SRBMW 6 Report post Posted June 30, 2012 (edited) Hey guys got a few bits for sale 97 M3 3.2 Engine with 11,000 miles with full history and replacement reciepts totaling 40k with loom headers ecu etc $8000 ONO 97 6 speed gearbox with X member and driveshaft and shifter $1700 M3 Evo lower wishbone arms $400 pair M3 Evo front brakes with spindles calipers and factory two piece 315mm rotors. $450 M3 Evo FRont brakes with spindles calipers and curve slotted rotors with near new EBC red pads $550 M3 Evo steering rack $300 M60 M62 V8 5 Speed ZF gearbox from E34 535i V8 $1900 with shifter and crossmember E36/E46 Getrag 220 with Shifter and crossmember $500 E30 Getrag 240 Box Suit M40 $300 E30 Getrag 240 Box suit M20 $300 E30 318is getrag 240 suit m42 engine $400 Cheers Darren 0211645663 Edited July 23, 2012 by SRBMW Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted July 3, 2012 update V8 ZF box added Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 4, 2012 (edited) if the price comes down on the M40 G240 gearbox its mine. kms etc? Edited July 4, 2012 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted July 4, 2012 You wouldn't have any 188mm lsd centres? Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted July 4, 2012 if the price comes down on the M40 G240 gearbox its mine. kms etc?PM me thanksYou wouldn't have any 188mm lsd centres? Hi yes I do what ratio diff were you trying to fit it to and model e30, e36? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted July 4, 2012 3.15 to 3.45 (I haven't yet decided) Would be to suit an e36 What is the difference between the centres? Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted July 4, 2012 3.15 to 3.45 (I haven't yet decided) Would be to suit an e36 What is the difference between the centres? The centres for E30 and E36 are both 188mm. Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted July 4, 2012 3.15 to 3.45 (I haven't yet decided) Would be to suit an e36 What is the difference between the centres? There is two different offsets in the centres- in the e30's there is one offset that will do 2.79 and 2.93 and then another that will go from there up to 4.3. However for some reason I'm pretty sure in the past I've found the e36 3.15 to need the lower 2.79/2.93 offset. I didn't look into it closely but they may have a different amount of pinion and crownwheel teeth.-just need to whip off the back cover and measure really. cheers Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 5, 2012 Interesting, how common is a 3.15 gear set? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 5, 2012 Interesting, how common is a 3.15 gear set? I'm running 3.15 LSD Medium case in the Ti Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted July 5, 2012 Interesting, how common is a 3.15 gear set? Pretty common esp in E36 Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted July 5, 2012 z3 M-coupe run it So do I -- If its a 5 speed 'e36/2' m motor, it will more than likely be 3.15 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 6, 2012 I have 3.45 at the moment with getrag 240. So the 3.15 gear set wont fit onto a E30 LSD center? Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted July 6, 2012 I have 3.45 at the moment with getrag 240. So the 3.15 gear set wont fit onto a E30 LSD center? It will fit fine both 188mm but just need to make sure you get the correct offset centre. Are you talking e30 or e36? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 7, 2012 E30. Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted July 10, 2012 E30. For E30 you should be fine with the normal offset one. I'll have a centre available soon that will have had extra clutches added and tightened ready to install in a diff. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 10, 2012 I already have a few LSD diffs, was just looking at what different ratios were avalaible and what fitted etc. Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted July 23, 2012 Update V8 ZF box now has shifter and crossmember also 318is E30 getrag 240 box added Quote Share this post Link to post Share on other sites
