Olaf 3426 Report post Posted August 29, 2020 On 7/8/2020 at 9:52 AM, Gaz said: Bolt straight in using e46 inner and e36 outer tie rod @modz @Gaz and for install into an e30, is it the same? e46 inner, e36 outer? Many thanks in advance. I understand the need for rack spacers, steering shaft, and hoses. cheers Olaf Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted August 30, 2020 @Olaf haven't done on before but e30zone suggests either all e30 or e36 https://www.e30zone.net/e30wiki/index.php?title=Steering_Rack_Conversions Quote Share this post Link to post Share on other sites
modz 159 Report post Posted August 30, 2020 I use e36 outers and e30 inners. E36 outers cheapest from partmaster @Olaf if you need any parts or help let me know mate Quote Share this post Link to post Share on other sites
M3AN 4185 Report post Posted August 30, 2020 1 hour ago, Olaf said: @modz @Gaz and for install into an e30, is it the same? e46 inner, e36 outer? Many thanks in advance. You must use e46 inners or machine them (as I did) to allow for internal venting. Neither e30 nor e36 inners are compatible with the e46 rack venting mechanism. For outers, total length (inner+outer) comes into play. So you want approx the same length as e30+e30 with the required e46+???. If e36 and e30 outers are the same length you can use either, if they're not then you'll have to work out what gives you the same overall length (or sacrifice alignment adjustment). For those that have used inners without venting grooves on an e46 rack you're going to blow out boots and ingest volumes of crap that will ruin your rack in short time. 1 Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted August 30, 2020 I've done the swap in the E30, E46 inners, E36 outers. As M3AN says, you can use E36/E30 inners, but you'll need another purple tag rack in a short time. 1 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted August 30, 2020 many thanks @modz @Gaz @M3AN and @nick496 for getting back to me, much appreciated. I had e46 inners in my parts stash for years, though used them on my... e46, oddly enough. e46 inners, e36 outers for this lad. game on. 1 Quote Share this post Link to post Share on other sites
BlackAngel 63 Report post Posted September 3, 2020 (edited) On 6/26/2020 at 3:38 PM, modz said: Bump @Sammo these are stock in 330i / 330ci and a handful of other variants. Really? I bought a purple tag rack for my 330i motorsport - ah well I guess I have a spare now . . . . . Wonder what it would take to put it in the e39 ????? or do they already have them too? EDIT: BTW, is there any way to adjust out radial play in the pinion shaft? Edited September 3, 2020 by BlackAngel added Quote Share this post Link to post Share on other sites
modz 159 Report post Posted September 3, 2020 1 hour ago, BlackAngel said: Really? I bought a purple tag rack for my 330i motorsport - ah well I guess I have a spare now . . . . . Wonder what it would take to put it in the e39 ????? or do they already have them too? EDIT: BTW, is there any way to adjust out radial play in the pinion shaft? Not in E39 that I'm aware of, and I've looked under plenty. Worth checking your 330i M to see if it does. Super easy, jack up the front and look at the underside of the steering column. Quote Share this post Link to post Share on other sites
Harshil 1 Report post Posted September 2, 2021 On 6/18/2020 at 7:52 PM, modz said: I've got a few of these for sale. Degreased, checked and ready to go. $250 each Pick up Howick Auckland or $20 shipped to non-RD's anywhere in NZ. pm if interested Hey mate, are any still available? 1 Quote Share this post Link to post Share on other sites
modz 159 Report post Posted September 2, 2021 Sorry no more available, I sold up everything when I sold my E30. Tip tho - e46 compacts tend to have purple tags… Quote Share this post Link to post Share on other sites
