No name user 379 Report post Posted April 30, 2015 So little update for amusement its been dyno'd and front cleaned up, made 487hp on 11.8 psi on 95 pump, stock motor done 287,000km never had the head off. Only mods are the DTM cams and my own intake manifold and exhaust headers, runs A048 for every day rubber which it sort of needs since it makes 1396 ft/lb at the wheels so pulls average i guess. Sits at just under 1400kg's now after fitting fibre glass front yet to do the back, made own billet quick shifter seems to do the job etc. New motor on the stand yet to so in with all the go fast bits in it ill then lean on it harder sadly will need to tub the rear for wider rubber to make use of anymore power ( kills the rears now on semi's in 4th, private road for the PC sensitive ) Box is still a 260G got a bunch of 6 speeds lined up for change of motor, not a rainy day car ! 7 Quote Share this post Link to post Share on other sites
MD13 562 Report post Posted April 30, 2015 Love the understatements/modesty in your posts (no I'm not being sarcastic). Car looks awesome dude! For shits and giggles you could get a badge made up with your avatar pic and glue it were the roundel usually goes 2 Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted April 30, 2015 Still trying to get my head around the torque, that's insane, I assume I'll be able to find more info in other threads on the engine management/ turbo it's running? So much respect! Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 30, 2015 Still trying to get my head around the torque, that's insane, I assume I'll be able to find more info in other threads on the engine management/ turbo it's running? So much respect! Divide by diff ratio to get actual engine torque. 1 Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted April 30, 2015 Brain fart still interested in what's being used to run it Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted April 30, 2015 (edited) M50B25 Turbo : IHI RX8 ( comes off a 96 Lola Indy Car ) ECU : Autronic SMC Yep divide the torque by the diff ratio = around 400 Ft/lb motor, in saying that Polley its still 1396 Ft/lb wheel and never blown a head gasket to date ! Hows your M50 going Troy ? Post a thread love to have a read........ Edited April 30, 2015 by crunchy Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted April 30, 2015 Cheap entertainment 2 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 30, 2015 M50B25 Turbo : IHI RX8 ( comes off a 96 Lola Indy Car ) ECU : Autronic SMC Yep divide the torque by the diff ratio = around 400 Ft/lb motor, in saying that Polley its still 1396 Ft/lb wheel and never blown a head gasket to date ! Hows your M50 going Troy ? Post a thread love to have a read........ I do have a thread, dynoed it last year and been doing hill climbs and sprints all last year, no head gasket problems. Engine is currently removed to make way for an m62 though. 1 Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted April 30, 2015 I do have a thread, dynoed it last year and been doing hill climbs and sprints all last year, no head gasket problems. Engine is currently removed to make way for an m62 though. why the engine change? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 30, 2015 why the engine change? Can't beat the sound of a v8. I still have the m50 setup, car is setup for both engines, can swap between them in a few hours if I need more go fast. 3 Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted April 30, 2015 Can't beat the sound of a v8. I still have the m50 setup, car is setup for both engines, can swap between them in a few hours if I need more go fast. Fair enough too im doing a turbo setup on my M60 cars not worth much so why not i say 2 Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted April 30, 2015 Subscribed for the m60 twin? turbo build 1 Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 1, 2015 Had to convert to N/M, but f**k me that's a lot of torque. There's also a joke in there about semis in forth puhuhu. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 3, 2015 What an epic car! Have you got any more pics? 1 Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 3, 2015 What an epic car! Have you got any more pics? 2 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 3, 2015 So cool. What bonnet and spoiler is it? I love the matt/satin black paint scheme - very mad max Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 3, 2015 So cool. What bonnet and spoiler is it? I love the matt/satin black paint scheme - very mad max I changed the bonnet edge to look that way Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted May 3, 2015 Saw you heading south early this afternoon. Looked and sounded the part. What a car! Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 3, 2015 Saw you heading south early this afternoon. Looked and sounded the part. What a car! You mean yesterday ? Havent been out in it today Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted May 3, 2015 You mean yesterday ? Havent been out in it today Right, sorry, need sleep. Regardless, real testament to your boost-related know-how. 2 Quote Share this post Link to post Share on other sites
