waxer 0 Report post Posted March 31, 2005 I am thinking of getting a new chip for my 325i to sparkle things up a bit. Any advise/pros/cons/previous experience/performance pluses. Muchly. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted March 31, 2005 a lot of chips dont do a lot except raise the red line (mines at 6800, but i get the feeling that without the chip, car would feel the same) your best bet would be to get something (not sure what, as i been looking at same) that is tuneable on a dyno. Link seems to be the cheapest around (there are a couple of others but apparently crap) would allow you to advance timing, change redline, change to MAP sensor or similar.....should give a decent gain depending on your other mods Quote Share this post Link to post Share on other sites
Juzzie Wuzzie 0 Report post Posted March 31, 2005 I had a chip programmed for my 2.8 rebuild. Done in CHC - Graeme Clyde of GAC will know who/how, etc. I think c.$1,000 it cost. Never drove the car, so can't comment on performance - but know the car went like a cut cat. Quote Share this post Link to post Share on other sites
318i Turbo 0 Report post Posted April 5, 2005 the revlimit is changed by the dissy rotor i think, they have a spring inside that once spings at a certin rpm stops the igntion, so by changing to a rotor with a diff strenght spring inside will change where ur revlimit is at Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted April 5, 2005 the revlimit is changed by the dissy rotor i think, they have a spring inside that once spings at a certin rpm stops the igntion, so by changing to a rotor with a diff strenght spring inside will change where ur revlimit is at only on L-Jet - motronic has ECU controlled rev limit Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted April 5, 2005 A remappable chip is the way to go - tangible gains are apparently possible (from the mouths of those who have had it done). I haven't done mine, so what I say is just what I've heard. I have heard of a couple of good brands to look for, but they escape me for the moment. If I remember I will post back. But I have heard of a well tuned (chipwise) M325i with custom exhaust and pod filter making 192hp, which is comparable to the first of the catalysed M3's with the previous uncatalysed one making 200hp I think, and the newer catalysed 215. So with no other serious mods other than exhaust and chip it seems big gains can be made. The M325 I was referring to was in an issue of total BMW and the guy had also beefed up brakes, dropped the car 60mm and thrown in a hartge strut brace, but as far as engine mods, that was it. It was in europe somewhere so they called it a 325i Sport, but I am led to believe this is essentially a M325i by a different name. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted April 5, 2005 Conforti chip ring any bells? Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted April 5, 2005 yuh, jim conforti, sparkle reckons they have the most gains on an m30(20hp apparently), so i'd imagine they'd be one of the better on a 325 as well Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted April 6, 2005 jim conforti the only chip worth any money.not any egay crap Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted April 6, 2005 was gonna do jim c, but i think ill do a whole new ecu now, as a chip is based on a standard engine, mine aint. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted April 8, 2005 (edited) apparently E.A.T chips work wonders for m30,s,try him he does other computer work so is sometimes a bit slow to respond.You will need to give him the dme no.... note that the yanks have a different system for their octane ratings,also would probably pay to tell him that its an non us car etc etc..... Edited April 8, 2005 by kiwi535 Quote Share this post Link to post Share on other sites
markusamigos 0 Report post Posted April 10, 2005 check this site..........the chip worked for my 540i http://www.powerchipgroup.com/index.asp :rambo: Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 11, 2005 as for that bmw article with the guy with a chip and exhaust making 192hp....i call bullshit if that was the case then how come people bother with 2.7's that make 192hp? i just find that REALLY really hard to believe...esp seeing as that car hasnt been dynoed and the 192 is a figure he pulled out his ass and whats makes that car an ACS?!?! the badge and exhaust? Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted April 12, 2005 sounds believable to me, jim c chips give M30s 20hp, dyno proven. Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted April 12, 2005 if that was the case then how come people bother with 2.7's that make 192hp? more torque? plus you could chip your 2.7 i reckon a sh*t generic chip, wouldnt do much, but a genuine quality one would have game. Quote Share this post Link to post Share on other sites
cruznz 0 Report post Posted March 19, 2006 check this site..........the chip worked for my 540i http://www.powerchipgroup.com/index.asp :rambo: sorry for digging up an old thread, but wondered if your 540i has EWS-11,if so,did you have to send your chip to Powerchip as their site doesn't mention anything about the EWS software Quote Share this post Link to post Share on other sites
Jazzbass 1 Report post Posted March 20, 2006 You're all wasting your money. As someone posted here some time ago, just get the one for $69.95 from Trademe - plus it is variable!! Maybe you buy 4 of these and get over a 100bhp increase .... Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted March 21, 2006 Conforti claims +15hp and +15lb.ft torque on a 325i. I've been contemplating getting one or two, but have no idea on which set up (ECU) I have on the two different cars. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted March 21, 2006 Conforti claims +15hp and +15lb.ft torque on a 325i. I've been contemplating getting one or two, but have no idea on which set up (ECU) I have on the two different cars. Are the conforti chips really going to work with our NZ fuel? You'd be taking a big risk spending money on a chip designed for the US or European markets without discussing the fueling issues first. Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted March 22, 2006 Think they said 91 octane or better fuel, so should be OK, I'm still dubious about the claims, given that there is no other work undertaken. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted March 22, 2006 Think they said 91 octane or better fuel, so should be OK, I'm still dubious about the claims, given that there is no other work undertaken. thats AKI fuel - so you'd need to run 98 RON fuel to get a similar level of octane. Quote Share this post Link to post Share on other sites
