Gaz 1076 Report post Posted June 10, 2016 What do they go for now days? And what is the compatibility between coupe and vert? Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 10, 2016 Some are being advertised for - frankly - silly money. I've seen them at $3.5k, used. Quote Share this post Link to post Share on other sites
Gaz 1076 Report post Posted June 10, 2016 There is one for about $2k at the moment which seems like a good deal but that is only comparing it to those at 3k Quote Share this post Link to post Share on other sites
APT 199 Report post Posted June 11, 2016 Sedan kits tend to fetch more than coupe kits, i would of thought 2K would be right on the money Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted June 11, 2016 the front rear and boot spoiler will be same between coupe and cabby, the door pods are probably cross compatible but the side skirts definitely won't be as the cabby sides are considerably larger. Possibly can be made to fit if you are happy to cut them, maybe make some finer glass copies and mod those. Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted June 11, 2016 there was a full coupe kit advertised on fb for 2k which i didnt think was bad considering it was door pods and all Quote Share this post Link to post Share on other sites
Gaz 1076 Report post Posted June 11, 2016 the front rear and boot spoiler will be same between coupe and cabby, the door pods are probably cross compatible but the side skirts definitely won't be as the cabby sides are considerably larger. Possibly can be made to fit if you are happy to cut them, maybe make some finer glass copies and mod those. I think they are larger in height so might it harder to mod them. Could just run the tech 2 front, I think that looks pretty good on the whole. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted June 11, 2016 Tech2 lower front and back but retain standard bumpers is a look I like Quote Share this post Link to post Share on other sites
JayCee 26 Report post Posted June 16, 2016 Have a full tech 2 kit with spare door pods for 2k cheers 1 Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted June 16, 2016 himmm that be nice on the se. Quote Share this post Link to post Share on other sites
