Greg111 13 Report post Posted January 3, 2013 That's a fair amount of pressure! We had an R32 GTR come into work a while back with no boost, got it sorted then went for a drive, guage was reading 29.3psi, needless to say it was insane! Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 3, 2013 That's a fair amount of pressure! We had an R32 GTR come into work a while back with no boost, got it sorted then went for a drive, guage was reading 29.3psi, needless to say it was insane! yes indeed that would wake it up some what i did a evo time attack car just before xmas with one of my holset's at 30 psi on pump gas made 450kw wheel and 640 ft/lb of torque we have yet to run it on e85 hoping if i havent screwed up too much should run high 500kw wheel or close to 900hp motor Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 11, 2013 when Bordom sets in make fly wheel to suit ORC double diaphragm clutch Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 13, 2013 and some hours later a 8.5 lb flywheel is born Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted January 13, 2013 and some hours later a 8.5 lb flywheel is born that looks very tasty.nice finish Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted January 14, 2013 I love engineering Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 14, 2013 and a nice set of BBS 18's AO48 for some track day/road fun never hurt Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted January 15, 2013 I like the wheels:) Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 15, 2013 I like the wheels:) i cant complain for freebies Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 28, 2013 desided to change turbos to one of the Holset Race Chargers im the importer for result was great comes on boost 500rpm sooner and gained 3 psi off boost theres more torque and topend still goes forever. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 28, 2013 desided to change turbos to one of the Holset Race Chargers im the importer for result was great comes on boost 500rpm sooner and gained 3 psi off boost theres more torque and topend still goes forever. Nice A mate of mine just brought an early E36 318is - I should really show him this I'm worried his Mrs will find out it was me though Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 28, 2013 Nice A mate of mine just brought an early E36 318is - I should really show him this I'm worried his Mrs will find out it was me though she may notice a slight change when she drives it for some reason lol Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted January 28, 2013 Looks good Steve. Although you're making the HX35 I've got for my 1JZ look small (proportionately). Has it still got the same 'hotside' as you had with the KKK? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 28, 2013 Looks good Steve. Although you're making the HX35 I've got for my 1JZ look small (proportionately). Has it still got the same 'hotside' as you had with the KKK? yes same hot side kkk has the same comp end dia as a small hx35 Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted January 29, 2013 An awful lot of what you say is like a foreign language to me but what little I understand sounds like a lot of fun!! Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 29, 2013 An awful lot of what you say is like a foreign language to me but what little I understand sounds like a lot of fun!! i think its pretty much foreign to most people on here lol but s.h.i.t loads of fun wait till ya see my other car Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted January 29, 2013 Cant wait to see that one!!!)) Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 1, 2013 headers for the e34 done Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted March 1, 2013 Wow, those look great! Can't wait to see pics & dyno of the finished product Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted March 1, 2013 is that stainless tube going to the mild steel merge? what size tube is that? Will you be bracing the turbo from the block? looking forward to seeing that exotic turbo mounted up Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 1, 2013 is that stainless tube going to the mild steel merge? what size tube is that? Will you be bracing the turbo from the block? looking forward to seeing that exotic turbo mounted up your correct the collector is mild steel runners are stainless purge welded, tube is 38mm it uses a rod end tie bar from top of rocker cover to turbo then one from the block up to the turbo. The turbo only weighs 5kg so not alot to worry about all manifolds crack at some point so i dont really care plus its being built to prove a point just like 318 turbo love making small minds look smaller Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 3, 2013 From what I hear and see you are very telented bro, that manifold looks real mean! Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 3, 2013 From what I hear and see you are very telented bro, that manifold looks real mean! Na its all rumours i just BS my way thru things..... 1 Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted March 3, 2013 Na its all rumours i just BS my way thru things.....Hahaha sure you do lol Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 3, 2013 straight up true dude...well most around here think its all smoke and mirrors Quote Share this post Link to post Share on other sites
