BmwolfJR 0 Report post Posted October 11, 2010 Hi to all The old man(BMWolf) and I are heading towards the end of a 7 year build of our BMW E21 Race car and I thought that I might post a chronicling of our battle with the beast. The car we started with was an E21 323i Gold with a bent rod and a hole in the block. On blocks it went and away we went Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 With every nut, bolt and sticky piece of plastic riped from the car we started rust repair. the roll cage was squeezed in next. Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 With a block that had a hole in it the decision was made to buy an M20 out of a 525e from Mosen which went under an extreme rebuild Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 As the e21 front end is known for its lack of skill and ability a new one was designed and fitted Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 Because the e21 comes with 4 stud hubs and wheels, the need for more custom work arose. Two large and two slightly smaller aircraft grade aluminum ingots were purchased to be made into new front and rear hubs Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 11, 2010 Blimey! More please. Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted October 11, 2010 God this is impressive. I can only imagine how much time/money you've poured into this. Those ingots cant have been cheap. Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted October 11, 2010 more please! Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 11, 2010 The rod and block destruction is great. Looking forward to see what's going into the m20 build Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 The people have spoken and we have more to show!! :-) Before the ingots could be machined, rear end components were made to replace the old ones then fitted to the newly powder coated parts Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 With the ability to make the hubs any way we want the standard rear disk, drum combo was not going to cut it. So the front vented disk, twin pot calipers and brakes were moved to the back. Two small floating calipers were added to work as a standalone hand brake. Two large 4 pot Wilwood disks and calipers were fitted to the front Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 Now to the fun bit the M20; The block was powder coated red and honed to new The valves were cleaned and lightened and the head port polished and in the heart of a dark garage the "master" constructed a set of needle roller rockers to replace the standard ones Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 11, 2010 How is the rear rotor attached to the hub? I'm guessing magic Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted October 11, 2010 wow! this is awesome, you have my full attention ... what are you doing to the M20? what capacity is it going to be? Quote Share this post Link to post Share on other sites
BMWolf 0 Report post Posted October 11, 2010 How is the rear rotor attached to the hub? I'm guessing magicThe rotors are spigot-ed and cap screwed to the back of the hubs with 8 x M8 316 SS screws Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 11, 2010 Loving the design/fabrication work going on here. Watching with interest Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted October 11, 2010 ^^+1 the detail and the quality of the engineering and fabricuation is incredible, a top effort. More please... Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 Thanks guys all the engineering and fabrication work has been done by the Old Man (Bmwolf) i will add more tomorrow. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted October 11, 2010 +1.. subscribed. Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 With a custom front suspension in the car the Macpherson strut needed to be modified so with some fabrication work the original strut was made in to a fully adjustable one Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 The petrel tanks were sent away to be powder coated red and then fitted. The dashboard was cut in half and fitted with our new steering wheel. The dashboard was later removed in favor of some thing cooler (more on that later) Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 11, 2010 the roller rockers were fitted After the crank, rods, balance wheel and fly wheel were lightened and balanced the crack an rods under went nitriding they were also fitted and then the engine was mocked up Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted October 11, 2010 Woah, so much win. Quote Share this post Link to post Share on other sites
Jacko 2304 Report post Posted October 11, 2010 ^ Oath. This is awesome. Stop drip feeding the addicts though, the suspense is killing me Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 12, 2010 (edited) a new intake manifold was fabricated and the EFI throttle bodies were fitted and the engine was squeezed in (with help from my good friend disk grinder) Edited October 12, 2010 by BmwolfJR Quote Share this post Link to post Share on other sites
