madhog427 0 Report post Posted July 27, 2021 So can was running good as gold up untill three days ago when it starte3d giving me all error codes at once including transmission failure warning then went into limp mode. It can be fine at times but will always go back to this state at some point. Also shuts of the infortainment screen speakers make weird static noise.. The othe codes are DSC, ABS,Battery termials which are fine.. Im kind of lost where to go from here. My first idea is it has to be an eletrical fault or sumthing.. It sux as its a great car when running right..170,000km on the clock.. ill include sum pics. sumeone must have seen this issue b4. It can be fine for half an hour or so then all hell kicks off. Or if i park it after a cold start and restart it this issue comes up.. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 27, 2021 sounds like battery and alternator issues Quote Share this post Link to post Share on other sites
madhog427 0 Report post Posted July 27, 2021 Thanx I'll test alt tomorrow... Battery is new so yeah Quote Share this post Link to post Share on other sites
jon dee 500 Report post Posted July 27, 2021 What he ^^^^ says. Get hold of a decent battery charger and hook it up in the engine compartment as shown in the pic. Positive lead to the positive terminal (green arrow) and negative lead to the grounding lug (yellow arrow). If everything works fine for a while and then the yellow battery symbol on the dash comes back and the problems start again, your battery is not charging off the alternator. Cheers... Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted July 27, 2021 2 hours ago, madhog427 said: Thanx I'll test alt tomorrow... Battery is new so yeah Has it been coded in? Quote Share this post Link to post Share on other sites
madhog427 0 Report post Posted July 30, 2021 no it wasnt coded in... ive tested it running and when the lights etc come on the battery is charging at 18v so im thinking it voltage reg? 1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 30, 2021 It MUST be registered (coded) to charge correctly 1 Quote Share this post Link to post Share on other sites
Jacko 2244 Report post Posted July 30, 2021 Stop and get someone to code it, then clear fault codes. There are a few pictures on the interwebs of batteries catching on fire doing what you are doing. Quote Share this post Link to post Share on other sites
madhog427 0 Report post Posted July 30, 2021 yeah i not driving it Quote Share this post Link to post Share on other sites
madhog427 0 Report post Posted July 30, 2021 Anyone know where to get voltage reg in nz? its confirmed it is the issue but they hard to find Quote Share this post Link to post Share on other sites
str8_6 278 Report post Posted July 30, 2021 BMW Dealer Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 30, 2021 15 hours ago, madhog427 said: Anyone know where to get voltage reg in nz? its confirmed it is the issue but they hard to find Try AES in Henderson. They can also supply new alternators Quote Share this post Link to post Share on other sites
