richard 384 Report post Posted December 23, 2011 my new project , pics and detail to follow as i start .................may take some time..... Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted December 23, 2011 Cool. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 27, 2011 Right, this was yesterdays effort.......today heatgun ,chisle and ( beer to help with the bordom of scraping off that tar stuff ) Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted December 27, 2011 A good start, time for a beer! Nice looking steering wheel - not seen one like that before, you do seem to be missing a third pedal though ? Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 27, 2011 Wow, whats been happening under the carpet! Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 27, 2011 A good start, time for a beer! Nice looking steering wheel - not seen one like that before, you do seem to be missing a third pedal though ? going to fix the pedal problem with this ......... i started buying parts when the USD was over80cents... have more onthe way Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 27, 2011 (edited) Wow, whats been happening under the carpet!lots of dirt thats got wet, was in storage, the window was broken . Edited December 27, 2011 by rich Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 27, 2011 Ah ha. So what is the plan with this car, are you using a non motorsport E36 coupe + S50? Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 27, 2011 Ah ha. So what is the plan with this car, are you using a non motorsport E36 coupe + S50? yup thats the plan at the moment Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 27, 2011 and are toying with this package from TMS.......................... E36 Turner Motorsport Group N/World Challenge Coil Over Suspension Part #: E36TMSWC Developed by TMS for our own E36 racecars, this kit gives you everything you need to bolt on a winning suspension! Front Bilstein Group N coil over struts are valved to our specifications and used with H&R race springs (Moton, double and triple-adjustable shocks are also available). TMS aluminum front camber plates and solid suspension bushings have also been developed by our race engineers to work with this kit. In the rear we use a Bilstein Group N shock and an inboard 60mm H&R Race spring with a ride height-adjustable spring perch. Turner Motorsport swaybars are recommended for use in the front and the rear. This is a professionally developed kit that puts you in a winning car from turn one. The suspensions we put together are complete and ready-to-race and have had every component planned out and designed to work with together. Stage 1 Basic Group N Suspension – shocks, springs p/n E36GPNSUSPENSION $2002.30 Includes: Bilstein Group N coil over front struts (pictured above), Group N rear shocks (non coil-over), 60mm H&R racing springs, rear height adjusters, spring hardware and seats Suggested add-ons: camber plates, shock mounts, sway bar / swaybars, reinforcements, rear camber arms Stage 2 Bolt-In Group N Suspension – shocks, springs, mounts, camber plates p/n TSU36GPN-2 $2522.20 Includes: Bilstein Group N coil over front struts (pictured above), Group N rear shocks (non coil-over), 60mm H&R racing springs, Turner front camber plates, Turner solid bearing rear shock mounts, rear height adjusters, spring hardware and seats Suggested add-ons: sway bar / swaybars, reinforcements, rear camber arms Reinforcement Package p/n T36REINF $additional, see Options below Includes reinforcements for: front subframe, front strut towers (requires modification with camber plates), rear sway bar / swaybar tabs, rear shock towers, rear subframe (not needed for M3 chassis) Aluminum Mount Package p/n T36MOUNT $1150.70 additional Includes: aluminum engine and transmission mounts, Delrin front control arm bushings, aluminum rear trailing arm bushings (RTABs), aluminum inner trailing arm bushings, Delrin and aluminum differential mounts, aluminum subframe mounts Other suggestions – Moton Motorsport shocks aluminum front control arms adjustable sway bar / swaybar links BMW x-brace Because of the complexity and wide range of options for this suspension the cost will vary. Items are also available for purchase separately. Call or e-mail for the most accurate pricing specific to your needs. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 28, 2011 Sounds like your onto it. In someways I am doing much the same thing with my E36, a lot of it needs to be upgraded to M3 hardware... which is the plan for 2012. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted December 28, 2011 going to fix the pedal problem with this ......... i started buying parts when the USD was over80cents... have more onthe way Yup, that should fix it!! Some nice goodies there Rich, will make a pretty serious package when it is all together. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 28, 2011 A good start, time for a beer! Nice looking steering wheel - not seen one like that before, you do seem to be missing a third pedal though ? Its a tech2 wheel. pretty rare in this part of the world though! available for E30 and E34 P-FL as well Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 28, 2011 (edited) Its a tech2 wheel. pretty rare in this part of the world though! available for E30 and E34 P-FL as well keep or sell the smilyface was a combnion of my bad photoing plus sun ...................... but like to think the car is smiling at the chance to get out on the track. Edited January 2, 2012 by rich Quote Share this post Link to post Share on other sites
