dont know why, and Id love to find out why, but it does make a difference. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 13, 2010 My guess is that one pipe comes out of the back of the head (hot obviously), and the other comes from a longer pipe from the thermostat housing / expansion bottle.. My guess is that the water has probably just come from the radiator or something, where as it should pass through directly from the back of the head, through the core etc that way. Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted January 13, 2010 My heater is all good. Once engine is warm, it definitely warms the car up if you turn it on. Even on "1" you can feel it but on 4 (or is it 5?) you aint gonna complain. Quote Share this post Link to post Share on other sites
NA325i 0 Report post Posted January 17, 2010 yeah it wasnt the non existant cable haha. it was the rod in the master cylinder. anyone know of that breaking before? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 17, 2010 Yeah I had that happen a few times to me. Quote Share this post Link to post Share on other sites
