CSET 602 Report post Posted June 3, 2017 15 minutes ago, Funkyflynz said: Cool, are they doing a custom tune or is it just to check fault codes and program them out? I'd planned to just disable the o2 sensors before & after the cats mate - not sure whether there's much to be gained from this motor tbh. That said, as it's booked in anyway and there is no codes, we'll see what happens..! Quote Share this post Link to post Share on other sites
Funkyflynz 151 Report post Posted June 3, 2017 I wonder about the value of tunes as well, but there seems to be a consistent flow of positive feedback from those that get tunes. HellBM have a $400 tune for the community that apparently nets a few more HP's. But from what I have read the best mod is to put in 4.10 gears. Really keen to see how you get on. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted June 3, 2017 3 hours ago, CSET said: I'd planned to just disable the o2 sensors before & after the cats mate - not sure whether there's much to be gained from this motor tbh. That said, as it's booked in anyway and there is no codes, we'll see what happens..! Pre are used for fuel trim so not a good idea to remove/disable Plenty of HP left out of the stock tune. 2 Quote Share this post Link to post Share on other sites
Funkyflynz 151 Report post Posted June 4, 2017 (edited) 1 hour ago, HaNs said: Pre are used for fuel trim so not a good idea to remove/disable Plenty of HP left out of the stock tune. Hey Hans, as i read it manufacturers will tune an engine to run much richer than required for optimal performance, this is so its safe and meets emissions, for cats to work they require a fairly rich mixture. Thus removing cats and leaning out the mixture will net gains for most modern engines correct? Be interested to hear your experience on this. Not wanting to hijack CSET's thread, but would you recommend an off the shelf after market tune? or is a custom tune the only way to go? Edited June 4, 2017 by Funkyflynz Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted June 4, 2017 5 hours ago, Funkyflynz said: Hey Hans, as i read it manufacturers will tune an engine to run much richer than required for optimal performance, this is so its safe and meets emissions, for cats to work they require a fairly rich mixture. Thus removing cats and leaning out the mixture will net gains for most modern engines correct? Be interested to hear your experience on this. Not wanting to hijack CSET's thread, but would you recommend an off the shelf after market tune? or is a custom tune the only way to go? Id suggest to go read about Stoich and air fuel ratios. Have a look at what AFR makes the most torque and what is best fuel economy. Also lowest emissions. Cats are an after treatment and AFR should really be measured before them. Off the shelf is ok. Custom is better. Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted June 7, 2017 On 6/4/2017 at 8:14 AM, CSET said: I'd planned to just disable the o2 sensors before & after the cats mate - not sure whether there's much to be gained from this motor tbh. That said, as it's booked in anyway and there is no codes, we'll see what happens..! Welp seemed I was wrong! There was apparently a flat spot from 2 - 3,500rpm, and it had thrown a code having the cats removed (despite no CEL yet). NZPT have addressed both of these things and had a play with some other bits and bobs that I won't even try and understand. I've yet to drive the car past moving it back & forth, but according them it's a fair bit better at low rpm. They're quietly confident they've gained a little power & torque from it too, but it won't be a huge amount. Looking forward to when I can get a chance to drive it! Quote Share this post Link to post Share on other sites
Funkyflynz 151 Report post Posted June 7, 2017 20 minutes ago, CSET said: Welp seemed I was wrong! There was apparently a flat spot from 2 - 3,500rpm, and it had thrown a code having the cats removed (despite no CEL yet). NZPT have addressed both of these things and had a play with some other bits and bobs that I won't even try and understand. I've yet to drive the car past moving it back & forth, but according them it's a fair bit better at low rpm. They're quietly confident they've gained a little power & torque from it too, but it won't be a huge amount. Looking forward to when I can get a chance to drive it! I would assume if its been tuned they should be able to show you a printout of the HP and Torque curves before and after, surely they don't tune it based on their "bum dyne" do they? Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted June 7, 2017 Iono, it's all dark magic to me. Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted June 22, 2017 Had a good little home project tonight, retro-fit an M Performance shifter & boot to my e46. The brackets from the M2 are quite different to the e46, so it took some fiddling but I got there in the end. Here's a pic & a vid (I have a BMW Performance short shift kit installed now too). Untitled by Christian Taylor, on Flickr 2 Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted June 24, 2017 New project underway! I'm having a diffuser setup for the underbody designed, starting at the rear. I pulled the bumper this morning - it was pretty dusty under there. I suppose 100km of gravel on the last rally had it's downsides...! I hope to have a mock up designed over the next couple of weeks, then manufacture & fitting before we start on the front. Good fun! Untitled by Christian Taylor, on Flickr Untitled by Christian Taylor, on Flickr 1 Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted October 10, 2017 Been pretty quiet on this build for a while, ran a bearing back in June so it's been up with Kayne Barrie for a rebuild. Couple of shots while the master was at his work: 20884884_1507597005930171_650205220_n by Christian Taylor, on Flickr 20904324_1507597182596820_1871693703_o by Christian Taylor, on Flickr 21684668_1535529916470213_553786645_o by Christian Taylor, on Flickr 21845349_1535529956470209_768997783_o by Christian Taylor, on Flickr New crank, gaskets, bearings etc. Untitled by Christian Taylor, on Flickr Untitled by Christian Taylor, on Flickr Kayne replaced the clutch and got the guys at Autospeed Engineering in Pukekohe to recondition the head: 20891530_1507597055930166_44621757_n by Christian Taylor, on Flickr Back now, and looking pretty good sitting in decent company..! IMG_3720 by Christian Taylor, on Flickr 6 Quote Share this post Link to post Share on other sites
