APT 205 Report post Posted September 30, 2012 Very interested to see how the MAF goes! Please keep us updated Quote Share this post Link to post Share on other sites
Top Secret 2 Report post Posted September 30, 2012 Would also be interested to see the results! By the time you invest in a chip, induction, MAF, exhaust etc, how far is it off the cost of a M50B25? Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted September 30, 2012 Would also be interested to see the results! By the time you invest in a chip, induction, MAF, exhaust etc, how far is it off the cost of a M50B25? I'm not sure, but if I was going to go to the trouble of an engine swap I'd go for a M52B28 or M54B30 as I think these are a lighter engine, although somehow i'd end up wishing I'd gone for an M62 V8 regardless. I'm not convinced an M50 conversion is worth all the effort, although I have no plans to do a conversion at all. My car already has a pretty much straight through exhaust, it has twin pipes all the way with no muffers or cat and then its strangled at the end with a Magoo Mufflers single pipe muffer, (for now). Ultimately I'm more interested in the improved throttle response and drive ability. I'm retaining my stock airbox (Bigger South African version anyway) and have ordered the Miller Adapter so that I can attach the MAF to it. The installation process is rather easy https://www.millerperformancecars.com/files...20GEN%20III.pdf Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted September 30, 2012 yea good choice for bang for buck , i got another 16-18rwkw and about 40Nm more with the millar maf on my M5 m88 engine . sounds nice too. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted September 30, 2012 yea good choice for bang for buck , i got another 16-18rwkw and about 40Nm more with the millar maf on my M5 m88 engine . sounds nice too. Nice Dyno Video Brent, induction sound is awesome, those E28's are cool looking old cars for sure. I don't expect big gains from mine at this stage, but its there for when I do some upgrades and it will be interesting to see what a 234,000k M20B25 makes at the wheels. I'm guessing 95kw ATW at this stage. Typically, now that the cars been converted to manual I have more interest in improving performance. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted September 30, 2012 induction sound with MAF on M20 Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 1, 2012 Booked Dyno for Baseline run on Saturday, however on my drive home from work today I noticed a nasty drive line vibration, hopefully its just the Centre support bearing.. always something hehe Quote Share this post Link to post Share on other sites
Matt127 0 Report post Posted October 5, 2012 I'd be really interested in how you go with your WAR chip. I have one on my e30 as well, along with the MAF conversion. I found it to be generally pretty good. Power gains on WOT were a bit dissapointing as it was a standard car other than a K&N panel filter, but i think it went from maybe 105kw at the wheels to about 107kw. The best gains on WOT were in the mid range and they were about +5kw. Generally I found the M20 to be pretty dull to changes though. I could move the timing and fuel alot both ways and it would only change the power slightly. I'm no professional tuner however. I just had access to a dyno and did it myself. The base tunes Miller give you are pretty good and really only need fine tuning. Oh yea and remember you MUST use Win XP with it. I had all sorts of troubles trying to use anything else, even virtual XP. Also check your TPS with a multimeter both when its running and just with the key on. I spent along time wondering why i was making changes to the WOT map and nothing was happening. Apparently its a very common issue that becomes more noticable with the new MAF. Hope those things are of some help anyway, I got a little frustrated with mine initially. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 5, 2012 Part of the reason I'm doing the conversion is that I suspect the AFM is a bit passed its use by date, but I'll know tomorrow morning once I do a stock Dyno run. I suspect the W.A.R chip tuning is more worth while once you add bigger injectors, better cam etc. I have not ordered the war chip part of it as yet, just the MAF with chip for a stock M20B25. Cheers Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 5, 2012 1st Dyno run completed, 102kw at the wheels, pretty good for a 23 year old stock standard E30 325i. It got a bit rich in the top end, 11.9 AFR, but low and mid range was pretty much Spot on apparently. Uploaded with ImageShack.us Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 12, 2012 No Real progress to speak of, Miller haven't sent me my MAF conversion yet, that is they haven't replied to me emailing them asking if its on its way.. Ordered some boring parts from autohausaz, the engine and gearbox mounts, to attempt to fix a non driveline related vibration. 1 03195 Distributor Cap 1 04156 Distributor Rotor; Triangular Bolt-On Type, 3 Bolt 1 10X825 V Belt/Drive Belt; Power Steering 1 10X965 V Belt/Drive Belt; Alternator 1 11311280960 Timing Belt Guide; Tensioner Pin (between tensioner and water pump) 1 11311468743U Timing Belt Tensioner 1 11311469240 Timing Belt 1 11511719836 Water Pump; With Gasket 2 11811132323MY Engine/Motor Mount; Left/Right 2 23701141614 Transmission Mount 1 51231906286 Shock/Strut, Hood Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 12, 2012 took a while for my one to come too , but they had run out of stock , but didn't return emails either , no replys untill i phone'd them Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted October 14, 2012 No Real progress to speak of, Miller haven't sent me my MAF conversion yet, that is they haven't replied to me emailing them asking if its on its way.. Ordered some boring parts from autohausaz, the engine and gearbox mounts, to attempt to fix a non driveline related vibration. 