Camberley 28 Report post Posted September 11, 2021 Just wondering if anyone has a magic solution to removing water spots from the glass on my e38? Cheers Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted September 12, 2021 Megiuars do one I have had good results with But I would recommend talking to Sam at United Car Car, he is a super helpful guy and would have good recommendations 1 Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted September 12, 2021 I think Autoglym do a glass polish. 2 Quote Share this post Link to post Share on other sites
Camberley 28 Report post Posted September 12, 2021 Thanks for those suggestions. I will follow them up. I have tried several "google" ideas but with little or no success. Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted September 12, 2021 I’m pretty sure I used a “soft” regular car polish on my last car. Worked fine. 1 Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted September 14, 2021 I used one of those shower cleaners with good results, if you have that around. The ones that are meant to clean water spots from shower glass. Just keep it off the paint, or follow it up with detailer or wax. To keep it clean in future use a glass cleaner with a water repellant coating on the outside, or apply a coating. Helps greatly with visibility in the rain too. 1 Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted September 14, 2021 (edited) The branded glass polishes work but because they are a single stage abrasive they are relatively weak. If you dont have a proper buffer you will probably be looking at 15 minutes per window for moderate improvement or 1 hour per window of hand polishing for total removal. If you can acquire a buffer preferably with a hard foam compounding pad or similar you can do this perhaps 5x faster. Edited September 14, 2021 by andrewm 1 Quote Share this post Link to post Share on other sites