Funkyflynz 151 Report post Posted October 10, 2017 Does it feel any different after the freshen up? Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted October 10, 2017 56 minutes ago, Funkyflynz said: Does it feel any different after the freshen up? It's definitely quieter, no rattle on cold start (Kayne refreshed Vanos too) and generally runs a lot smoother. It does seem to pull a bit harder, tho that might be due to dailying a Kia for the past few months (anything would seem fast in comparison..!) 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 10, 2017 Kayne is the man. Why did you replace the crank? Was your old one stuffed? Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted October 11, 2017 22 minutes ago, zero said: Kayne is the man. Why did you replace the crank? Was your old one stuffed? Yep, must have been bad for a while Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 11, 2017 Yikes, a new crank would have cost a small fortune. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 11, 2017 Good job Christian, not exactly something you plan to fork out for, but at least it future proofs the engine for another 10 years+ and helps with resale value, if you part with it at some stage. Now to take it for some good open road drives! 1 Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted October 24, 2017 (edited) On 10/11/2017 at 7:44 PM, Michael. said: Now to take it for some good open road drives! First decent drive over the weekend, drove to Napier and back! Everything went well. Did some mild maintenance once we got there. Replaced battery (it's been a bit rubbish for a while), cleaned wheel speed sensors after they threw faults & fixed reversing sensors. Took a boot full of junk down, which ended up coming in quite handy. Untitled by Christian Taylor, on Flickr] Untitled by Christian Taylor, on Flickr Untitled by Christian Taylor, on Flickr Engine is running very nicely, tonnes of torque in the low & mid range and the fuel efficiency is heaps better. 650kms from a tank...! Best I had in the past is mid-500's. Chuffed. Edit: shot of it back together shortly afterwards. It's dirty, but it's not that bad given it drove to Napier and I didn't wash it down there..! If that doesn't convince you on ceramic coatings, I don't know what will haha Untitled by Christian Taylor, on Flickr Edited October 24, 2017 by CSET 2 Quote Share this post Link to post Share on other sites
Funkyflynz 151 Report post Posted October 24, 2017 Nice one, what do you put the additional power and economy down to? Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted October 24, 2017 17 hours ago, Funkyflynz said: Nice one, what do you put the additional power and economy down to? Probably a mix of the work done and the comparison with daily driving a Kia 4wd slug for a few months. 1 Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted November 10, 2017 Had the windows tinted on Wednesday by Autotintz with a dark layer under the Infinity OP 35% metallic film - hadn't seen this done before so was a bit of a gamble, but result is pretty good. Untitled by Christian Taylor, on Flickr Untitled by Christian Taylor, on Flickr Untitled by Christian Taylor, on Flickr Swapped wheels & bootlid last night in prep for summer - back on with the CSL 19's and carbon ducktail lid. MTOYPark by Christian Taylor, on Flickr MTOYPar2 by Christian Taylor, on Flickr MTOYPark3 by Christian Taylor, on Flickr 2 Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted November 10, 2017 its pretty much impossible to pick which set up I like more.. 1 Quote Share this post Link to post Share on other sites
*rUstY_nUts* 9 Report post Posted November 10, 2017 (edited) Luv the car without the wing Christian. Saw it, and heard it out at Villa Maria a couple of weeks ago Edited November 10, 2017 by *rUstY_nUts* 1 Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted November 10, 2017 (edited) That tint looks real nice. I need tints, after I had to rip off my 11% tint that my car came with (from Japan) when it failed a WOF Would you recommend that kind of metallic tint? How is it with phone/GPS signals? I like the reflective look and I would like my (black with black interior) car not to be like an oven after being parked outside in summer And your M3 will have frameless windows on the front as well, does the tint still look ok on that at the edges? Not worried it'll peel off? Edited November 10, 2017 by Matth5 Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted November 10, 2017 13 hours ago, Matth5 said: That tint looks real nice. I need tints, after I had to rip off my 11% tint that my car came with (from Japan) when it failed a WOF Would you recommend that kind of metallic tint? How is it with phone/GPS signals? I like the reflective look and I would like my (black with black interior) car not to be like an oven after being parked outside in summer And your M3 will have frameless windows on the front as well, does the tint still look ok on that at the edges? Not worried it'll peel off? Hi mate, I ran 35% Infinity OP for a year or so (check pics previous few pages) - that was legal and looked good imo. Can't remember turning the radio on in that time so I'm not able to comment on reception. Phone and GPS seemed to be ok. No lifting on edges that I could see, only reason I added to it was that I want it darker/ less see-through. 95%+ heat rejection will be gained from most films regardless of the opacity by the way, so 'darkness' doesn't necessarily equal more heat rejection. Suntek have a good website which explains this. 1 Quote Share this post Link to post Share on other sites
