No name user 379 Report post Posted August 21, 2017 No pipe inside at all, dead center is the best place or build a dual plenum Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 22, 2017 It's all mostly together now, massive thanks to the guys at RML engineering and wakfield alloy for ya off cuts and making me awesome engine parts at short notice ? 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 22, 2017 (edited) 11 hours ago, crunchy said: No pipe inside at all, dead center is the best place or build a dual plenum Yeah will make a nice duel plenum one day when I have more time ? Didnt end up putting pipe inside Edited August 22, 2017 by Garett 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 22, 2017 Funny my last engine when it was hot the oil pressure would be around 4psi this one is at 25psi Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 23, 2017 Wheel alignment time 1 Quote Share this post Link to post Share on other sites
BatMansWilly 74 Report post Posted August 23, 2017 1 hour ago, Garett said: Wheel alignment time Next step, BURNOUT TIME! make sure to upload a video! hehehe 2 Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted August 25, 2017 when is dyno day? ethanol? I have some wilwood 6 pots and 4 pots if you need more brake options 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 25, 2017 4 hours ago, thorburn said: when is dyno day? ethanol? I have some wilwood 6 pots and 4 pots if you need more brake options I'd be keen as if they would fit, I think m3 may be different spacing on the front hubs. If ya like bring em out and I'll try one on dyno day is wedensday but may have to delay it, with all this time spent on my car there is still a half finished hallway at my house and Hayleys getting a bit impatient lol ethanol now that's a thought... I thought I'd start with 98 and see what it can make off that, hey it might just be enough... then e85 with an upgrade of pump and injectors 1 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted August 25, 2017 Was that you going some lil test drives down horotiu the other day? Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 25, 2017 Just now, polley said: Was that you going some lil test drives down horotiu the other day? Yeah just setting up the fuel with the laptop, sh*t it's goes well once I got the afr within the correct range Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 25, 2017 You can't do much without a dyno Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 26, 2017 Depending on dyno ill guess 350-380kw wheel on eth closer to 500kw wheel Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 27, 2017 13 hours ago, crunchy said: Depending on dyno ill guess 350-380kw wheel on eth closer to 500kw wheel Cool, I'm guessing 400kw on 98 and 600kw on ethanol... and 25psi boost Any other ideas on what it will make?? Quote Share this post Link to post Share on other sites
Jibs05 86 Report post Posted August 27, 2017 it will make at least 1hp. lol 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted August 27, 2017 500kw We need to have a sweepstake. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 27, 2017 Boost means nothing its just a measurement of pressure or restriction has no reflection on mass airflow, as for end result ? Let the motor decide, if you want really good numbers i can direct you to over inflated ego boosting dynos. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 27, 2017 Your right at the end of the day the motor will decide.. I'm feeling optimistic ? Might have to start looking at track day events coming up... when does night wars kick off?? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 27, 2017 3rd Nov is the first night wars , there is some winter meets but pretty pointless as no track prep Quote Share this post Link to post Share on other sites
richard 384 Report post Posted August 27, 2017 345kw @7000rpm Quote Share this post Link to post Share on other sites
musccoo 84 Report post Posted August 27, 2017 Surely this should cream past 350kw if I made 282kw on a bum old M20 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted August 27, 2017 I would like to think it would too. but a stock standard s50b30 is 217kw @7100 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 28, 2017 9 hours ago, musccoo said: Surely this should cream past 350kw if I made 282kw on a bum old M20 Your ride looks very nice btw! Looks like you done a real good job of it... Quote Share this post Link to post Share on other sites
BatMansWilly 74 Report post Posted August 28, 2017 (edited) 387kw on 98 and 575kw on e85...No matter what the numbers are it will be one hell of a fun car to drive?. When is Dyno day? Edited August 28, 2017 by BatMansWilly 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 28, 2017 1 hour ago, BatMansWilly said: 387kw on 98 and 575kw on e85...No matter what the numbers are it will be one hell of a fun car to drive?. When is Dyno day? Wednesday this week... ? 1 Quote Share this post Link to post Share on other sites
musccoo 84 Report post Posted August 29, 2017 On 8/28/2017 at 7:20 PM, Garett said: Your ride looks very nice btw! Looks like you done a real good job of it... Cheers dude, looking forward to seeing your results.. Quote Share this post Link to post Share on other sites
