Herbmiester 947 Report post Posted December 12, 2016 My 335i currently has these 17 inch style 188s and I have a set of Style 350 (18) that I picked up cheaply. The rear style 350 has a 225 on it instead of a 255 so looks a bit wrong but what do you guys think? By the way the offsets are pretty good. Front is out 4mm and closer by 9mm the rear is in by 1mm and closer by 13mm. I may run a 5mm spacer on the rear yet. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted December 13, 2016 you definitely want some wider tyres for the rear! 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted December 13, 2016 Yes will get some 255 or 265 for the rear. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted December 13, 2016 What size wheel and tyre does BMW recommend for your vehicle. Just consider the extra stress being placed on the suspension bushes and ball joints with the larger size wheel tyre combo. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted December 13, 2016 nothing wrong with going for 18x8 and 18x9 with relatively normal offsets. and also would be fine to run 225/235-40-18 front 255/265-35-18 rear on a 335i. 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted December 13, 2016 225 front and 255 back are factory and M3 runs 235 and 265. So no issues. Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted December 13, 2016 Much better. You should have some fun and rip up those rears before you replace them with the right size. A tuned 335i should have no trouble destroying them... Since you mod your car a fair bit I think following M3 tyre specs would be good. 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted December 16, 2016 would wider tires even help on the rear? The offset looks weak sauce as fark on the rear. Needs a wider tire for sure though. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted December 16, 2016 Rear is the same -1 mm as factory but is closer to the shock as its a 9 inch rim as opposed to an 8.5. May run a spacer to get it out a bit. Don't know much about spacers but 5mm would seem to do it. I could run a 265 rear but as I have some good 255's I will just stick with them. The 225 on the back looks crap I agree and makes it hard to get a real idea. The alloys themself I like though. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 17, 2016 I like em... they look like a "more swish" Style 194. Before running the 235/265 combo, check that the e90 M3 runs same rims as your coupe - offsets and rim widths may be different (as in e46). You going RE003's again, John? Or "something else"? They're doing the "buy one, get one half price" deal on Potenzas at Bridgestone NZ at the moment. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted December 17, 2016 Yes Re003s again. straight up its a good tyre and then you look what price you can get them for and it's a no brainer. sold in the US as the firestone firehawk. very good reviews. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 17, 2016 yep, I'm still loving mine and must have over 10,000 kms on them now which is a 'good thing' IME #; ) 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted December 27, 2016 (edited) So i have fitted the Style 350s with 225 and 255 rubber. The first thing I noticed was that the steering was a little more direct. The fronts that come on the 350's are Nitto Nt830's. the old tyres were Hankook Ventus 2's. I really dont know much about either tyre but the Nittos give decent feedback and seem to have some grip but I haven't pushed them to the limit to really see. Looking at the description I think they are more of a touring tyre. At the rear its hard to pick, Newish S001's vs new Re003's so far its a wash. I do have a slightly wider track at the front 8mm and less at the back 2mm. There is room to push the rears out another 10mm each side so will have a look at that in the new year. The bottom line is that the car feels more precise on 18s than 17's and the ride is slightly firmer but not anywhere near uncomfortable. Edited December 28, 2016 by Herbmiester Quote Share this post Link to post Share on other sites
