Aslan 0 Report post Posted July 17, 2011 Hi everyone! As mentioned earlier I may have found a 2000 BMW 330i SE that I would like to buy, its mileage is quite high so I thought I'd check if anyone knew a rough estimate to recondition the engine. Thanks in advance, Aslan Quote Share this post Link to post Share on other sites
3series 0 Report post Posted July 17, 2011 (edited) Really depends on how far you want to go, I would estimate you would be looking at around $6-8k if you're getting someone else to do it. Edited July 17, 2011 by bmw3 Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted July 17, 2011 If it ain't broke, don't fix it. With the k's the car has done, you may want to get a BMW mechanic to give it a once over and let you know what maintenance will need doing soon. But there's no point in having the engine rebuilt if there's nothing wrong with it. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 17, 2011 How many kms is high milage to you? I wouldn't be considering it until at least 400k depending on it's past lfe Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted July 17, 2011 (edited) it isn't this one is it? http://www.bimmersport.co.nz/forums/index....t=0&start=0 second hand engines are about 3k on trademe Edited July 17, 2011 by bbs Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted July 17, 2011 (edited) HellBMW would do you a better deal than getting a rebuild, do the change as well. Talk to Ray. Edited July 17, 2011 by Silver Fox Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted July 17, 2011 Ray had a moderate 70 ish km engine just a few weeks ago. PM him. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted July 17, 2011 (edited) dont bother unless you need to , these engines will do plenty of miles as long as they are kept cool and oiled well . just go over the coolant system , replace all old plastic water pipe parts , water pump and thermostat. also service the trans while you are at it . trans will fail/wear out before the engine does. about $3k for a good used engine. a full rebuild could cost a lot more and not really need it unless the engine has been cooked or run out of oil , or had lack of oil changes which causes excess wear in the engine. Edited July 17, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Aslan 0 Report post Posted July 17, 2011 How many kms is high milage to you? I wouldn't be considering it until at least 400k depending on it's past lfeIt's at 198,000kms. So it doesn't really need it yet? it isn't this one is it? http://www.bimmersport.co.nz/forums/index....t=0&start=0 second hand engines are about 3k on trademe Yes, but the most recent one in there. The black one from Precision Automobiles. Quote Share this post Link to post Share on other sites
