gjm 3300 Report post Posted May 8, 2019 Has anyone seen or driven one of these? Are they (m)any in NZ? Jon @E30 325i Rag-Top - do you know? Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted May 8, 2019 For anyone else, like me, that had never heard of this model, check it out. Pretty cool for a 4 banger! https://www.bmwblog.com/2009/10/28/bmw-320si-a-real-drivers-car/ Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted May 8, 2019 they are pretty cool. Well thought of in UK. I did read something a year or so ago in BMW Car about wear issues with the engine? Quote Share this post Link to post Share on other sites
Jacko 2359 Report post Posted May 8, 2019 (edited) That is cool, whats the engine code? Google FTW - https://en.wikipedia.org/wiki/BMW_N45 Edited May 8, 2019 by Jacko Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 8, 2019 7 minutes ago, Jacko said: That is cool, whats the engine code? N45B20. 175 road-going hp, 275 for racing. The 320Si is said to handle at least as well as the M3 - it's a homologation car with 2600 being built. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted May 8, 2019 40 minutes ago, KwS said: 4 banger! After its done leaking. Looks aside i think the E36 and E30 iS versions would still be the better drivers cars. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 8, 2019 Camchain tensioner and VANOS are the biggest issues with the N45 generally, but the N45B20 used aluminium liners which can cause problems. Usual other factors apply - use good oil, regularly changed, and good quality fuel. Other than that it's probably no better or worse than many other engines of the same era. But as Jared says - the earlier iS versions may be a better long-term bet. If you can find one... (And the E36 has build quality issues all of it's own, too.) Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted May 8, 2019 Yeah reliability aside It would make a good daily if traffic wasn't a bit issue. Certainly more livable than the E30 and E36, both of which i can barely fit in due to roof height and transmission tunnel. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted May 9, 2019 17 hours ago, gjm said: Has anyone seen or driven one of these? Are they (m)any in NZ? Jon @E30 325i Rag-Top - do you know? I sat in one back in the day when they were available new from the dealerships in the UK, quite pricey over a standard 320i M-Sport IIRC. Quite a cool little limited numbers homologation special, maybe a little down on power in road trim to be fully exciting but still interesting none the less. I didn't get to test drive as there was no demonstrator vehicle as the dealers, so I can't comment from personal experience on that side. I have certainly never come across one in NZ, or heard of one. A quick search reveals nothing NZ, which I would expect. Even in terms of the used imports there is nothing in the screeds of 320i models that have been registered that would suggest it was an E90 Si model. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 9, 2019 Thanks Jon. 170-175 isn't all that much power these days, or even 15 years ago when the M3 was making well over 400. The attraction for me was around handling rather than outright acceleration or speed, so that's not an issue. Sadly it seems as though the lower power output doesn't necessarily translate to better economy, although the stock 85hp per litre isn't too shabby. 1 Quote Share this post Link to post Share on other sites
