russellc2 9 Report post Posted April 21, 2016 (edited) Hi all, Looking for some advice, currently running 17x7.5 style 24 rims and RE003 225x45 tyres (square setup) and looking for more track / sealed sprint oriented setup (and more grip!) I'm keen to stick with square setup and 17's - what do others use on track? do the e90 motorsport rims in 17 fit on ok? I was hoping to go 17x8 or 17x8.5 and 235x45 or 245x40 but not sure how the latter would fit on the front. Cheers, Russell Edited April 21, 2016 by russellc2 Quote Share this post Link to post Share on other sites
M3AN 4194 Report post Posted April 21, 2016 Why not run 235's on your 7.5's? BMW did that up front on a few E36 M3's (M3 GT and LTW IIRC). Quote Share this post Link to post Share on other sites
russellc2 9 Report post Posted April 22, 2016 Thanks for the prompt replies guys! Sounds like the 235/40 option on my current rims would be easiset solution then. Maybe good to try before finding more rims. Although I'm looking at semi slicks like Toyo 888's or similar rather than performance road tyres. I've even heard that Westlake do a semi slick that isn't too bad for the price... So if I do that I still need something else road legal to drive to and from events with. Can anyone confirm if a 245/40 17 on an 8.5 inch rim would fit on the front of an E36? As you note Ron I don't want to loose too much of the feel of the car, but it is pretty loose at the mo (although I don't have a lot to compare with! and still on the average RE003's as you say) Thanks again Quote Share this post Link to post Share on other sites
Arborguy 7 Report post Posted April 22, 2016 Has anyone had experience with the Westlakes so far? Looking at running them on my e36 with staggered style 66 wheels. Scary cheap at $120 for 225/45/17 and $130 for 245/40/17. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted April 23, 2016 From your original question I'm not sure which way you want to go. Are you looking for a set of dedicated track wheels / tyres, or a better set of rims & rubber for your daily? WIth the price of a decent set of used rims and decent semi-slicks, I would say go that route rather than compromising on the daily. 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted April 23, 2016 I had 17x7.5 front 17x8.5 rear on my e36 and previous owner had 225 45 17s all round and i changed them to 235 45 front 255 40 rear and noticed an instant improvement in grip and just overall better feel. Quote Share this post Link to post Share on other sites
russellc2 9 Report post Posted April 23, 2016 Yeah my original question may not have been that clear. I'm after a track / sealed sprint / hill climb setup. I have another car that I daily. I'm just looking at options for the track setup & whether I stay square setup and a little wider all round (235-245/40 17) or staggered. When I'm talking about Westlake I am referring to the semi slick / track tyres. Not the road tyres which are probably in the same class as some of those tyres you mentioned Ron. Thanks for the all the replies guys - keep it coming Quote Share this post Link to post Share on other sites
jom 98 Report post Posted April 23, 2016 The 888s wil give you 1-1.5 secs a lap, but you really need to run stiffer dampers first Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted April 23, 2016 Also check the re55s runout specials . $149 per corner in 17s and street legal like the 888s 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 24, 2016 one would hope there'll be some runout pricing on R888's soon, as the R888 Asymetric has been introduced elsewhere. RE55 runouts - wow. If only I could justify buying some, at that price! Quote Share this post Link to post Share on other sites
M3AN 4194 Report post Posted April 24, 2016 Also check the re55s runout specials . $149 per corner in 17s and street legal like the 888s Where? Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted April 24, 2016 (edited) Pop re55s into trademe. You'll see the sizes and the dealers that still have them.. I almost put a set on the M3 late last year when I couldn't source Re11 s or the replacement re71r which where around $2.2 k a set. Re55s where something like $1300 for a set in 18s ! Just wasn't convinced that I could drive on these every day. Edited April 24, 2016 by Neal Quote Share this post Link to post Share on other sites
russellc2 9 Report post Posted April 25, 2016 Only issue with the re55 specials on tm is they are all advertised as 1 side only... I have no experience with the tyres but will it be an issue if you have one side right way round and the other side is backwards.. Ie the inside marking of tyre is on outside of rim Quote Share this post Link to post Share on other sites
