APT 199 Report post Posted October 2, 2012 Going to do a battery to boot conversion this weekend, can anyone tell me where the factory grounding points are in the boot? Thanks team! Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted October 2, 2012 (edited) http://cache.gawker.com/assets/images/jalo...runkBattery.jpg http://vorshlag.smugmug.com/Projects/E30-V...576_o5Acz-M.jpg hope the pics help, was about to do the same, but CBF with a m40. does anyone know what that thing above the battery is, the thing with the wires? Edited October 2, 2012 by dubman Quote Share this post Link to post Share on other sites
APT 199 Report post Posted October 2, 2012 Thanks man! Do you know if all e30's have a grounding bracket? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted October 2, 2012 no idea tbh, but i don't think they all do, because from memory, mine doesn't Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted October 2, 2012 Only e30's that come original with a battery in boot have the grounding bracket. To convert mine i bought a short battery earth cable and bolted it to a secure point in the battery well. Quote Share this post Link to post Share on other sites
APT 199 Report post Posted October 2, 2012 Just checked mine doesn't have the bracket, will have to look into the wheel well. Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted October 2, 2012 Are you running a fuse or circuit breaker? if so what rating? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted October 2, 2012 When I did mine I got a slightly longer cable and used it on the rear bumper bolt, just sand some metal around it so it has good contact with the metal. Quote Share this post Link to post Share on other sites
APT 199 Report post Posted October 2, 2012 No not running any circuit breakers, I have got all the factory cables and stuff. Will give it a go this weekend and ill find an appropriate point, thanks for the help guys Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 3, 2012 Chuck an 80amp breaker on the ECU power cable. Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted October 3, 2012 Chuck an 80amp breaker on the ECU power cable.80 amp on ecu power??? Quote Share this post Link to post Share on other sites
