Cammsport 391 Report post Posted January 19, 2019 Long shot but thought I'd try here. The state of decent 4 lug wheels available for my E30 over the past year in NZ has driven me to consider a 5 lug swap. I'm after the front struts, LCAs and spindles from an obd2 E36 M3. Cheers! Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted January 25, 2019 Saturday morning bump ? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted January 25, 2019 Pretty few and far between in NZ unfortunately. Been on the lookout for a long time as well. Lots of other ways to go 5-stud now, but imho this is still the best set up. Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted January 26, 2019 Yea to be honest I just want to have my car certified before Christmas so it looks like I'll have to deal with 4x100. I'm unsure on those SRS concept lollipops and I'm unsure how the machined hubs would go with our cert process. Definitely a compromise on brakes and wheel choice but ?♂️. Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted January 26, 2019 I'd say hit up your certified and ask. Or you could email lvvta directly, which I have done in the past also. Quote Share this post Link to post Share on other sites
rarerimresource 6 Report post Posted January 29, 2019 Z4 rear hubs are direct fit into the E30 trailing arm if you're stuck for solutions in the rear. +3mm track increase. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted January 30, 2019 Yeah, there are plenty of quite simple bolt in options for the rear end, it's the front end where it gets a bit more difficult. Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted January 30, 2019 so what are you going to use at the front, Jon? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 30, 2019 On 1/26/2019 at 7:35 PM, Cammsport said: Yea to be honest I just want to have my car certified before Christmas so it looks like I'll have to deal with 4x100. I'm unsure on those SRS concept lollipops and I'm unsure how the machined hubs would go with our cert process. Definitely a compromise on brakes and wheel choice but ?♂️. I have used the SRS bushes and passed my cert, still need either m3 evo LCA & e36 hubs or m3 LCA & hub to center the wheels correctly 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted January 30, 2019 7 hours ago, skidz said: so what are you going to use at the front, Jon? Still not decided on the front, I keep hoping to find a decent set of M3 (e30) uprights for a not too exorbitant price, but that seems to be a fading dream. So option two would be same as the OP E36 M3 Evo, easy to put coilovers in with the bolt on knuckles. Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted January 30, 2019 So the SRS setup isn't a one stop shop @WYZEUP? Damn, that's disappointing. These parts are obviously rare and there's 10+ people all hawking them by the looks ? 4 lug it may have to be. Quote Share this post Link to post Share on other sites
slideways 53 Report post Posted January 30, 2019 I tried to get away with non M knuckles using the SRS bushes and while I used M3 LCA's to get the wheel perfectly in the centre of the wheel well, the castor was outrageous. An SRS bush gives the same effect of using normal offset LCAB's and M3 Evo LCA's so actually adding the M3 LCA's on top of this to this means your strut is pushed forward at a huge angle. Without using M3 knuckles getting the wheel in the centre of the wheel well isn't too much of a problem, its what your castor and KPI be once you get it there. I have since upgraded to the M3 knuckles and brakes and did away with the M3 LCA's and castor is now bearable with the wheel still centre. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted January 31, 2019 15 hours ago, Cammsport said: So the SRS setup isn't a one stop shop @WYZEUP? Damn, that's disappointing. These parts are obviously rare and there's 10+ people all hawking them by the looks ? 4 lug it may have to be. Try looking overseas, lots of E36 M3s are being wrecked for parts in the UK because no-one can afford the insurance on them. Quote Share this post Link to post Share on other sites