1 03195 Distributor Cap 1 04156 Distributor Rotor; Triangular Bolt-On Type, 3 Bolt 1 10X825 V Belt/Drive Belt; Power Steering 1 10X965 V Belt/Drive Belt; Alternator 1 11311280960 Timing Belt Guide; Tensioner Pin (between tensioner and water pump) 1 11311468743U Timing Belt Tensioner 1 11311469240 Timing Belt 1 11511719836 Water Pump; With Gasket 2 11811132323MY Engine/Motor Mount; Left/Right 2 23701141614 Transmission Mount 1 51231906286 Shock/Strut, Hood Have you placed the order yet..Im ordering as well could share the freight costs Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 14, 2012 Have you placed the order yet..Im ordering as well could share the freight costs Doh, sorry bud, already ordered on Friday, the shipping is always the killer eh, next time I'll ask you if you want anything. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 20, 2012 took a while for my one to come too , but they had run out of stock , but didn't return emails either , no replys untill i phone'd them Looks like its time to call them. I was eager to get that installed too.. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 20, 2012 Box of Parts arrived on Friday that I'd ordered about a week before. The main thing of interest for me, the new Engine and Gearbox Mounts. Also pictured is a new bonnet strut, it was only about $5, so I thought, why not, mines stuffed. Not sure if you can see on this Pic, but in real life the engine mount looks squashed. New Dizzy Cap and Rotor As you can see, the engine needs a bit of a clean, oneday hehe. Hopefully after the engine mounts are installed in the next couple of days I rid the car of an annoying vibration issue which happens when driving or when sitting idle at the traffic lights with the car in Neutral, ie not drive train related. I suspect it will help as if you get someone to rock the engine while its running the vibration you feel in the car changes. I also have a new waterpump, cambelt, tensioner, however I forgot to order some new oil seals that I will change while doing this job, but I think i'll just get those locally. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 23, 2012 Today I ordered B12 Pro-Kit Suspension (Joint effort between Eibach and Bilstein) I went with this as I wanted the car to retain a level of Comfort while at the same time improve the handling. They claim its tested at Nurburgring and fine tuned etc. http://www.performance2.info/b12-pro-kit-en I heard back from Miller about my MAF conversion, it turns up the hold up is due to the adapter plate not being in stock (that attaches the MAF to the factory airbox) so I told them to delete it and refund me for that and just send the MAF and Chip. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 28, 2012 Replaced Distributor and Rotor a couple of days back. The old parts had seen better days for sure. The metal contacts, well they didn't look that good at all. Uploaded with ImageShack.us I have spent the weekend messing around with the valve adjustment, yesterday I only succeeded in making it worse, however I re-did it today and took my time and made sure all were adjusted correctly. As you can see the inside of my engine is .. dirty. Uploaded with ImageShack.us Uploaded with ImageShack.us Not sure what to do about that, however it is running well now. It sounds a lot better then a week ago, ie http://www.youtube.com/watch?v=0650jtAQzTU Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted November 3, 2012 Miller Maf conversion complete, well sort of. Its working, but cruising around I can detect a slight miss and its hesitant down low. Currently I only have a pod filter on the MAF, so I need to sort something out about cold air. But I did a WOT run to demonstrate the Intake sound, http://www.youtube.com/watch?v=RUMviHzE2lU...eature=youtu.be Quote Share this post Link to post Share on other sites
APT 205 Report post Posted November 3, 2012 Do you feel a difference after the MAF conversion? Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted November 3, 2012 (edited) Do you feel a difference after the MAF conversion? Its made the drive ability worse, which means I have a problem somewhere, I need to check the voltage going to the MAF etc and see that all is well. According to Miller if the TPS has an issue it can cause running problems once using the MAF, so thats another thing to test out. I can't discount Vacuum leaks too. The car almost wants to bunny hop if you idle along too slow in 1st or Second gear. Edited November 3, 2012 by Charles32 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 3, 2012 my one wouldn't run right untill i had it remapped , the std millar maf tune was way off . Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted November 3, 2012 my one wouldn't run right untill i had it remapped , the std millar maf tune was way off . Yeah, they claim to have perfect maps, but they will be for the US version of my car with only 8:8-1 Compression etc. SA built one like mine is 9.4-1, factors like that could throw it off for sure, also my car doesn't have a Cat or O2 sensor and I suspect the USA cars all do. I will replace my intake boot and vac hoses anyway, as the intake boot has signs of cracking around the pieces that connect to ICV etc and get it back on the Dyno Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 3, 2012 Yeah, they claim to have perfect maps, but they will be for the US version of my car with only 8:8-1 Compression etc. SA built one like mine is 9.4-1, factors like that could throw it off for sure, also my car doesn't have a Cat or O2 sensor and I suspect the USA cars all do. I will replace my intake boot and vac hoses anyway, as the intake boot has signs of cracking around the pieces that connect to ICV etc and get it back on the Dyno also if you unplug the vac hose going to the fuel pressure reg and block it up. that will increase fueling a bit , might make it a bit more driveable (and safe) until you get the ecu remaped etc Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted November 3, 2012 also if you unplug the vac hose going to the fuel pressure reg and block it up. that will increase fueling a bit , might make it a bit more driveable (and safe) until you get the ecu remaped etc I'll give that a go, that vac hose is a bit dodgy, its got a T-Join in it with a screw adjuster. Perhaps I should replace that hose with a normal one 1st. My ECU has a separate black box attached to it also, with about 5 wires going to it and the ECU itself has a sticker about Homologation from dated 1999. The car came with cruise control, so perhaps that black box is to do with that, the wires from it don't go to the ECU. Quote Share this post Link to post Share on other sites
