w_elliot 7 Report post Posted February 7, 2011 had some free time today and made a start at pulling the cracked sump off the e30 in order to get it welded up, the sump just doesn't want to go anywhere... i have removed all visible bolts and have seperated the front of the sump from the block but something is holding things up at the gearbox end. any hidden bolts i should know about? I am running an m50b25 with getrag 240 trans and an e34 sump. i hope someone can help me out here, i'm over having no means of transport!! Quote Share this post Link to post Share on other sites
Jacko 2371 Report post Posted February 7, 2011 had some free time today and made a start at pulling the cracked sump off the e30 in order to get it welded up, the sump just doesn't want to go anywhere... i have removed all visible bolts and have seperated the front of the sump from the block but something is holding things up at the gearbox end. any hidden bolts i should know about? I am running an m50b25 with getrag 240 trans and an e34 sump. i hope someone can help me out here, i'm over having no means of transport!! Lightly tap it with a mallet all the way around the gasket, if that fails, thin plastic scraper and a hammer works Quote Share this post Link to post Share on other sites
w_elliot 7 Report post Posted February 7, 2011 i think it's something trickier than a sticky gasket. the front part of the sump seperated easily but further back it just wont budge no matter how hard i try to pry it off which leads me to think that it's stuck where the engine, trans and sump meet. any hidden bolts in that area? Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted February 7, 2011 (edited) double check the number of bolts you have removed . and dont forget all teh ones around the bell housing etc http://bmwfans.info/parts/catalog/E34/Seda...evel_indicator/ Edited February 7, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
polley 916 Report post Posted February 7, 2011 (edited) You need to take the gearbox off to get at the rest. (bolts 8 and 9 I believe). Edited February 7, 2011 by polley Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 7, 2011 No, the gearbox doesn't have to come off, there are 2 small cutouts on the bottom of the box to access those bolts thru. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted February 7, 2011 He's got a getrag 240 or 260 on there from an m20 and it doesn't have the cutouts. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted February 7, 2011 No, the gearbox doesn't have to come off, there are 2 small cutouts on the bottom of the box to access those bolts thru. Ok. Quote Share this post Link to post Share on other sites
w_elliot 7 Report post Posted February 7, 2011 poos. going to be a busy day then. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 7, 2011 He's got a getrag 240 or 260 on there from an m20 and it doesn't have the cutouts.Get a drill? Quote Share this post Link to post Share on other sites
B PORTN 0 Report post Posted February 7, 2011 (edited) should be two bolts at the gearbox end (bell housing) had the same problem but i had an auto box not sure if theyre same/different?? Edited February 7, 2011 by B PORTN Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 7, 2011 Hours of fun lying under an e30. On the topic of welding I was advised against welding a cracked sump. According to a welder I talked to about this any residue oil can cause small holes to be blasted into the aluminium once they start the welding. It was for an e28 M30 sump hard to find parts as it is, even though in the end finding an uncracked second hand one was cheaper anyway. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted February 8, 2011 should be two bolts at the gearbox end (bell housing) had the same problem but i had an auto box not sure if theyre same/different?? It is different because he is using an m50 with an m20 gearbox. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted February 8, 2011 Hours of fun lying under an e30. On the topic of welding I was advised against welding a cracked sump. According to a welder I talked to about this any residue oil can cause small holes to be blasted into the aluminium once they start the welding. It was for an e28 M30 sump hard to find parts as it is, even though in the end finding an uncracked second hand one was cheaper anyway. Yes, it can be difficult to weld the alloy sumps. Especially if the crack is old. however, I successfully had an m20 sump welded and it still doesn't leak to this day. (4-5 years later). Quote Share this post Link to post Share on other sites
w_elliot 7 Report post Posted February 8, 2011 Yes, it can be difficult to weld the alloy sumps. Especially if the crack is old. however, I successfully had an m20 sump welded and it still doesn't leak to this day. (4-5 years later). the crack is far from old, only happened about three days ago. finally got it off at lunch time today, i've chopped a small unnessecary section out of the bellhousing so if this ever happens again it'll be a nice quick fix as the two hidden bolts are no longer hidden can anyone reccomend a good welder in christchurch? cheers to the people who mentioned the hidden bolts, if it weren't for those pointers i'd still be sitting around scratching my head. Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted February 8, 2011 the crack is far from old, only happened about three days ago. finally got it off at lunch time today, i've chopped a small unnessecary section out of the bellhousing so if this ever happens again it'll be a nice quick fix as the two hidden bolts are no longer hidden can anyone reccomend a good welder in christchurch? cheers to the people who mentioned the hidden bolts, if it weren't for those pointers i'd still be sitting around scratching my head. I just wrote you a pm about this. Sorry I didn't get back to you sooner. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted February 8, 2011 Has it got my old sump on it with a crack welded down the side of it ? Quote Share this post Link to post Share on other sites
w_elliot 7 Report post Posted February 8, 2011 Has it got my old sump on it with a crack welded down the side of it ? Doesn't appear to, unless someone is very good at grinding their welds back. Its still repairable but it was cheaper and easier just to buy another one so the cracked one is getting shelved until I learn how to tig. Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted February 8, 2011 Has it got my old sump on it with a crack welded down the side of it ? When I smashed it I put a mint sump on it. I think that's the one he smashed. Quote Share this post Link to post Share on other sites
w_elliot 7 Report post Posted February 9, 2011 Mended. now it's time to track down a bit of compressed air and blow all the rainwater out of my ignitition system so i get 6 cylinders all the time. god i wish i had a decent garage... thanks for all the tips, it's made the job a lot easier. Quote Share this post Link to post Share on other sites
