havak2tone 0 Report post Posted October 13, 2010 hi guys just wanted to ask you guys about me car.its a 320i manual running getrag 240 and the thing is i got the car after it had a transplant.so unsure about kilometres on either of them Im planning on using the car for a daily driver and drifting.The only thing is that im scared the motor might blow up on me or something.Ive only done little things like clutch replacement rust repair and simple stuff but i cant do a rebuild let alone have the tools for it.You guys think i should rebuild both gearbox and motor before drifting it?? if so does anyone here wana do it for me just pm me with your price please..... Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 13, 2010 I think you should put a bigger motor in it tbh. Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted October 13, 2010 (edited) Makes sense to rebuild an M20B25 if you're going to take the motor out. Try drifting it first and see how it goes, would give you an idea of what needs to be upgraded. Edited October 13, 2010 by B20 Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted October 13, 2010 (edited) if you are serious about drifting then you may want to be considering a motor swap so something else, ie m5x or something jap. unless you plan on drifting on ice the m20b20 motor probably wont cut the mustard, to give you a rough idea though, i rebuilt my m20b25 for $3500 a few years back, and that was with me assembling and disassembling the motor, ive been quoted about $1200 for parts to recon a gearbox. you will also need to look into getting some good suspension and an lsd and if youve got some change get the lsd rebuilt. approx $1200 Edited October 13, 2010 by -Oli- Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3027 Report post Posted October 13, 2010 It all depends on what you mean by drifting it really, are you talking about doing skids in a mate's paddock, taking it to the odd public track day where drifting is permitted, or entering competitions, even doing a full season of D1NZ? As a minimum I would say you need to check everything is in tip-top condition before even the skids in the paddock, fresh new (quality brand) oil in the motor, gearbox and diff, cooling system working well, a decent tune-up on the engine, new air filter, plugs, etc. Drifting is very hard on the cars, even before you start sliding off into things, so things are likely to break, even in a low state of tune E30, allow for that in your thinking. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 13, 2010 It all depends on what you mean by drifting it really, are you talking about doing skids in a mate's paddock, taking it to the odd public track day where drifting is permitted, or entering competitions, even doing a full season of D1NZ?If it is also his daily i'd imagine its just grassroots stuff.If your comfortable with an engine swap then i'd say drive it till it dies, replace and repeat. Of course give it as much help as it can get with all maintanence up to date and a good cooling system. You wont get far with an open diff and a welded diff isn't really daily driver friendly(some might argue this). Some nice shocks and springs, few bushes and some other bits that'll empty your wallet and you should have a reasonable e30 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 13, 2010 Just put a m20b25 in it. You can pick them up for like $700. If it blows up (probally wont), buy another one. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 13, 2010 Lots of options if you want more power. Could turbo your M20B20 for like $700. Rubbish Quote Share this post Link to post Share on other sites
havak2tone 0 Report post Posted October 13, 2010 i wont be drifting all the time just every now and then in a paddock or on the tracks.How easy would it be to put the m20b25 in it ......I think ill use it with the getrag 240 if it bolts straight in ?? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 13, 2010 (edited) i wont be drifting all the time just every now and then in a paddock or on the tracks.How easy would it be to put the m20b25 in it ......I think ill use it with the getrag 240 if it bolts straight in ??All bolts straight in. You will have to mount up the oil cooler, but its piss easy. Should replace the clutch and other bits while its apart aswell, but thats up to you. It is the cheapest way to make a 320 faster. Edited October 13, 2010 by polley Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted October 13, 2010 Thrash it till it dies then transplant something more powerful If your cheap I wouldnt muck around with a bmw engine just put an sr20 or rb in it imo those nissan engines offer the most bang for buck and theyre tough in the mean time your going to want a bigger radiator, strip the interior, lower it and use harder rear springs, thicker rear sway bar lsd or at least a locker lots of tyres Thats just a basic setup to induce oversteer With harder rear suspension the car will oversteer more so that will just help while you have low power Stick to smaller rear wheels to aid loss of traction and maybe a higher ratio diff to keep the revs high Quote Share this post Link to post Share on other sites
havak2tone 0 Report post Posted October 13, 2010 okay then i shall thrash its pants off till it dies then transplant when its goners .I might just do a m20b25 straight swap for my first engine tranplant to keep it easy might rb it if i manage to get enough experiance with engine swap Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted October 13, 2010 All bolts straight in. Depends what year it is, FL swap is easier than preFL. PreFL uses different engine management and has sensors in the gearbox, if you change the box then you need a new driveshaft too. Other bits and pieces different too that should be changed Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 13, 2010 Depends what year it is, FL swap is easier than preFL. PreFL uses different engine management and has sensors in the gearbox, if you change the box then you need a new driveshaft too. Other bits and pieces different too that should be changed Doh. I was thinking all facelift stuff. Quote Share this post Link to post Share on other sites
havak2tone 0 Report post Posted October 13, 2010 aw f@*k it my one is a prefacelift....How difficult is it to do those little changes,I think im just gonna get another car like a nissan for this. it looks like its only gonna get more complicated and fiddly. but thanks for all the advice cuzzies Quote Share this post Link to post Share on other sites
Driftit 2199 Report post Posted October 15, 2010 Yip do not bother with a BMW drift car unless you have lots of money or wish to transplant in a better or Jap motor. Your only cheap option for diffs is to weld up an open diff as the LSD's are very expensive. They are also snappy little cars when biffing them around. As you said. Get yourself a lazy old Nissan. Cefiro, Laurel. Though about 10X the price they were 10 years ago they are plentiful and easy to drive. Quote Share this post Link to post Share on other sites
