slowe30 0 Report post Posted November 16, 2012 today i started up my e36 after it sitting for about a week, and noticed it was ticking quite loudly, was about a 20 min drive so should have warmed up enough. its in the rear part of the valve train, so dont think it has anything to do with vanos. its very lid and car be heard through out the rev range (didnt rev it over 3.5k but it was still as loud if not louder as revs got higher). Is there anything that i should check out, like gummed up oil squirters or something along those lines? havent had a huge look into it yet but its loud enough for me to want to fix it asap. its got about 8k on the oil thats in it and im going to be replacing it this weekend as i had already planned to. would anyone recommend a engine oil cleaner solution to use? Cheers for any help Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted November 16, 2012 sticky lifter , change the oil run some engine flush stuff through it . then add some lifter quietner to it with new oil. Quote Share this post Link to post Share on other sites
slowe30 0 Report post Posted November 16, 2012 awesome, thats the info i was wanting. by lifter quitener, are you meaning proma mbl8? Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted November 16, 2012 something like this for engine oil flush http://www.wynns.co.nz/wynns-product.php?n...;s=15&id=68 http://www.wynns.co.nz/wynns-product.php?n...;s=2&id=207 and lifter treatment stuff http://www.wynns.co.nz/wynns-product.php?n...;s=15&id=70 Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted November 16, 2012 What oil is in the motor at the moment ?? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted November 16, 2012 something like this for engine oil flush http://www.wynns.co.nz/wynns-product.php?n...;s=15&id=68 http://www.wynns.co.nz/wynns-product.php?n...;s=2&id=207 and lifter treatment stuff http://www.wynns.co.nz/wynns-product.php?n...;s=15&id=70 didn't even know you could buy lifter treatment stuff, where do i get that from? Repcos? My M40 is really noisy, but cheaper to replace the engine when it becomes so had it than it is to sort out putting 8 new ones in Is it, oil oil out, new oil in, then add treatment and then replace oil again within 1000kms or..? Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted November 16, 2012 didn't even know you could buy lifter treatment stuff, where do i get that from? Repcos? My M40 is really noisy, but cheaper to replace the engine when it becomes so had it than it is to sort out putting 8 new ones in Is it, oil oil out, new oil in, then add treatment and then replace oil again within 1000kms or..? Repco or supercheap. Replace oil, add additive, wait til it stops working or you next change oil, add some more. It varies by brand, but some products can only be added once per oil change, others up to 3 times etc. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 16, 2012 Go see the mitsi dealer for tick control.... Mitsubishi make their own oil additive. Works boss. Quote Share this post Link to post Share on other sites
slowe30 0 Report post Posted November 16, 2012 was hoping it would be the mbl8 as i have some left over and its bloody expensive stuff, ill change it today or tomorrow after running the cleaner stuff through it and see how it all works, if it doesnt quite stop ill get some lifter treatment to use in it Quote Share this post Link to post Share on other sites
westy 614 Report post Posted November 17, 2012 I'd treat it to an Italian tune-up and see how it goes. Quote Share this post Link to post Share on other sites
euroriffic 616 Report post Posted November 17, 2012 Go see the mitsi dealer for tick control.... Mitsubishi make their own oil additive. Works boss. Hahaha they must of got wind of their cars being called mitsuticki!! Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 18, 2012 haha, yeah they use to sell MBL8 but, now they sell their own, in little aluminum cans with beer can pop rings. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted November 21, 2012 tried MBL8 on my M40, wasted $70. Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted November 21, 2012 tried MBL8 on my M40, wasted $70. M40 , most likly worn cams and rockers.you can normally see that through the oil fill hole Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted November 22, 2012 M40 , most likly worn cams and rockers. you can normally see that through the oil fill hole took the whole valve cover off and the shield plate thing off a few weekends back, cleaned up the oiler bar. bit of wear on the first first cam lobe and also either the 5th or 6th one, apart from that it looked good in there, especially for 245,000kms now. quietened down a lot after cleaning the oiler bar, but semms to be about as clakety as its always been again. Quote Share this post Link to post Share on other sites
