Olaf 3414 Report post Posted June 6, 2018 33 minutes ago, gjm said: I've also found that shouting at the laptop and car and asking "if there's no #$%^** problem, why won't you $%^*^&* start?" doesn't actually work. ? thanks mate, that gave me a good belly laugh. Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted June 6, 2018 Ok. Unsure if the cable will work with your setup but you are welcome to bring your laptop with you to try it. It's a USB>16 Pin but i have an adapter if you are using the 38 Pin Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted June 6, 2018 14 minutes ago, Eagle said: Ok. Unsure if the cable will work with your setup but you are welcome to bring your laptop with you to try it. It's a USB>16 Pin but i have an adapter if you are using the 38 Pin Thanks. I've sent a PM. Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted June 14, 2018 Ah, fun times... Visited @Eagle - Jared (so helpful - thank you!) - and borrowed his cable. At home, found I still had the same problem with the software, and found that I had to reconfigure the laptop to 'force' COM1 on to the USB portI was using. Got through that, and I have some mismatched software (I'll sort that later) with language settings being all over the place. INPA is fun. Not especially intuitive, but once you get your head around it, it's great. Cleared codes, tried again, no joy. Re-read codes and this time the crux of the matter appears to be 4A63, something I've not seen reported by the Scanner 1.4.0. 4A63 is 'EWS Manipulation' - basically, the codes between the DDE and EWS have got out of synch. This could be due to a flat battery following trying to start the car before the fuel pump was replaced, which could be complicated by the ECU having been replaced by the previous owner (which would itself have required a re-synch). This is where the fun starts as the language mis-match rears it's head: when navigating through INPA to 'Activate', I'm faced with some pretty unintelligible German instead of the English which had been present before! I'm presented with two options: zurückset - meaning 'reset to default' uebertragen - meaning 'transfer, transmit or broadcast I'll read the instructions. @Gabe79 - I think this may be the issue you resolved for @zero ? [I'll also retry the cable I have here, now that I have identified COM port config as being the potential issue I experienced before.] So - still no joy, but I'm finding other things to try. I keep telling myself "To travel hopefully is a better thing than to arrive..." ? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted June 14, 2018 So engine cranks but wont start? Have you got another key you can try? Maybe post your keys, ews etc to gabe? Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted June 14, 2018 (edited) 31 minutes ago, zero said: So engine cranks but wont start? Have you got another key you can try? Maybe post your keys, ews etc to gabe? Aye - whirr, but no vroom. RESULT: 1 error in error memory ! 4A63 4A63 EWS Manipulation Should be able to sort this with INPA. Or Gabe is welcome to have a look; he suggested he might be able to help. Of course, @aja540i may well have been right, too. Edited June 14, 2018 by gjm Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted June 14, 2018 (edited) 5 hours ago, gjm said: Ah, fun times... Visited @Eagle - Jared (so helpful - thank you!) - and borrowed his cable. At home, found I still had the same problem with the software, and found that I had to reconfigure the laptop to 'force' COM1 on to the USB portI was using. Got through that, and I have some mismatched software (I'll sort that later) with language settings being all over the place. INPA is fun. Not especially intuitive, but once you get your head around it, it's great. Cleared codes, tried again, no joy. Re-read codes and this time the crux of the matter appears to be 4A63, something I've not seen reported by the Scanner 1.4.0. 4A63 is 'EWS Manipulation' - basically, the codes between the DDE and EWS have got out of synch. This could be due to a flat battery following trying to start the car before the fuel pump was replaced, which could be complicated by the ECU having been replaced by the previous owner (which would itself have required a re-synch). This is where the fun starts as the language mis-match rears it's head: when navigating through INPA to 'Activate', I'm faced with some pretty unintelligible German instead of the English which had been present before! I'm presented with two options: zurückset - meaning 'reset to default' uebertragen - meaning 'transfer, transmit or broadcast I'll read the instructions. @Gabe79 - I think this may be the issue you resolved for @zero ? [I'll also retry the cable I have here, now that I have identified COM port config as being the potential issue I experienced before.] So - still no joy, but I'm finding other things to try. I keep telling myself "To travel hopefully is a better thing than to arrive..." ? This isn't the same issue. His issue was a lot more mundane. 