BrokeMyWallet 10 Report post Posted August 19, 2018 Hello Boys & Girls I've got coolant dribbling out from the weep hole near the water pump area. I've already started taking this thing apart. I am planning on using the URO parts expanding pipe to rectify this. So far, my parts list has the following Anything else I should "renew" while I'm in the are? Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted August 19, 2018 The crank case vent valve itself will probably be shot. Had one crumble in my hands yesterday! Quote Share this post Link to post Share on other sites
BrokeMyWallet 10 Report post Posted August 19, 2018 (edited) Already done along with valve stem seals Also I’m currently working on removing the manifold still. I need to get this one torx bit off (see pic) but can’t get my rachet handle on there because of the plastic shroud. Any trick to this? Maybe I could get a 1/4” spanner on the hex portion of the socket and back it out that way? Edited August 19, 2018 by BrokeMyWallet Quote Share this post Link to post Share on other sites
Jacko 2241 Report post Posted August 19, 2018 Ratcheting 1/4" spanner Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted August 21, 2018 (edited) On 8/20/2018 at 10:16 AM, BrokeMyWallet said: Any trick to this? Maybe I could get a 1/4” spanner on the hex portion of the socket and back it out that way? This will work, but be damn sure the bit is snug in the hex or you risk stripping it out. Edited August 21, 2018 by KwS Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted August 21, 2018 masking tape on socket then vice grip the socket, pretty sure I did that for my crank case vent valve. Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted August 21, 2018 Why can't you use a normal torx wrench on it? Quote Share this post Link to post Share on other sites
BrokeMyWallet 10 Report post Posted August 29, 2018 Because I didn't have the right bit at the time, and even if I did I'd need some sort of low profile ratchet head to get at it. Anyway I managed to back it off using vice grips + masking tape! After getting that done I promptly managed to strip one of the bolts on the VanOS Servo motor. Clearly this thing has been apart before, I can see the valve stem seals were done, god knows why they didn't do the valley pan at the same time ? Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted August 30, 2018 On 8/29/2018 at 1:41 PM, BrokeMyWallet said: Because I didn't have the right bit at the time, and even if I did I'd need some sort of low profile ratchet head to get at it. Anyway I managed to back it off using vice grips + masking tape! After getting that done I promptly managed to strip one of the bolts on the VanOS Servo motor. Clearly this thing has been apart before, I can see the valve stem seals were done, god knows why they didn't do the valley pan at the same time ? Vice grips and masking tape, 60% of the time it works every time. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted August 30, 2018 no point not using the right tools. because when you use the wrong tools, screw it up, try to solve the problem, and end up buying the correct tool to put it back together again any way, why wouldnt you. 1 Quote Share this post Link to post Share on other sites
