Garett 103 Report post Posted May 13, 2012 Ok so the easiest part is done haha Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 13, 2012 good effort dude Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted May 13, 2012 crunchy said: im having custom cams done for the m50 if your ever in the need just sourcing the lash caps and they will be exchange ans at a price that you cant refuse when you have these sorted i will be interested in some spec's and price so please send me a pm. regards kerry Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 13, 2012 kerry said: when you have these sorted i will be interested in some spec's and price so please send me a pm. regards kerry M50 MSE Fast road intake .400" lift exh .366" intake 222deg@.050" exh 210deg@.050" intake valve fully open at 108deg exhaust valve fully open at 112deg 1.5mm lash caps are needed to retain correct geometry Quote Share this post Link to post Share on other sites
EdifGee 0 Report post Posted May 13, 2012 Dude this is such a awesome build. Good to see what a bit of time and effort can do. Keep it up :thumb: Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 8, 2012 More good things arrived this morning Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted June 8, 2012 the gates are great the blow valves a pain in the butt Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 8, 2012 crunchy said: the gates are great the blow valves a pain in the butt Really Why? Which one would you reconmmend? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted June 8, 2012 Garett said: Really Why? Which one would you reconmmend? the quality is fine but not user friendly to adjust the springs dont give enough range versus vacuum Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 9, 2012 crunchy said: the quality is fine but not user friendly to adjust the springs dont give enough range versus vacuum True, now ive been reading alot of forums on the Tial Q, there is alot of people having surge issues with having the wrong spring. Mine is a 10 psi spring. ill need to check the vac at idle to make sure i have the right one, i didnt know you had to do that before you ordered it, mind you the didnt ask either.. at least i can send it back and get the correct one if need be, thats the good thing about buying new Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted June 9, 2012 i just cut the spring to get it right Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 9, 2012 crunchy said: i just cut the spring to get it right I can see how that would work, pain pulling it apart every time till ya get it how ya want it.. Does anyone know what the best and user friendly BOV is? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted June 9, 2012 Garett said: I can see how that would work, pain pulling it apart every time till ya get it how ya want it.. Does anyone know what the best and user friendly BOV is? what you have is a good as it gets sorry even the turbosmart bv isnt much better you can run without one but thats another story and requires two throttle bodies Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 11, 2012 crunchy said: what you have is a good as it gets sorry even the turbosmart bv isnt much better you can run without one but thats another story and requires two throttle bodies So i guess ill run with this one and see how we go... Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 11, 2012 (edited) This weekends plan will be doing some painting on the body and weld the nut on the oil pump while the engine is out, does any one know if you can upgrade the oil pump using one from another bmw engine?? Was also thinking of die grinding the internal side of the block on my engine and sanding it nice and smooth to alow oil to return quicker to the sump.. Edited June 11, 2012 by Garett Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted June 11, 2012 If you have any oil pumps from an s50 or s54 they are a nice upgrade. M54 pumps are different but seem to have the same internals. You'd need to modify it a little to fit so probably not worth it Are you making up a sump baffle Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 11, 2012 (edited) Thorburn said: If you have any oil pumps from an s50 or s54 they are a nice upgrade. M54 pumps are different but seem to have the same internals. You'd need to modify it a little to fit so probably not worth it Are you making up a sump baffle I was not planing on making a baffle up for the pan, worth doing you think? have you made one for yours? Edited June 11, 2012 by Garett Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted June 11, 2012 I've just got a cardboard template made up. I'll get around to it one day Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted June 11, 2012 Thorburn said: I've just got a cardboard template made up. I'll get around to it one day dude id so supply the alloy sumps and materials if you wana make a couple Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted June 12, 2012 Can i get you to clean the sumps as well haha Yea i'd be keen to make a couple It'd be a good excuse to use my folder for something other then bait boards I'll PM you my number Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 1, 2012 (edited) Just a quick update... I noticed that there were a lot more dents in my car that needed attention so ive been attacking that, also my manifold collectors made, the rest is not far away Edited July 1, 2012 by Garett Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 1, 2012 Thorburn said: Can i get you to clean the sumps as well haha Yea i'd be keen to make a couple It'd be a good excuse to use my folder for something other then bait boards I'll PM you my number I got a couple of clean ones there, ill flick ya a text and we can go over a plan Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 1, 2012 Are you making the manifold or getting mike to do it? Looks like one of mikes collectors. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 1, 2012 polley said: Are you making the manifold or getting mike to do it? Looks like one of mikes collectors. Yep sure is, i dropped off a donor e36 4dr with m52 engine so he can make it to fit that i assume it has the same clearances as the e36 2dr m50 right? that way i can continue working on the shell. I gave up on making my own manifold i figured for the time involved and the weekends spent it would be cheaper just to get one made, i heard he does a pretty good job. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 1, 2012 Yeah I'm sure they would be the same. He did a pretty good job of my manifold, was worth the wait. Quote Share this post Link to post Share on other sites