1 hour ago, gjm said: Aye - whirr, but no vroom. RESULT: 1 error in error memory ! 4A63 4A63 EWS Manipulation Should be able to sort this with INPA. Or Gabe is welcome to have a look; he suggested he might be able to help. Of course, @aja540i may well have been right, too. I think this is something you can resolve with INPA, or BMW Scanner. Have a look at a thread like this: https://www.bimmerforums.com/forum/showthread.php?2233690-Car-not-starting-after-reset-the-ews-dme-adaptations-with-BMW-Scanner This is a relatively common issue, and you want to search for "e39 sync DME EWS" even some youtube videos around if this is the same issue. 2 hours ago, zero said: So engine cranks but wont start? Have you got another key you can try? Maybe post your keys, ews etc to gabe? I'm always happy to code up keys, but note I am out of keys right now. I'll order more once I am actually living in my own house again, in that fantasy day when the renovations end... Edited June 14, 2018 by Gabe79 I meant BMW Scanner, not EWS. Quote Share this post Link to post Share on other sites
M3AN 4113 Report post Posted June 14, 2018 Okay, well I'll pitch in again even if it doesn't help. I'm not sure you have INPA working at all TBH. If you can get ADS working over USB then you're the first person in the world to do so. Also codes like "4A63" aren't the descriptive codes you'd get from BMW software AFAIK. If you have a language problem with INPA this will be because of a mismatched file in the default directory (typically EC-APPS/INPA). Almost all of the language files end in .eng (English) and .ger (German) so browse through those to see if there's anything obvious. You might need to use a Windows GREP programme to search for the German terms you're seeing. If it's EWS I know nothing I'm afraid... if it's not then I suspect you're going to need to use DIS rather than INPA. INPA is a stepping stone towards DIS which is the proper diagnostics programme. Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted June 14, 2018 (edited) 1 hour ago, Gabe79 said: I think this is something you can resolve with INPA, or EWS. Have a look at a thread like this: https://www.bimmerforums.com/forum/showthread.php?2233690-Car-not-starting-after-reset-the-ews-dme-adaptations-with-BMW-Scanner This is a relatively common issue, and you want to search for "e39 sync DME EWS" even some youtube videos around if this is the same issue. I searched for 4A63 and found a couple of other threads describing similar things. 42 minutes ago, M3AN said: Okay, well I'll pitch in again even if it doesn't help. I'm not sure you have INPA working at all TBH. If you can get ADS working over USB then you're the first person in the world to do so. Also codes like "4A63" aren't the descriptive codes you'd get from BMW software AFAIK. If you have a language problem with INPA this will be because of a mismatched file in the default directory (typically EC-APPS/INPA). Almost all of the language files end in .eng (English) and .ger (German) so browse through those to see if there's anything obvious. You might need to use a Windows GREP programme to search for the German terms you're seeing. If it's EWS I know nothing I'm afraid... if it's not then I suspect you're going to need to use DIS rather than INPA. INPA is a stepping stone towards DIS which is the proper diagnostics programme. It doesn't appear to be a standard BMW fault code format, but is referenced in several places. The 4B90 error I had before falls into the same category. I think INPA is working - it shows when the ignition is on or off, shows engine cranking speed, battery voltage and variations when cranking, and lots more. It'd probably show even more if the engine was running! Regarding language - I found reports that the version of INPA I have - 5.0.6 - hadn't been fully translated, but I've also found the config (.ini) files that I need to edit to ensure English is used. Not tried that yet. I can always try version 5.0.2 if necessary. I've also found details of running INPA/EDIABAS/NCS/NFS (and more) under Windows 10. May give that a look too. Of course, BMW replaced BMW has replaced all the DIS and SSS/Progman software with Rheingold, combining DIS, SSS, INPA, WinFPK and the TIS and WDS into a single of software operated by point-and-click. Again, something to look in to, but it's pretty huge. Edited June 14, 2018 by gjm 1 Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted June 19, 2018 Cleared the 4A63 error. Still wouldn't start. And the 4B90 is back... There'll be a wholesale check of all electrical connections tomorrow, assuming it's not pissing down with rain (again). Quote Share this post Link to post Share on other sites
