thorburn 123 Report post Posted October 12, 2010 Who makes the throttles/what are they from? Was the intake section between the throttles and head designed to be replaceable for tuning the intake length? That is one very good looking engine Quote Share this post Link to post Share on other sites
TDP 0 Report post Posted October 12, 2010 Best thread EVAH! I am very interested to hear how that front end works out for you. Are you still using the original sub-frame and steering rack but with modified hub-carriers and custom control arms? I'm curious also about steering weight with wider tyres fitted? Quote Share this post Link to post Share on other sites
BMWolf 0 Report post Posted October 12, 2010 Who makes the throttles/what are they from? Was the intake section between the throttles and head designed to be replaceable for tuning the intake length? That is one very good looking engine The intake manifolds are my own design and work. After much reading and research of how similar modifications were arrived at in the USA, the magic number is 12 inches from valve face to the end of the trumpets. This will give good low down torque. The throttle bodies were purchased from Etchells race parts in Tauranga. W Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 12, 2010 ^ the "guru" has spoken p.s. try http://www.efihardware.com/ Quote Share this post Link to post Share on other sites
BMWolf 0 Report post Posted October 12, 2010 Best thread EVAH! I am very interested to hear how that front end works out for you. Are you still using the original sub-frame and steering rack but with modified hub-carriers and custom control arms? I'm curious also about steering weight with wider tyres fitted? Yes we are using the original sub-frame and steering rack. The original wheels were steel so the Mags we have weigh no more then them, also we do not have a power steer setup but steering is still very easy lock to lock. W Quote Share this post Link to post Share on other sites
nzer 0 Report post Posted October 12, 2010 love this thread!! niiice work! Quote Share this post Link to post Share on other sites
E30BMA 0 Report post Posted October 12, 2010 Whoa this this is awesome!! Amazing custom mods & fabriation skills there. Id never be able to keep a project like that secret for 7 years. Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted October 18, 2010 we need an update on this! Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 18, 2010 hello im back sorry we have been super busy after the engine went in we added a custom gear leaver and short shifter Quote Share this post Link to post Share on other sites
Jacko 2304 Report post Posted October 19, 2010 Wow. Heavy Duty shifter! Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 19, 2010 It just gets better and better. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted October 19, 2010 I'm very aroused. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted October 19, 2010 ^ What he said Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 19, 2010 f**k .. im very impressed with the custom work. Especailly interested in your long length shifter. Im running something similar however looks like you have got over the linkage ratio barrier with having a shifter up to the steering wheel ? Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted October 19, 2010 Serious amounts of awesome.... Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 20, 2010 f**k .. im very impressed with the custom work. Especailly interested in your long length shifter. Im running something similar however looks like you have got over the linkage ratio barrier with having a shifter up to the steering wheel ? I believe that the plan is that if you move your hand off the wheel you should be able to get to the shifter with out having to move your hand vertically. At the current length with addition of short shifter we get about the same ratio as standard but gain the length at the top. Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted October 20, 2010 Those mods are very cool indeed. I am liking the red Did you spend alot of time researching? or was it trial and error on the custom work? Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 20, 2010 (edited) A new wiring loom was imported form the USA so we did not have to deal with the old one We also added a front/back brake bias lever Edited October 20, 2010 by BmwolfJR Quote Share this post Link to post Share on other sites
BmwolfJR 0 Report post Posted October 20, 2010 In with the radiator and away with the plumbing. the e21 brake master cylinder was replaced with E32 750i one. Quote Share this post Link to post Share on other sites
BMWolf 0 Report post Posted October 20, 2010 Those mods are very cool indeed. I am liking the red Did you spend alot of time researching? or was it trial and error on the custom work? I am reliably informed that the powder coating will stand up to almost all heat the engine can produce except overheat so powder coating the block and sump red, was a great option for us. I spent many hours researching E21 performance mods in the US, and that is where most of my ideas came from. W Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 20, 2010 (edited) What ecu will you be using? alpha-N tune? opened eyes and found map sensor Feel free to ignore question and surprise me later. Edited October 20, 2010 by bbs Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 20, 2010 In with the radiator and away with the plumbing. the e21 brake master cylinder was replaced with E32 750i one. Around the expansion tank, have you thought of getting a polished tig welded alloy one made insteadt of the OEM brown plastic one ? You could then mount it away from the motor. Quote Share this post Link to post Share on other sites
BMWolf 0 Report post Posted October 21, 2010 What ecu will you be using? alpha-N tune? opened eyes and found map sensor Feel free to ignore question and surprise me later. We have a HAWK ecu which is adjustable down to 128 RPM increments with live feed to a vdu if we need it. The down side is the Company, which is (was) in Aust. has gone belly up. Doesn't help the project much now. W Quote Share this post Link to post Share on other sites
BMWolf 0 Report post Posted October 21, 2010 Around the expansion tank, have you thought of getting a polished tig welded alloy one made insteadt of the OEM brown plastic one ? You could then mount it away from the motor. Good call, I have been told about an early BMC one (Austin 1100 I think) which is brass, will chrome up well. But I have yet to investigate full. W Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 23, 2010 Nice! .. I used a e36 m3 one for mine. I found it had the added bonus of being translucent which was nice to visually quick check levels. However for look good factor I think a nice polished one in that engine bay of yours is more appropreiate! looking forward to the next update! Quote Share this post Link to post Share on other sites
