Garett
GDM - E36 Drift/Race Project
On Friday, September 23, 2016 at 2:27 PM, richard said:
I'm keen on the doors and bonnet if the shipping price right .
Will get onto pricing sea freight then
So pretty exciting day today and finally an update...  most of the good things have arrived for my build, big thanks to speed factor in Tauranga, done an awesome job getting the parts together for me.
  • Like 2
Out of interest it that head gasket use the floating rings ?
I guess so, I, Athena cooper ring gasket. They seem to be a better gasket for boosted applications going off what the internet says lol
Edited by Garett
It's a cut ring gasket so will slightly cut into the head and the block to handle a lot more pressure and less chance of it blowing out
  • Like 1
Used them before, they sit on top of the block and locate within the cut out of the fibre head gasket
  • Like 2
So dropping off the block to get tourqe plated and bored to fit the pistons tomorrow, after that the all the components for the block will get balanced and then installed, I'll try get photos of the processes if I can. The only thing missing is a good clutch.. I could use my clutch in my car already but that would require me removing my engine and gear box now and it's still driving and driving well...
im toying with the idea of getting new supertech valves and springs but a cost of around 2k is making me wonder what difference would it make???
What size are you getting the block bored to?
86.5mm so not much over factory, I measured the bore in different places and it was all over the show I'd say this block has had a pretty good life lol
Edited by Garett
  • Like 1
Which shop has the torque plate?
What cam are you going to use?
Are you looking at getting the supertech springs to maybe save you if you money-shifting it or just performance?
I'm sure the block will continue to have a great life
  • Like 1
Nice one.
Are you stroking the motor out to s50b32 specs?
Edited by zero
Waikato engine reconditioners have one they hired in, I'm going to use the stock s50b32 intake and exhaust cams with a vanos delete and custom cam timing...
ive done a lot of research into the valves and springs and just aftermarket valve train in general and many sleeps lost and found a few people having valves and retainers broken and them reverting back to the stock set up, I'm going to keep the revs to 7000rpm max and run what I got, I'm not sure the turbo will flow much after that anyway...
Hell yeah this blocks got a new lease on life... for how long we will see haha
Edited by Garett
10 hours ago, zero said:
Nice one.
Nope the stroke will remain the same as I'm using the s50b30 crankshaft at 85.8mm stroke I think the b32 is 89mm stroke.
Tomorrow I'll be dragging out the car and removing the clutch set up and taking it in so the whole set up can be balanced together, then start tiding up the body work, got some new m3 front and rear bumpers that are going off to get new paint well maybe just the front as I don't really mind the cable tie stitches in the rear lol.
Edited by Garett
Ok so nothing got done.. ended up writing up invoices and get jobs ready for next week, washing cars and ready just sweet F A, no hoists are free and don't really fancy dropping it all out on the floor, maybe next week i might have better luck, off home to do some homely things, hope everyone else is weekend is more productive than mine.
I did however buy a cheap V8 e39 540 non vanos that runs mint and looks the part, only thing is it hasn't had a reg since 2014
Does anyone know of a fun event that i could use it in like some sort of gumball or under $1000 race, etc ???
Got abut done today, cleaned up all the nuts and bolts and more engine parts, disassembled the cylinder head so can take it in to get machined
  • Like 3
I've got some s50b30 camshafts if Somone would like to buy them...
Edit: may still use them yet!
Edited by Garett
So much engine porn.......
  • Like 1
I've reposted this from 318ti.org from user Nix328ti, cheers
M50B20nv // int: 240º(9.7mm) // open:24º close:36º // exh: 228º(8.8mm) // open:38º close:10º
M50B25nv // int: 240º(9.7mm) // open:19º close:41º // exh: 228º(8.8mm) // open:35º close:13º
M50B20tu // int: 228º(9.0mm) // open:3º close:39º // exh: 228º (9.0mm) // open:39º close:9º
M50B25tu // int: 228º(9.0mm) // open:4º close:44º // exh: 228º(9.0mm) // open:35º close:13º
S50B30 // int: 260º(12.0mm) // // exh: 260º(12.0mm)
S50B30US // int: 252º(10.2mm) // // exh: 244º(9.5mm)
S50B32 // int: 256º(9.7mm) // // exh: 240º(9.0mm)
M52B20 // int: 228º(9.0mm) // open:4º close:44º // exh: 228º(9.0mm) // open:39º close:9º
M52B25 // int: 228º(9.0mm) // open:4º close:44º // exh: 228º(9.0mm) // open:39º close:9º
M52B28 // int: 230º(9.0mm) // open:1º close:49º // exh: 228º(9.0mm) // open:39º close:9º
S52 // int: 252º(10.2mm) // // exh: 244º(10.2mm)
M52B20tu // int: 228º(9.0mm) // open:-6º close:54º // exh: 244º(9.0mm) // open:47º close:17º
M52B25tu // int: 228º(9.0mm) // open:-6º close:54º // exh: 244º(9.0mm) // open:47º close:17º
M52B28tu // int: 228º(9.0mm) // open:-6º close:54º // exh: 244º(9.0mm) // open:47º close:17º
M54b25 // int: 228º(9.0mm) // // exh: 244º(9.0mm)
M54b30 // int: 240º(9.7mm) // // exh: 244º(9.0mm)
M54b30ZHP // int: 248º(9.7mm) // // exh: 248º(9.7mm)
If this info is correct, would it be better to use the b30 cams or the b32??
22 hours ago, M3AN said:
Not sure how accurate that ^ is? Doesn't match up to the attached which come from a pretty reputable source.
Lots of cam data here: http://www.catcams.com/engines/engine-selection.aspx?SelectedManufacturer=4
S50B30.pdf
S50B32.pdf
Thanks bud very helpful indeed... ?
Quick update, engine block getting ready for boring, clutch addy arrived and going in for balancing.
  • Like 2
All good mate, love what you're doing.
  • Like 1
