rxhoon 13 Report post Posted September 26, 2015 So after changing my mind numerous times on engine options I have gone 6ltr LS (L98) with 6spd tremec. Roll cage has been started. Still need some advice on the rear end Ideas I do have a winters quick change I am considering using. Any advice would be appreciated 2 Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted September 26, 2015 The stance on this is gorgeous!!!! Quote Share this post Link to post Share on other sites
rxhoon 13 Report post Posted September 29, 2015 Any Diff upgrade suggestions? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted September 29, 2015 (edited) For ease of install you could use an e46 m3 back end. Is the LS staying NA? Cage is looking good. Are you keeping the standard steering column? Edited September 29, 2015 by Thorburn Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted September 29, 2015 Awesome. I'd like to see a local LS swap actually get done properly. How did you go about the engine mounts? As for the diffs, if its got the medium case setup, its probably just good enough for the stock power of the LS with road use, I suspect it wouldn't last with track work though. I know of guys in the states with 500nm+ setups in turbo E36s with 188mm diffs were doing ok, but for your setup I'd do what James suggested and replace the rear end with an M3 subframe for the 210mm large diff. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted September 29, 2015 what was the car originally if it was a 318i 320i etc it will have the small case diff , wont last 5 mins 330i set up would do (med diff but with bigger ,brakes axles and bearings etc) 323i 325i 328i type also use med diff but smaller brakes ,axles and bearings etc , but if you can find one m3 rear end that would be better still Quote Share this post Link to post Share on other sites
rxhoon 13 Report post Posted September 30, 2015 Sounds like the plan to hunt down a e46 m3 complete rear end I will add few more pics of cage and mounts all done by PPRE I will be running a aftermarket pedal box and steering column . Motor will just be rebuilt with a big cam keeping it n/a and hopefully reliable. Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted September 30, 2015 Re enforcing the floor section where the rear subframe mounts to? 2 Quote Share this post Link to post Share on other sites
rxhoon 13 Report post Posted October 1, 2015 A couple of pics of mounts and more cage bars added Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 1, 2015 Nice Engine mounts. But yeah like Martin says, as well as the floor, I'd also look at doing some additional work to integrate the subframe mounting points into the roll cage. Quite a few E36 / E46 people do this. Plenty of ways to do so, but heres one extensive example Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 2, 2015 Was the LS out of a dirt track car? 1 Quote Share this post Link to post Share on other sites
rxhoon 13 Report post Posted October 2, 2015 Was the LS out of a dirt track car? Haha nah engine was in a car that was in a flood lots of silt through engine will be getting rebuilt in the next few weeks. Quote Share this post Link to post Share on other sites
rxhoon 13 Report post Posted October 2, 2015 Nice Engine mounts. But yeah like Martin says, as well as the floor, I'd also look at doing some additional work to integrate the subframe mounting points into the roll cage. Quite a few E36 / E46 people do this. Plenty of ways to do so, but heres one extensive example Yea planing to do something similar and will tie it into cage. Will work it out once diff is sorted incase I use my winters one 1 Quote Share this post Link to post Share on other sites
rxhoon 13 Report post Posted March 6, 2016 Small progress engine rebuilt and engine bay painted , Now to find motivation and crack into it 2 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted March 6, 2016 Looks sooo good sitting there! 1 Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted March 6, 2016 Awesome! Waiting to be unleashed in the not too distant future, Nice work. Quote Share this post Link to post Share on other sites
