Michael. 2313 Report post Posted March 9, 2014 G'day guys, I've been looking around for a suitable product to aid in pressing in my rear end suspension bushes, namely for the subframe etc, is there any particular lubricant for assembly I should be using - one thats readily available? From what I gather it should be water based, with no solvents, silicones or petroleum bases. Cheers Quote Share this post Link to post Share on other sites
jom 98 Report post Posted March 9, 2014 For assembling o rings where absolutely no contamination was allowed - water is the only way. it works pretty well if you can't find a non-destructive lubricant. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted March 9, 2014 Used Crc on mine, worked fine. And was told to use it from my workmate that's been racing, building and maintaining racecars for 30 odd years. 1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 9, 2014 yes Castrol make a synthetic rubber bush lubricant it's red and is relatively cheap ^^^^ This. We use it all the time 1 Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted March 9, 2014 Inox make a extreme pressure rubber grease called mx6. Works great. Last saw ot at FCO of all places gor about 8 bux Sent from my GT-I8160L using Tapatalk 2 Quote Share this post Link to post Share on other sites
RustyItalian 11 Report post Posted March 10, 2014 it should be water based, with no solvents, silicones or petroleum bases. I believe that the supermarket has a lube that meets those requirements ;-) Quote Share this post Link to post Share on other sites
jom 98 Report post Posted March 10, 2014 I believe that the supermarket has a lube that meets those requirements ;-) And the lemon scented one makes the car smell nice..... Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted March 10, 2014 The warming lotion might expand the arms and are designed to penetrate the bush easily Sent from my GT-I8160L using Tapatalk 2 1 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted March 10, 2014 The warming lotion might expand the arms and are designed to penetrate the bush easily Sent from my GT-I8160L using Tapatalk 2 very clever Quote Share this post Link to post Share on other sites
