SRBMW
M3 Evo 3.2 Engine+ Box, E36 E30 + V8 gearboxes
Hey guys got a few bits for sale
97 M3 3.2 Engine with 11,000 miles with full history and replacement reciepts totaling 40k with loom headers ecu etc $8000 ONO
97 6 speed gearbox with X member and driveshaft and shifter $1700
M3 Evo lower wishbone arms $400 pair
M3 Evo front brakes with spindles calipers and factory two piece 315mm rotors. $450
M3 Evo FRont brakes with spindles calipers and curve slotted rotors with near new EBC red pads $550
M3 Evo steering rack $300
M60 M62 V8 5 Speed ZF gearbox from E34 535i V8 $1900 with shifter and crossmember
E36/E46 Getrag 220 with Shifter and crossmember $500
E30 Getrag 240 Box Suit M40 $300
E30 Getrag 240 Box suit M20 $300
E30 318is getrag 240 suit m42 engine $400
Darren 0211645663
Edited by SRBMW
if the price comes down on the M40 G240 gearbox its mine. kms etc?
Edited by _Ethrty-Andy_
PM me thanks
You wouldn't have any 188mm lsd centres?
Hi yes I do what ratio diff were you trying to fit it to and model e30, e36?
3.15 to 3.45 (I haven't yet decided)
Would be to suit an e36
What is the difference between the centres?
The centres for E30 and E36 are both 188mm.
There is two different offsets in the centres- in the e30's there is one offset that will do 2.79 and 2.93 and then another that will go from there up to 4.3. However for some reason I'm pretty sure in the past I've found the e36 3.15 to need the lower 2.79/2.93 offset. I didn't look into it closely but they may have a different amount of pinion and crownwheel teeth.-just need to whip off the back cover and measure really. cheers
Interesting, how common is a 3.15 gear set?
I'm running 3.15 LSD Medium case in the Ti
z3 M-coupe run it
So do I :) -- If its a 5 speed 'e36/2' m motor, it will more than likely be 3.15
I have 3.45 at the moment with getrag 240. So the 3.15 gear set wont fit onto a E30 LSD center?
It will fit fine both 188mm but just need to make sure you get the correct offset centre. Are you talking e30 or e36?
E30.
For E30 you should be fine with the normal offset one. I'll have a centre available soon that will have had extra clutches added and tightened ready to install in a diff.
I already have a few LSD diffs, was just looking at what different ratios were avalaible and what fitted etc.