3series 0 Report post Posted December 28, 2011 keep - they're an awesome feeling wheel. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted December 29, 2011 Are you linking the S50? Assume so as it'll be a right pain to get it going without the EWS, well it won't go at all. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 29, 2011 Are you linking the S50? Assume so as it'll be a right pain to get it going without the EWS, well it won't go at all.have all the necessary parts ECU , EWS, and microchip from the key . Got it from Hellbm . Quote Share this post Link to post Share on other sites
westy 614 Report post Posted December 29, 2011 have all the necessary parts ECU , EWS, and microchip from the key . Got it from Hellbm . Good work. Will be watching with interest. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted December 30, 2011 have all the necessary parts ECU , EWS, and microchip from the key . Got it from Hellbm .Oh yup, all good, would have been a right vagina getting all the neccercary bits from the states. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 30, 2011 keep - they're an awesome feeling wheel. But not very good for motorsport, My suggestion would be change it out for a suede steering wheel around 330mm This will give you a quick steering response and have the grip to match your race gloves and doesn't sweat. If your starting from scratch I would suggest swapping the steering rack form a z3 1.9ltr one.. 2.7 turns A lot better Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 30, 2011 I would suggest swapping the steering rack form a z3 1.9ltr one.. 2.7 turns A lot better I shall use your advise. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 30, 2011 Some info on it. I did this to my e30 and its an amazing upgrade. http://www.318ti.org/forum/showthread.php?t=12941 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 30, 2011 (edited) because i have lots of time on my hands i been looking for parts , do you think this is value for the money Race / Rally lightweight polycarbonate window kit BMW E36 Coupe - Polycarbonate window kit 5 piece fully thermoformed kit Manufactured from Lexan Exell-D or Makrolon UV high quality glazing polycarbonates the kit includes 1 X REAR SCREEN (Thermoformed) 2 X REAR 1/4 WINDOWS (thermoformed) 2 X FRONT DOOR WINDOWS (Thermoformed) All windows are fully thermoformed and have the same external curvature as the OEM glass items. Price £342.00 (+ 20% VAT) THICKNESS & COLOUR 3mm Clear Polycarbonate 4mm Clear Polycarbonate 4mm Glass Green Polycarbonate (+ £51.30) 4mm Bronze polycarbonate (+ £41.04) 4mm Grey polycarbonate (+ £41.04) 5mm Clear Polycarbonate (+ £34.20) 5mm Glass Green Polycarbonate (+ £85.50) 5mm Bronze polycarbonate (+ £75.24) FRONT DOOR WINDOW TYPE Standard 1 Peice Door Window REAR 1/4 WINDOW TYPE Oversize 1/4 Window to Bond/Bolt in Opening 1/4 Windows + Mounting Holes REAR WINDSCREEN TYPE Standard Rear Screen to Bond in SCREEN BORDER Plain Finish - No Border Applied + Black OEM Border to Rear Screen (+ £15.00) + Border Applied to Rear 3 Windows (+ £35.00) SLIDER KITS No Slider Kits 1 x Budget Slider Kit (Drivers Side) (+ £35.00) 2 x Budget Slider Kits (+ £60.00) RIGHT OR LEFT HAND DRIVE Right Hand Drive Left Hand Drive 1 2 3 4 5 6 7 8 9 10 Edited December 30, 2011 by rich Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 30, 2011 But not very good for motorsport, My suggestion would be change it out for a suede steering wheel around 330mm This will give you a quick steering response and have the grip to match your race gloves and doesn't sweat. If your starting from scratch I would suggest swapping the steering rack form a z3 1.9ltr one.. 2.7 turns A lot better thanks for the advice , will keep a lookout for one .... Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 30, 2011 (edited) Wow, going as far as weight saving on the window glass. You're not mucking around! I'd go for the thermo formed poly, keeping the original glass curvature would make all the difference in the quality when it's a finished track car. Depends how extensive your budget is though... care to share how much you expect this build to reach? Edited December 30, 2011 by V8E36 Quote Share this post Link to post Share on other sites
