jeffbebe
FS: Various bits and pieces (mostly E31 and E39)
Few bits and pieces I don't need... All brand (or near) new:
  • Pair of Michelin Pilot Sport tyres 265/40/R18 - $350 each - SOLD
  • 8 brand new NGK Iridium BKR6EIX spark plugs (suit E39 V8s) - $75 for four or $140 for the lot
  • 12 near-new NGK Laser Platinum 3741 Spark Plug - $25 a pack (of 4) or $80 if you take the lot
  • Pair of E39 foglight delete brake/airbox ducts like the one in the pic below but unpainted black plastic - $150 - SOLD
  • Brand new Mahle oil filter kit for E39 540i (might fit others) - $10
  • Set of 4 genuine aluminium BMW emblems - $40
  • Also got a pair of E31 headlights - untested so not sure if they work or need repairs. $150 ea to Bimmersporters - SOLD
132905d1304433816t-slimms-fog-light-dele
Edited by jeffbebe
Bump - Michelin Pilot Sport 265/40/R18s added.
Michelin pilot SUPER sports Jooles. The crem da la crem of street tyres ;)
Might be keen on the fog light delete panels.
Sorry, SUPER sports!! Chat soon about the fog deletes.
dammit. if they were 265/35/18 i would have been all over it.. agh!!
yea but i want to run stock tyre size and the back is quite high already so dont wana go even higher ><
Fair enough... Only a few mms between 40% of 265 and 35% of 275 though.
I imagine 265/40s and 275/35s would fit aswell unless clearance is really tight on your car. Higher profile might fill the arch a bit better too if the 265/35s have a gap.
Tyres are sold. Also have 8 brand new NGK Iridium BKR6EIX spark plugs - recommended and quality upgrade to M62TUB44 plugs (amongst probably a lot of other applications). $75 for four or $140 for all 8 (RRP is around $30 ea).
Also have a virtually new set of 12 x NGK 3741 Spark Plug - Laser Platinum - bought them as recommended for the M70 only to discover it doesn't like platinum plugs. They were installed for 6-7 days only. As a result, they're yours for $25 a pack (of 4) or $80 if you take the lot.
OP updated.
Have had an offer on them... Will check whether they still want them and let you know asap.
Sweet, thanks. Think the will go well with the front set up of the ute
You might as well go all out with the ute and get a power dome for the bonnet too:
ooh that is pretty. where do you get this from?
Im ordering one of these next month
Schmiedmann used to sell them but can't see it on their website currently. I think the plus side is you don't get the ugly "GTR" vents and fitment will be perfect because you're fitting to your OE bonnet not an aftermarket CF one. Probably a fair bit cheaper. I seem to remember they dome and vent was about $300 + shipping from Schmiedmann.
I thought about it for my E39 but decided it was a bit OTT but for your project, perfect!
