3 SERIES 93 Report post Posted April 26, 2012 The E30 seems to take a while to warm up. Tends to take 5-10 mins, about 5km before the it reaches temperature. I have recently replaced the thermostat which did make it better bit still seems to take some time. Is this normal? All help/info would be appreciated. Cheers Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 26, 2012 (edited) Yea that's about the norm. All Of mine have taken about that, because it's a cast iron block. You'll notice it stays warm for a long time after its turned off too Edited April 26, 2012 by euroriffic Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted April 26, 2012 Mine was exactly like that too, was always wondering the same myself. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted April 26, 2012 If this is the best issue you can give us then e30 ownership has been treating you very well Brett! Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted April 28, 2012 If this is the best issue you can give us then e30 ownership has been treating you very well Brett! Ha ha cheers Max. Has a few little things that require attention but nothing major. Should really start a project thread. Will give me a bit of motivation to get the bits n pieces done. Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted April 28, 2012 So does anyone have any ideas on this? Or is it really the norm? Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted April 28, 2012 It won't be due to cast iron block because my S50 is cast iron and it takes just over a KM to be at operating temp. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 28, 2012 It won't be due to cast iron block because my S50 is cast iron and it takes just over a KM to be at operating temp. That's crazy, my alloy m52 takes an age to warm up. By the time I drive to work which takes about 15mins it's only at about a quarter. Makes cold mornings suck haha. Good thing the m44 takes mare seconds. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted April 29, 2012 So does anyone have any ideas on this? Or is it really the norm? I think it may just be the norm, my E30 is the same despite having a new thermostat. Not that it's in tip-top shape, but it normally isn't warm for at least 6kms. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted April 29, 2012 That's crazy, my alloy m52 takes an age to warm up. By the time I drive to work which takes about 15mins it's only at about a quarter. Makes cold mornings suck haha. Good thing the m44 takes mare seconds.Cooling system is a cooling system, no difference in how they work between the models. Mine is super fast at warming up but thought that was just normal. Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted April 29, 2012 My petrol cars warm up super fast, but the diesel takes longer though. My e46's needle leave the blue zone as I reverse out of the driveway and will reach the middle in two blocks (~500m). I can get warm-air from the vents as soon as I drive off. Gotta love instant heat in winter. My other previous Bimmers (e46 compact and e36) are slightly slower but not far off. Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted April 29, 2012 The gauges have a designed "normal" range. The engine temp fluctuates, and the "normal" position is always displyed over a range of engine temperatures. I know the gauge in M54 powered cars shows normal over a very wide temperature range - seemingly from mid 70's to abou 115C! Hence their intolerance to being "overheated"! An E30 probably doesn't show "normal" until it's near or into the 80's, so might actually show normal much later than an M54 powered car, even though the M54 is actually at a cooler temp. I guess the short answer is that the gauges are NOT linear. Older cars used to show the temperature fluctuations of the engines, but it started to worry people, so the curve of the gauge was altered to hide them. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted May 2, 2012 As far as I know the E30 gauges do not register until 80, and normal is about 90 degrees. I still don't like the idea of driving "spiritedly" until it's at least above 1/4 on the gauge! Quote Share this post Link to post Share on other sites
adams202 1 Report post Posted May 3, 2012 Sounds normal to me - my m20 takes about the same amount of time to get a proper spring in her step. So if you've got a problem.... then so do I Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted May 3, 2012 Ever BMW ive owned has warmed up by the end of the road which is 2km and takes about 2mins (2\3 80kph & 1\3 60kph zone) Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted May 3, 2012 I agree with Jared..all my e30s warm quickly THe question is tho..Is it an issue?? I know Brett wonders if it may be contributing to high fuel consumption Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted May 4, 2012 (edited) Well I know mine is pretty dissapointing on fuel, I struggle to keep it under 11L/100kms around town, but I thought maybe that was just the go with a 320i. Although mine also has a very low diff so maybe thats contributing. Perhaps time for a new thermostat. (Although Brett has already done this so it won't help him!) Maybe there are other aspects that need investigating, are all the coolant lines as they should be and in good condition? I know my thermostat housing was broken when I got the car, so one of the coolant lines was just plugged Edited May 4, 2012 by huff3r Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted May 4, 2012 When I got my E34 the thermostat was pried open with a screwdriver ROFL. has your car had it's AC Removed? I have wondered if the bigger AC radiator is "too" big. (even though it shouldn't matter) Quote Share this post Link to post Share on other sites
