earon
M3 CS Maintenance Project
^ i need to do this. Is it easy to remove?
Yup looks like it will just peel off later :)
Been very busy today with my mate in getting the shocks refreshed. Wanted to go the CSL shocks route but decided against it.
Introducing Sachs Performance dampers and springs:
Posted Image
Posted Image
Posted Image
The springs are actually Eibach springs with Sachs Part Number on it and seems to lower the car by 15mm
Posted Image
Had the front sway bar links changed at the same
time so will get some new rear tyres and then get the car aligned properly.
Next on the list is the front control arms and tie rods and then off to ray to get the rear end bushes refreshed and reinforcement plates welded on!
Hopefully by then my wallet wont cry as much :P
  • Like 4
i mean easy to remove the panel from the steering wheel haha
Hahaha, yeah pop off the airbag and use torx 20 heads to remove 4 screws :)
Wanted to try a black out kidney grill but was unsure but I think I settled on the right medium!
Original VS Black Out
Posted Image
Posted Image
Inner Parts Blacked out
Posted Image
Posted Image
Holy crap that looks bad.
Lucky you spotted it.
Yup :)
But most of the components are being replaced via this refresh and there are no rust affecting the chassis so its fine.
UK Import?
well with the amount of maintenance you've done on it t should be awesome.
we picking it up on sat? :)
Car is finally back where it belongs.
Pretty much the bottom end of the car has been refreshed with new parts!
- Subframe Bushes
- Rear Trailing Arm Bushes with Rogue Engineering Shims
- Upper and Lower Control Arm bushes
- Rear Diff seals
- Subframe Reinforced with Reddish Motorsport Reinforcement Plates
- Rust proofing the underside
- Flex Disc and Associated Parts
- Handbrake Shoes and Handbrake Overhaul
- Engine Mounts
- Rear Swaybar mounts and Endlinks
- Exhaust Mounts
- Pre Cat O2 Sensors
- CPV Replacement with Uprated O Rings
- Tie Rods
- Front Lower Arm bracket bushes
Along with the above, the CSL SMG Tune by Tom via Ray was done and now the car is a now a bloody beast!
Just need an alignment because the track is off and the dash is lit up like a Christmas Tree :P
Once I have recovered from the Wallet hemorrhage then the coils and engine oil service will be next thing to do!
Edited by M3_Boy
Alignment finally done!!
Posted Image
No more DSC Errors - No more Christmas Tree on the dash.
this m3 is getting a full pampering isnt it. lucky car..
edit: pretty sure you have the right to say "no expenses spared" when or if you decide to ever sell the car
Edited by QUBE
Still a long way to go!
I've actually bought 6 Bosch Ignition coils and Bosch AFM for the car as well :P
This project just doesn't stop... Hahahaha!
Next stop: New Steering wheel then some exterior CSL goodies!
How you liking the new throttle mapping Justin? I did a little tweak there also just to see if you liked it?! Car is also delimited but don't go testing that on public roads!!
Also I wouldn't just do the Reddish plates - get the epoxy done also.
I did a big write up quite a few years ago on the rear subframe crack and how plates on its own are useless and next to pointless. A very good friend of the owner at Reddish showed him the write up and he basically said, yep, spot on.
I liken the rear subframe failure to a coke can with a bolt through it, adding another skin on top of the can does nothing to stop the bolt from pulling out - add some sand or silicon in the can and voila, try pulling that sucker out!
Edited by M3_Power
There was a really detailed thread on here from another member who did the subframe mounting repair and re-enforcements using epoxy.
Great work restoring this beautiful car!
The throttle mapping is amazing Tom!
I also love the downshifts by the way, makes the car that much smoother.
Will look into the Epoxy once I get the Coils/AFM/Valve Adjustment is done!
I need to also repaint the steering wheel trim because the Wrap was always a temporary solution.
After this I might start look into getting some CSL goodies.
^ any idea how you're going to paint the steering wheel trim? any particular method?
I'll get the paint code from Tom for the trim and have it painted by Ballantynes in Henderson :)
I might send the steering wheel over to the US to have my Alcantara redone again as well :)
but..... how we gonna car pool with no steering wheel?!?!!? :(
New AFM has been installed.
Slight improvement in idle and performance but nevertheless a good preventative maintenance item!
Only cost $110 from Germany direct so quite a good bargain.
Hopefully I get better fuel economy ;)
Posted Image
