hunter 413 Report post Posted November 15, 2020 I have what can best be described as a clicking coming from my drivers front wheel well area. It has been getting louder in the last few weeks. it presents itself when moving off from a stand still or turning the wheels (in either direction) at a stand still or moving slow. And I’m sure I might be able to hear it when driving with the window down. But not sure. I thought it might be cured whe I replaced the rack ends, but no. Could it be wheel bearing or possibly sway bar links. I can’t seen anything obvious. Any ideas guys? @hqstu or @BreakMyWindow in your vast experience have you guys heard such a noise. Quote Share this post Link to post Share on other sites
hqstu 780 Report post Posted November 15, 2020 Sway bar links are more of a rattle or knocking, can notice at slow speed on smooth road and then a judder bar or other undulation. Is the frequency speed dependent? Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted November 15, 2020 (edited) Is only noticeable when turning the wheel during slow manoeuvring / turning or when coming to an abrupt stop actually. have been doing some searching and a lot of older forum posts mentioned wheel bearing. It been intermittently happening since before I had my brakes done but frequency has increased recently Edited November 15, 2020 by hunter Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted November 15, 2020 You said in your first post can hear it when turning the wheels from stationary position? Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted November 15, 2020 Strut mount maybe? Can be more of a knock though Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted November 15, 2020 5 minutes ago, Eagle said: You said in your first post can hear it when turning the wheels from stationary position? Yeah. But I don’t do that much. So mostly when I’m pulling in /out of a parking space or my garage or driveway. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted November 15, 2020 Should be easy to pinpoint on the right hoist ramps then with someone listening. Ive got still 2x FAG bearings if that have only done around 60,000km if needed. Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted November 15, 2020 7 minutes ago, Eagle said: Should be easy to pinpoint on the right hoist ramps then with someone listening. Ive got still 2x FAG bearings if that have only done around 60,000km if needed. Yeah I need some help listening / diagnosing. cheers for letting me know about the bearings mate. If I need them I will reach out. Quote Share this post Link to post Share on other sites
BreakMyWindow 2003 Report post Posted November 15, 2020 Take wheel off and remove the calliper. Just 2 bolts holding it on. Spin the disc and have a listen for grinding noises from wheel bearing. Could be the dust shield behind the disc. They get crusty and get a bit of play when the speed nut doesn’t secure it to the carrier fully. 1 Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted November 16, 2020 (edited) I don’t have to to take wheel and calliper off today. But jacked the car up to see if giving the wheel a wiggle reveals anything. see vid. that is essentially what I’m hearing but slower and loaded up with car on ground it has a clicking sound or ping to it. The wheel felt loose. All the wheel nuts are tight. IMG_1383.MOV Edited November 16, 2020 by hunter Quote Share this post Link to post Share on other sites
BreakMyWindow 2003 Report post Posted November 17, 2020 Wheel bearing and or bad ball joint(s) me thinks. Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted November 17, 2020 Cheers Martin, the wheel "wiggles" when i do that, i can feel play there somewhere. just trying to get it into my local mechanic for a closer look. The shock / spring looks like it might be moving too, which is disconcerting to say the least..... Quote Share this post Link to post Share on other sites
BreakMyWindow 2003 Report post Posted November 17, 2020 Ah ok if shock/spring unit has play that’s a bit of a worry too. Yeah someone looking in behind wheel while it’s being wiggled should find the bastard easy enough. Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted November 25, 2020 P&H suspension looked overthe car this week. couple of issues identified; - loose brake dust sheild ratlting / moving on its bolts - tightened - right lower (strsaightone) control arm balljoint clicking / play - will be replaced next week Quote Share this post Link to post Share on other sites
