E30stz 0 Report post Posted September 24, 2005 (edited) Hey guys and girls What is the most effective way of getting rid of breakdust. My bottlecaps have a fair bit of breakdust on them and the only way to get it off seems to be to replace them. Cheers Andy Edited September 24, 2005 by E30stz Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted September 24, 2005 Tooth paste works a charm ... Quote Share this post Link to post Share on other sites
topless 14 Report post Posted September 24, 2005 Tooth paste works a charm ... ones with "extra whitening" should do even better then... Quote Share this post Link to post Share on other sites
Palazzo 514 Report post Posted September 24, 2005 Once it's thru' the clearcoat/lacquer (whatever), you're pretty much screwed. Really hard to get out, which is why I clean the basket weaves with a toothbrush (no toothpaste tho'. there's a thought), much to the amazement of the neighbours. Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted September 24, 2005 Seriously toothpaste does work a charm ... Some one told me to try it and it works well .. Quote Share this post Link to post Share on other sites
nath 174 Report post Posted September 24, 2005 oxalic acid works great, as does any other mag cleaning acid. Repco flog it off for $20 a spray container, which is the biggest ripoff in history. we use some green sh*t at work which is a mix of acid and detergent, works a charm. for the ones that it doesnt work on because the dirt is more oil, we use pink stuff that has more detergent in it, and some other multi cleaners, and it works well. Quote Share this post Link to post Share on other sites
topless 14 Report post Posted September 24, 2005 Seriously toothpaste does work a charm ... Some one told me to try it and it works well .. Toothpaste contains some sort of very fine grinding paste. I was told to use it once to remove some fine scratches from glass and it worked. Also, Brasso will work quicker but all of these will eventually go through the clearcoat. Be careful with acids, some will turn the clearcoat foggy. I use phosphoric acid to clean rims before I repaint them, mixed to about a 30% strength, and applied carefully with a toothbrush !! Quote Share this post Link to post Share on other sites
Jazzbass 1 Report post Posted September 25, 2005 Can mags (in general) be refurbished - cleaned and recoated? Quote Share this post Link to post Share on other sites
Jazzbass 1 Report post Posted September 25, 2005 Thanks for the email: The Mag & Turbo Warehouse is an approved insurance repairer. We can perform wheel repairs and refurbishing for all types of alloy wheels including European (BMW, Mercedes, Porsche), American and Japanese. Quote Share this post Link to post Share on other sites
Jimocles 0 Report post Posted September 25, 2005 Mr Muscle oven cleaner works a treat on greasy stuff good on engine bays as well Quote Share this post Link to post Share on other sites
Jazzbass 1 Report post Posted September 25, 2005 here's some more info: wheel care Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted September 25, 2005 here's some more info: wheel care good read. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 25, 2005 Avoiding brake dust is as easy as not using your brakes. Anyone know a good pad compound/brand that really is dustfree or dust-resistant that is a good performing road pad? Quote Share this post Link to post Share on other sites
Jimocles 0 Report post Posted September 26, 2005 I think you get them from that same place that has the magic tyres that never wear out and have great grip. I get asked for them all the time one or the other thems your options Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted September 28, 2005 I changed the OEM pads cause the dust was prolific, fitted PBR metal master pads all round about 75% less dust so pretty significant, pads cost $30 US a pair, E-bay, they need to warm up a little and sqwark a little until theyre warm. Quote Share this post Link to post Share on other sites
