BM WORLD 1298 Report post Posted October 7, 2010 just a quick update , got the engine in the car , today , just waiting for some new exhaust nuts , should be able to fire it up soonish Quote Share this post Link to post Share on other sites
tire 10 Report post Posted October 7, 2010 Good news. Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted October 7, 2010 Good stuff. See you at Hampton sometime Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted October 7, 2010 Looking good Brent!! With having those nice hi-comp pistons & lumpy sticks are you going to run out of breath through the stock airbox/AFM?? Also given the S38's had airboxes quite a bit bigger and MAF's... Are you going to be running on the stock ecu (& AFM) etc... Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted October 7, 2010 Looking good Brent!! With having those nice hi-comp pistons & lumpy sticks are you going to run out of breath through the stock airbox/AFM?? Also given the S38's had airboxes quite a bit bigger and MAF's... Are you going to be running on the stock ecu (& AFM) etc... yes that had crossed my mind , i will look into maybe updating the intake system at some stage .i have already had the stock ecu remapped with the std engine , but will be doing it again when i have it up and running. will see how it proforms . i use a k&n type filter with plenty of fresh air coming in around the head light etc like in the picture below. i might look picking up a e34 m5 intake system and maybe e34 m5 ecu & maf etc or some after market maf/map system etc. or maybe a nice 6 trumpet set open set up Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted October 8, 2010 (edited) ITS ALIVE!!!!!! got up and running today , seems to be ok , a bit of a resonating rattle just above idle but disapears at higher rpm , sounds a bit like timming chain or something , so need to do a bit more investigating , but other than that seems to be ok , pulls quite nice , but havn't ringed it out yet as its a new engine . now just get a new wof and some reg etc . fit the road wheels and drive it around a bit Edited October 9, 2010 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted October 9, 2010 nice work brent! bloody awesome Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 9, 2010 sweet! 1000k run in ahead ? Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted November 15, 2010 a quick update , car is all go . got a new 3.2L m3 chain tensioner in , sort of changed the engine noise up the rev range so ended up modifying a old cam chain tensioner with bolt etc , so now its adjustable . car goes well , will clock up a few k's in it first then off to get the ecu remapped , Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted December 20, 2010 dyno run today . with the ecu being remaped by gavin at high velocity need to do a bit of work on the intake and exhaust system to let a few more pony's out . a good increase of torque and fairly good across the rev range of power. but its a little restricted up at the topend should keep going past 180rwKw or so previous dyno time with the old worn engine. http://www.bimmersport.co.nz/forums/index....showtopic=25493 Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted December 20, 2010 Quite a gain throughout the revs. How different are the schricks vs standard in lift and duration? Looking forward to seeing what you do to the intake and exhaust Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted December 21, 2010 Quite a gain throughout the revs. How different are the schricks vs standard in lift and duration? Looking forward to seeing what you do to the intake and exhaust 11,0mm lift 272/272/110 std 262?? i think Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 21, 2010 Sounds utterly fantastic. Nice work Brent. Hitting the track with it soon? Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted December 21, 2010 Sounds utterly fantastic. Nice work Brent. Hitting the track with it soon? yup should be out as much as i can . Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted December 21, 2010 Come hampton jan 2nd Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted August 29, 2011 (edited) this should help the engine breath a bit will get the factory plenium chamber modifed to except 4" intake pipe etc this is a millar maf replecment unit for the standard old barn door flap type afm . which is a bit restrictive and old school way of measuring air flow details here http://millerperformancecars.com/index.php...t&Itemid=30 can also get them for m30 and m20 engines Edited August 29, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
malus139 5 Report post Posted August 29, 2011 I heard these units are really good, would Gavin be able to reprogramme your current computer to use these MAF's to its full potential? Im looking at one for my next project. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted August 29, 2011 I heard these units are really good, would Gavin be able to reprogramme your current computer to use these MAF's to its full potential? Im looking at one for my next project. yes gavin will be doing the remap etc. it comes with a chip to go into the ecu , but i dont think i need to use it?? have already had the ecu remapped with the old afm setup will be interesting to see how it goes. Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted August 30, 2011 I imagine a HUGE improvement. Please post dyno etc Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted August 30, 2011 I heard these units are really good, would Gavin be able to reprogramme your current computer to use these MAF's to its full potential? Im looking at one for my next project.Gavin did mine, took what he needed from the new chip and built a new one for mine, got around 10 rwhp improvement, took the M30 3.5 to 209 rwhp. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted September 12, 2011 (edited) mounted the maf unit up today modified the wiring to the afm , fitted the miler maf ecu chip. starts and runs , makes big sucky sound now. off the gavins in the morning to tune it up. Edited September 12, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted September 12, 2011 Post graphs pretty please Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted September 12, 2011 nice shield addition too should make for healthy improvements so +1 on the graph posting please Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted September 13, 2011 ok , took the car in today for a remap after fitting the miller maf unit . came up to 182rwkw ,10rwkw over previous time with a std afm unit. had a few issues with pinging , due to we think low fuel flow (old worn fuel pump??) and wrong fuel pressure reg fitted 2.5bar instead of 3bar etc. also need to do a few other things and checks. like get the injectors cleaned serviced or replaced etc. get rid of the inline fuel dampers , check intank pump filter , check/replace fuel filter etc. fit a wire mesh in front of the maf unit to straighten out the air flow. then back for a proper tune. Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted September 14, 2011 thats a pretty good jump by widening the sippy straw for the motor. Quote Share this post Link to post Share on other sites
